Mid Atlantic Impreza Club
Closed Thread
Old 12-27-2012, 03:28 PM   #4201
FunnyRico
Member#: 92311
2005 STI : Gone.
2007 STI : Forever.
Just talked to IAG and my car is ready to be picked up.
Probably heading there on Saturday.
FunnyRico is offline
Old 12-27-2012, 04:11 PM   #4202
skatin707
Member#: 251552
Chapter/Region: HIIC
2014 FXT
Satin White Pearl
Tried to get these coils on.
****ing collars wont come loose. I don't want to go 3 inches lower!
skatin707 is offline
Old 12-27-2012, 05:02 PM   #4203
96accord
Member#: 145105
2015 WRB WRX Limited
2007 WRX Limited (sold)
What did they have her for? Hope not more issues... :/
96accord is offline
Old 12-27-2012, 09:43 PM   #4204
P.Rico
Member#: 239452
2010 Impreza WRX
1991 Prelude Si 4WS
Originally Posted by gaedikus View Post
beautiful D:
i have a set of headlight housings i need to bake apart, but im kind of worried to do it. was it your first time doing this set just now?
I've done it four times now. The first time is always the most stressful, but it's really not a difficult job. The only issue I would see would be if your headlamp is sealed with permaseal instead of butyl. You should check on here or HIDplanet to see if someone's done it for your year and has a write up.
P.Rico is offline
Old 12-27-2012, 10:22 PM   #4205
Matt_H
Member#: 107000
2015 BMW X1
One of the easier mods just time consuming, waiting and baking.
Matt_H is offline
Old 12-27-2012, 10:56 PM   #4206
infinite012
Member#: 74392
2015 Forester
I've done quite a few headlight retrofits. It's definitely a mod for someone with patience no ocd.
infinite012 is offline
Old 12-28-2012, 11:08 AM   #4207
ResidentR
Member#: 281656
2011 DGM WRX
5dr limited
I am swapping fuel pumps this afternoon!
There, I posted it, so I can't procrastinate any more.
ResidentR is offline
Old 12-28-2012, 01:10 PM   #4208
spintheground
Member#: 239638
2007 WRX TR UGM
Fixed my fuel leak, and wouldn't you know? My MPG's have drasticly improved.
Also changed oil and P/S belt. Need to check fluid as my pump has a bit of a whine.
spintheground is offline
Old 12-28-2012, 01:24 PM   #4209
skatin707
Member#: 251552
2014 FXT
Satin White Pearl
Where was your fuel leak at? I think I've got one too and my combined mpg is (at most) 18.
Old 12-28-2012, 01:42 PM   #4210
spintheground
Member#: 239638
2007 WRX TR UGM
It was a 2 fold leak that was a PITA to track down.
The fuel pump assy seal was bad which caused the leak, but I got my car tuned and the evap CEL was deleted so I had no idea where to start troubleshooting. The leak was around long enough to soak my charcoal canister, so I ripped my evap system out.. removed, inspected and replaced the fuel filler neck.. then replaced the gasket. Problem solved.
What makes you think you have a fuel leak? I have the fuel system section of the FSM commited to memory because of my issues
Old 12-28-2012, 01:44 PM   #4211
acumenhokie
Member#: 271479
2010 LGT
2009 FXT
They are calling for 2 - 4 inches of snow so I finally bit the bullet and swapped into my winter shoes. Looking forward to playing in the snow tomorrow morning.
acumenhokie is offline
Old 12-28-2012, 02:07 PM   #4212
skatin707
Member#: 251552
2014 FXT
Satin White Pearl
Sounds like a pain!
I smell raw fuel sometimes and my mpg is awful.
Old 12-28-2012, 02:24 PM   #4213
Uncle Tattoo
Member#: 139542
2007 Civic Sedan
Daily driver status son
Sounds like a pain!
Same problem here. Thought it was just my tune for my upgraded turbo and injectors etc
Uncle Tattoo is offline
Old 12-28-2012, 03:09 PM   #4214
Very WRXY
Member#: 295615
2010 Sea Tree Hundy
Mars Red
Repainting my Hellas and got new stainless screws for them. Also took the plasti dip off of part of my front grill. **** that ****
Very WRXY is offline
Old 12-28-2012, 03:09 PM   #4215
RossLH
Member#: 147839
2003 WRX
SRP
Snow tires and roof rack are on. Now we'll never have snow.
RossLH is offline
Old 12-28-2012, 03:32 PM   #4216
I WANT AN STI
Member#: 79983
2005 STI
Sounds like a pain!
Do you smell it mostly when the car is cold ? I know they had a recall for that on my last wrx. For some reason subaru used a 2 inch piece of rubber hose with somewhat weak hose clamps to adjoin the fuel hardlines that run beneat the intake manifold. When its cold i guess the hardlines contract just enough for a small bit of fuel to leak out until the car is warm and the metal line expands enough to creat the seal again. I dont trust the local subaru dealership so i did it myself. Wasnt too bad but you did have to take a bunch of stuff off to get to the lines. I replaced the rubber and bought some of the nicer fuel line clamps and after that no more raw fuel smell.
I WANT AN STI is offline
Old 12-28-2012, 03:39 PM   #4217
ResidentR
Member#: 281656
2011 DGM WRX
5dr limited
Note to self: Do not fill gas tank first.
Old 12-28-2012, 03:40 PM   #4218
skatin707
Member#: 251552
2014 FXT
Satin White Pearl
It varies, but it does do it when it's cold.
I'll look into that, but I've got bigger fish to fry. Hopefully I can fix my axle tonight.
Old 12-28-2012, 03:49 PM   #4219
spintheground
Member#: 239638
2007 WRX TR UGM
Sounds like a pain!
It was a pain.. fuel system issues are almost as big of a PITA as electoral issues..only 1000x more dangerous.
How strong is the raw fuel smell?
Are there any CEL's?
I have 1300cc injectors and since I fixed my leak I smell no fuel, for what that's worth.
Do you top off your fuel tank when filling up?
How did your fuel pump assembly gasket look when you upgraded your fuel pump?
When was the last time you replaced your front O2 sensor?
Does the smell only happen when it's cold?
You can also inspect your fuel filler neck by removing the guard and see what the rust:metal ratio is. A quick search will bring up some awful pictures of rusted out fuel filler necks.
If you some how should be throwing a CEL but aren't, it could be anything from the gas cap to a valve riiight on top of the fuel tank I was sooo happy not to have to drop my tank
Old 12-28-2012, 03:54 PM   #4220
spintheground
Member#: 239638
2007 WRX TR UGM
I know the 3G's have a better designed pump assembly but still..make sure the gasket is in good shape and in right!
Old 12-28-2012, 03:54 PM   #4221
skatin707
Member#: 251552
2014 FXT
Satin White Pearl
I've got a cel that pops on and off every so often. I probably need a new front o2 sensor. I don't know when it was replaced last and I'm almost at 100k.
Old 12-28-2012, 04:09 PM   #4222
spintheground
Member#: 239638
2007 WRX TR UGM
Read out the CEL if you can!
You can get a front O2 sensor on Amazon for $70 ~. PB Blast the old one for a few days and don't buy a cheap O2 Sensor socket. My car spent a few years in the north east so it was a PITA to get that sucker out.
Old 12-28-2012, 04:11 PM   #4223
skatin707
Member#: 251552
2014 FXT
Satin White Pearl
I love PB blaster. Made my coils a much easier process
Once I get the axle fixed, ill take it to get the CEL read. It's probably a phantom misfire.
Old 12-28-2012, 04:19 PM   #4224
ResidentR
Member#: 281656
2011 DGM WRX
5dr limited
When fuel started pouring out as I was loosening the bolts I cranked them right back down again. Will try again tomorrow after a road trip, haha.
Old 12-28-2012, 04:27 PM   #4225
Kharn
Member#: 306129
Brought it home.
Kharn is offline
Closed Thread
What did you do to your car today? Jester808 Texas Impreza Club Forum -- TXIC 3235 08-05-2013 12:55 AM
what did you do to your car today? Schrecken Bay Area Impreza Club Forum -- BAIC 11 09-25-2012 03:08 AM
What did you do to your Scoob today? Sheehan North West Impreza Club Forum -- NWIC 27 11-23-2007 12:02 PM
