Mid Atlantic Impreza Club
Closed Thread
Old 11-11-2012, 06:27 PM   #3426
96accord
Member#: 145105
2015 WRB WRX Limited
2007 WRX Limited (sold)
Originally Posted by Uncle Tattoo
I feel you there. I've driven the Subaru .5 miles all weekend since Friday at 3. It will get another 4 today as I gotta go get gas for the next 2 weeks.
I am off tomorrow (its a holiday) so I will get gas in the morning before I go to IAG for an oil change.
96accord is offline
Old 11-11-2012, 06:29 PM   #3427
mcuzzin
Member#: 292732
2007 FXT
SGM
Washed, clay bar, 2 coats of wax. It took a couple hours but it Looks like fuggin glass. And now I don't want to take it out of the garage lol
mcuzzin is offline
Old 11-11-2012, 07:57 PM   #3428
ResidentR
Member#: 281656
2011 DGM WRX
5dr limited
New swaybays and end links went on the car today
ResidentR is offline
Old 11-11-2012, 08:07 PM   #3429
EvileyeZ88
Member#: 233501
07AD 337/335SAXWAGON
99 outback sport
^how'd the install go?
Rolled over 76000 today
EvileyeZ88 is offline
Old 11-11-2012, 08:24 PM   #3430
yuephoria
Member#: 64624
2008 FS XT
WR Blue Pearl
Washed it, cleaned the Weathertech floor mats, sprayed on Iron Cut (still can't get used to the smell ) and washed again with ONR. Ran out of sunlight before I could wax it.
yuephoria is offline
Old 11-11-2012, 09:30 PM   #3431
enjoi1968
Member#: 234416
It's A BRAAAAAHtato,
Yo.
Parked the car looked down to this little surprise...
enjoi1968 is offline
Old 11-11-2012, 10:09 PM   #3432
metros
Member#: 111343
Put it on jackstands in preparation of swapping back to street brake pads.
Cleaned my wheels inside and out in preparation for Prima wheel armour.
metros is offline
Old 11-11-2012, 10:17 PM   #3433
ThatGy
Member#: 137791
2002 Impreza WRX
WR Blue
Originally Posted by Smurftastic View Post
Clearly you're doing something right, since you are an original owner I've always been concerned about using Mobil1 5w30 due to studies of Mobil1 5w30 sheering down in the EJ series motor, hence why some suggest 0w40 as a way to combat that sheering. However, you may already be familiar with that line of thought or have a differing opinion, just wanted to share.
I've never read or known about this sheering business, but I'm obviously skeptical about this since I haven't had any problems.
I'll look into it but what is the problem? Are people claiming that it lubricates too well or something? Really, I'd like to know about this because I think there are a lot of oil myths out there.
ThatGy is offline
Old 11-11-2012, 10:33 PM   #3434
ManualOverAuto
Member#: 304662
2001 Impreza L coupe
Sedona red Pearl
This happened today also!
ManualOverAuto is offline
Old 11-11-2012, 10:45 PM   #3435
ResidentR
Member#: 281656
2011 DGM WRX
5dr limited
Install went pretty smoothly, got it all right the first time. Car feels very tight, and there's no clunking or anything
Old 11-11-2012, 11:02 PM   #3436
Bluemachine
Member#: 302496
2016 STI LIMITED
damn
my sti just hit 81k of course I missed the photo
I hope to see the numbers you display.,
Today I decided no more 25mm spacers on the sti., And to sell the seats door cards and carpet! for something new....
Bluemachine is offline
Old 11-11-2012, 11:06 PM   #3437
Smurftastic
Member#: 243697
02 | BLOD Founding
Member | TopScoob 031
While it IS a myth that ALL Mobil1 oils are bad for the EJ series engine (read: M1 0w40 is a good winter-time oil, M1 HM 10W-30 meets European ACEA A3 specs) there are multiple UOAs showing Mobil 1 5w30 will sheer down below 5w30 in an EJ series engine.
Generally the problem is that if M1 5w30 shears down too much and/or burns off, lower oil and/or lubrication levels can lead to spun bearings. Realistically speaking though, a spun bearing due to low oil levels is not just the oil's fault... it really behoovs any WRX/STi owner to check oil levels at least weekly.
Here is a UOA on Rotella T6 on an STi:
http://www.iwsti.com/forums/attachme...9&d=1350740917
Smurftastic is online now
Old 11-11-2012, 11:14 PM   #3438
BradX978
Member#: 334143
2008 WRX
Vin Diesel.
Blacked out the tail lights, cleaned, washed, and detailed inside and out. Ripped some gears on the highway
BradX978 is offline
Old 11-12-2012, 01:45 AM   #3439
ImNOrobo
Member#: 255716
Itsa bugeye 04, V9
RHD and it makes me smile
Got about 70% done with version 2.0 rear diffuser. Then I cleaned the **** out of the garage to make room for the subie.
ImNOrobo is offline
Old 11-12-2012, 09:45 AM   #3440
yuephoria
Member#: 64624
2008 FS XT
WR Blue Pearl
Waxed it this morning.
Old 11-12-2012, 10:07 AM   #3441
rotian28
Member#: 259164
2003 WRX Wagon
I will be installing adjustable rear lateral links and aftermarket trailing arms.
If i have time a 21mm rear swaybar will be going in.
anyone know of a good shop for alignments in Ocean City Md area? or am i driving to IAG performance outside baltimore
rotian28 is offline
Old 11-12-2012, 10:11 AM   #3442
STiWanabe
Member#: 41447
---- _________
Damn, Idk about the oc area but there have to be plenty of shops on the eastern shore. Makes no sense to drive 8hrs round trip for an alignment.
STiWanabe is offline
Old 11-12-2012, 12:11 PM   #3443
08WRXNUBE
Member#: 166524
2008 Spec C
SSM
Just do a search on google and look at yelp also.
If they have a newer machine they should be able to tell you what your ride height is at each corner. And they should also have weights to put on the drivers floor to simulate you sitting in the seat so your car doesn't pull to one side or the other.
Just make sure they give you a before print out so you know the starting parameters. From that point you can tell them to set the camber, caster and toe where you want them.
And once completed they should give you a final print out.
08WRXNUBE is offline
Old 11-12-2012, 02:30 PM   #3444
BoostinIX
Member#: 136701
2013 WRBBRZ/S14 240
04WRX/05STi- Goooone
BoostinIX is offline
Old 11-12-2012, 02:48 PM   #3445
P.Rico
Member#: 239452
2010 Impreza WRX
2005 Outback 2.5i
Installed the Blizzaks and gave it a nice bath.
P.Rico is offline
Old 11-12-2012, 03:11 PM   #3446
voltic
Member#: 310385
Chapter/Region: HIIC
2016 BRZ Limited
Series.HyperBlue
Installed a DW65c fuel pump. Seriously. Never again. I can't imagine trying to squeeze the Walbro 255, this pump was direct fit and still a massive pain in the ass.
voltic is offline
Old 11-12-2012, 03:17 PM   #3447
Abnormal
Lil Curious
Member#: 149626
2005 CGM FXT
Rocket Box! :D
Ah, the plastic eggshell pumps...
I do not envy you. Dicey sounding!
Abnormal is offline
Old 11-12-2012, 03:23 PM   #3448
voltic
Member#: 310385
2016 BRZ Limited
Series.HyperBlue
The clips that hold the actual pump to the housing was probably the most difficult part. It took two of us, and a weird contraption of 4 flathead screwdrivers, one of them bent to hook the clips easier, and then we smacked the pump out with a nice headbutt.
voltic is offline
Old 11-12-2012, 04:10 PM   #3449
lilblue619
Member#: 288292
2004 sti
wrb. the blue one.
Received my Cobb iwg bracket and started deleting my tgvs
lilblue619 is offline
Old 11-12-2012, 05:07 PM   #3450
DKDunn04
Member#: 275640
1968 Corvette-Yellow
2004 STI-Silver
Rebuilt the headlight actuators, replaced the headlight relays, and ran all new vacuum lines in the Corvette.
DKDunn04 is offline
Closed Thread
What did you do to your car today? Jester808 Texas Impreza Club Forum -- TXIC 3235 08-05-2013 12:55 AM
what did you do to your car today? Schrecken Bay Area Impreza Club Forum -- BAIC 11 09-25-2012 03:08 AM
What did you do to your Scoob today? Sheehan North West Impreza Club Forum -- NWIC 27 11-23-2007 12:02 PM
