Mid Atlantic Impreza Club
Closed Thread
Old 11-28-2012, 02:23 PM   #3726
FunnyRico
Member#: 92311
2005 STI : Gone.
2007 STI : Forever.
Originally Posted by mangostick View Post
Yesterday.. pulled the perrin fsb off and put back factory, pulled whiteline rsb and put back factory, removed sub box and amp n power wiring.. removed sts..
refactoryfication .. gettin ready to trade in the ol mule.
Hulk sad....
What are you thinking about trading it for?
FunnyRico is offline
Old 11-28-2012, 02:39 PM   #3727
mangostick
Member#: 256936
2013 FRS
pearl white beetches!
Oh there's no thinking.. its decided. I'm not letting cat out of bag until I have keys in hand though.
mangostick is offline
Old 11-28-2012, 03:14 PM   #3728
SlverEJ20
Member#: 157158
05 WRX stage 2
Originally Posted by gaedikus
dude, yes. stupid valve cover gaskets. and that smell is terrible.
I need to do mine, I can't stand the smell and smoke anymore. Where did you get your gaskets from ?
SlverEJ20 is offline
Old 11-28-2012, 03:49 PM   #3729
gaedikus
Member#: 310254
04 Forester XT
ebay!
http://www.ebay.com/itm/330612735205
make sure you get some RTV too.
gaedikus is offline
Old 11-28-2012, 09:27 PM   #3730
EvileyeZ88
Member#: 233501
07AD 337/335SAXWAGON
99 outback sport
I actually did something to my car today lol.
Dual gauge cluster pod
Prosport perf. Boost gauge (Green)
XD-16 afr gauge innovate LC-1 not connected yet
Thanks Peter
EvileyeZ88 is offline
Old 11-28-2012, 09:46 PM   #3731
AJ711
Member#: 6178
98 GM67 + 03 SG6
2 whls > 4 whls
Swapped the winter rubber on in place of the hard as rocks summer tires. I forgot how squirmy near full tread Nokians can be.
And as it has been previously mentioned, cold starts suck, but motors work better when a load is applied to them. Get in, start the car, turn the seat heaters on, plug in your MP3 player, buckle the seat belt and then slowly drive off. Keep the RPMs low until the coolant has come up to temperature (as oil will be 10-20 degrees higher than the coolant, in general) and things will be just fine.
If you are running a larger radiator, you may want to look into fabricating a plate to block off a portion of the airflow. My koyo will overcool things when out on the highway, so I've put a lexan plate in front of a portion of the radiator. It has helped a bit, but I need to make a bigger piece.
AJ711 is offline
Old 11-28-2012, 09:56 PM   #3732
96accord
Member#: 145105
2015 WRB WRX Limited
2007 WRX Limited (sold)
Nice! 52mm or 60mm Prosport?
If it's the 60mm I have the same one. Mine is in the autometer gauge cluster pod tho
96accord is offline
Old 11-28-2012, 09:59 PM   #3733
EvileyeZ88
Member#: 233501
99 outback sport
Its a 52mm got it for free from a buddy the other day.
Not sure what pod I have but I was told it was an autometer, not really a fan of how it fits, a smy cluster would be optimal but that costs nearly 4 times what I paid for this pod.
~Evil
Old 11-28-2012, 10:08 PM   #3734
ImNOrobo
Member#: 255716
Itsa bugeye 04, V9
RHD and it makes me smile
I have the autometer gauge pods like that and the fitment is fine. I have heard others say it sucks. I was waiting for the smy to come out forever and they kept delaying it.
ImNOrobo is offline
Old 11-28-2012, 10:17 PM   #3735
Ignored281
Member#: 202011
10 WRX Sedan
305hp/355tq
Had the car dynotuned....
306hp/350tq.
Also bought some new lugnuts today. Bought the car used and it came with some heinous ones!
Ignored281 is offline
Old 11-28-2012, 10:28 PM   #3736
EvileyeZ88
Member#: 233501
99 outback sport
The fitment is okay, but it could be better. I can deal with it maybe I'll change it out when I can get a Smy cluster for $40
I like that the Smy cluster re-uses that little flappy cloth thingy to cover the steering column, as well as it has the little plastic pieces that connect to the dash for a nice firm fit.
306hp/350tq.
Nice torque numbers
Is that on the VF-52 turbo?
Old 11-28-2012, 10:38 PM   #3737
Ignored281
Member#: 202011
10 WRX Sedan
305hp/355tq
Thanks
VF-52 is stock, correct? Yes.
Car has intake, exhaust and a boost controller.
Check ur Pm's, sending you my contact info if you need that exhaust welded up. Would be no issue at all!
Old 11-28-2012, 10:45 PM   #3738
EvileyeZ88
Member#: 233501
99 outback sport
Yeah that's the stock turbo, those things are OEM monsters
That's perfect I was just about to go to a muffler shop tomorrow too
~Evil
Old 11-28-2012, 10:55 PM   #3739
V8sPFFF06sti
Member#: 236314
2015 WRX
got my winter wheel set up put on! 07 goldies and continental extreme contacts.... car looks so funny going from 275/35/19s to 225/45/17s
V8sPFFF06sti is offline
Old 11-28-2012, 11:04 PM   #3740
EvileyeZ88
Member#: 233501
99 outback sport
^Pics or it didn't happen
Old 11-28-2012, 11:17 PM   #3741
SneakySh0rty
Member#: 280516
03 WRX v9 trans
I had my dad double check my 6spd swap progress and he thinks my passenger side gasket may need to be replaced. Though I havent noticed any smoke/smell. perhaps mine isnt that bad yet, hoping i can delay replacing it when it gets warmer. It's already a pain working on my car in the cold.
Today, picked up some wires to extend the ones on my dccdpro controller. Also soldered in the diode for the e-brake wire of the controller. Im thinking about posting pics about my wiring job. Slowly finishing most of the things i wanted to do to the car. Cant wait to drive the bugeye again after all the work ive done! gotta thank nasioc for all the DIY threads, else id be even poorer having a shop do the work for me.
SneakySh0rty is offline
Old 11-28-2012, 11:20 PM   #3742
mistathugh4844
Member#: 235548
2002 wrx hybrid
Gutted my ac, started tucking and shaving my bay
mistathugh4844 is offline
Old 11-28-2012, 11:21 PM   #3743
EvileyeZ88
Member#: 233501
99 outback sport
Wow all these people with leaky VC gaskets.
Should I do a detailed write up when I do Gaedikus' gaskets?
~Evil
Old 11-28-2012, 11:39 PM   #3744
SneakySh0rty
Member#: 280516
03 WRX v9 trans
~Evil
im sure there are ones already up somwhere on nasioc. BUT in case there isn't, please do! detailed write ups with pics help out a lot.
Old 11-29-2012, 09:24 AM   #3745
prescottn6ft7
Member#: 268918
2002 WRX Wagon
Got home from 7 days in Orlando... Washed, waxed, and drove the hell out of it.
Also hit up the Central Florida International Auto show while on vacation... it was fun getting to school the Subaru reps they had there that couldn't answer any questions about the WRX and STi at the show.. they actually had me field some questions for people there. Gave me a pretty awesome swag pack:
prescottn6ft7 is offline
Old 11-29-2012, 11:15 PM   #3746
shadowmd
Member#: 193222
05 Wrx 1.5xtr 6spd
2.5 hybrid 367whp/363wtq
Pulled these out of my (what used to be old) r160. The new r180 will be going in Monday along with dss hybrid (Sti to Wrx) axles.
There is more in the diff and ill pull the cover off when it comes out Monday night. Carnage pics will follow. These pics are just what fell out when I drained the diff
shadowmd is offline
Old 11-29-2012, 11:35 PM   #3747
mangostick
Member#: 256936
2013 FRS
I pulled the 3" tbe off and re-installed the factory bits. Unmarried my ap.. refactoryfication continues... Next up, last but not least.. what's left of the audio system.
Old 11-29-2012, 11:37 PM   #3748
Cheese13
Member#: 272366
2003 Evo 8 gsr
Bby
Trading the car in?
Cheese13 is offline
Old 11-29-2012, 11:59 PM   #3749
mangostick
Member#: 256936
2013 FRS
...Yep
Old 11-30-2012, 12:40 AM   #3750
ImNOrobo
Member#: 255716
Itsa bugeye 04, V9
Steve, trade me seats and I will forgive you for getting rid of the bugeye.
Mango, will you have the new car for the meet on Saturday??
ImNOrobo is offline
Closed Thread
What did you do to your car today? Jester808 Texas Impreza Club Forum -- TXIC 3235 08-05-2013 12:55 AM
what did you do to your car today? Schrecken Bay Area Impreza Club Forum -- BAIC 11 09-25-2012 03:08 AM
What did you do to your Scoob today? Sheehan North West Impreza Club Forum -- NWIC 27 11-23-2007 12:02 PM
