Mid Atlantic Impreza Club
Closed Thread
Old 12-28-2012, 05:54 PM   #4226
mangostick
Member#: 256936
2013 FRS
pearl white beetches!
Nice, I love the smell of new car!
FRS now has 1700 or so miles on it.. last few days of "staycation" have been put to good use effin off, surfing the internet and generally being a bum. and .. driving around for fun just because I can. Avg mpg is still 27.9 by the dash, 28.3 by my mathematics.. I'm inclined to say the dash is probably closer to accurate vs my dumb ass.
So far I've swapped head units, put on the oem mudgaruds and changed the oil.
I'll tell you what, changing the oil on this new FA engine platform is STUPID EASY! With the oil filter on top of the engine and a factory opening in the splash/skid pan for the drain plug it doesn't get any easier. Really nice not having to remove anything to do an oil change. Hopefully the impreza has the same opening in the splash pan.. removing that sucker was a pita on my WRX.
I dunno about the normal impreza FA20 but the FRS takes 0-20wt .. its $9/qt at the zone and this little bear holds just under 6 quarts. A price I can live with for 5k-7500k intervals but damn.. will be nice when Mob1 starts selling that stuff in the bigger jugs.
mangostick is offline
Old 12-28-2012, 05:58 PM   #4227
ImNOrobo
Member#: 255716
Itsa bugeye 04, V9
RHD and it makes me smile
Got a good deal on some forester struts and springs from some cool people. Now to look at options for revalve or rebuild.
ImNOrobo is offline
Old 12-28-2012, 05:58 PM   #4228
OrbitalEllipses
Member#: 178811
2011 White Corolla
Over 400hp
Originally Posted by skatin707 View Post
I've got a cel that pops on and off every so often. I probably need a new front o2 sensor. I don't know when it was replaced last and I'm almost at 100k.
If you were closer I'd offer you my old one to test. It threw a CEL last winter, but mysteriously started working the day I swapped in a brand new one.
My first tank was about 30mpg, but I've averaged about 26mpg a tank since then.
Haven't bothered changing the factory fill yet since it's got pretty high moly content and I'm still only at 3K miles. You can find 0W-20 for cheaper than that, but I've decided to go with Motul ester based oil on this gal and they're stupid expensive for a quart. Absolutely planning on doing UOA so I can really get an idea of how often to change the oil instead of the silly 3K miles I was doing on the WRX.
OrbitalEllipses is online now
Old 12-28-2012, 06:23 PM   #4229
SneakySh0rty
Member#: 280516
03 WRX v9 trans
Took the bugeye for an actual test drive rather than just running her on jackstands to find any leaks. Welp, found one as i drove around the neighborhood. Lost powersteering and as I pull into the driveway I see a drips from when i left and then a big pool of ps fluid. sigh.
SneakySh0rty is offline
Old 12-28-2012, 07:53 PM   #4230
Mr.horsepower
Member#: 338573
2003 bugeye w/vf30
wrb
Rolled my fenders today, thanks to my friend getting a fender roller for Xmas.
Mr.horsepower is offline
Old 12-28-2012, 09:37 PM   #4231
Joslin Rae
Member#: 280613
2005 FXT Premium 5MT
PSM & Aqua
Originally Posted by I WANT AN STI View Post
Do you smell it mostly when the car is cold ? I know they had a recall for that on my last wrx. For some reason subaru used a 2 inch piece of rubber hose with somewhat weak hose clamps to adjoin the fuel hardlines that run beneat the intake manifold. When its cold i guess the hardlines contract just enough for a small bit of fuel to leak out until the car is warm and the metal line expands enough to creat the seal again. I dont trust the local subaru dealership so i did it myself. Wasnt too bad but you did have to take a bunch of stuff off to get to the lines. I replaced the rubber and bought some of the nicer fuel line clamps and after that no more raw fuel smell.
I had this happen to me last winter in my wrx. The smell just went away when it got a little warmer out.
Joslin Rae is offline
Old 12-28-2012, 10:14 PM   #4232
yuephoria
Member#: 64624
2008 FS XT
WR Blue Pearl
Gave the Forester an ONR bath and dusted off the interior with a Swiffer sheet. The interior looks so much nicer when there's no dust bunnies.
Too bad my car looks nice and I have no time to go to meets.
yuephoria is offline
Old 12-29-2012, 12:16 AM   #4233
96accord
Member#: 145105
2015 WRB WRX Limited
2007 WRX Limited (sold)
Talking about fuel issues... I think I need a new fuel pump sending unit. It never goes to F (Full) anymore. It use to go past F but now goes in between 3/4 and F. Getting the same MPGs but have to fill up sooner.
96accord is offline
Old 12-29-2012, 02:27 AM   #4234
SneakySh0rty
Member#: 280516
03 WRX v9 trans
Continued from earlier. Thought the leak was the top banjo bolt on my p/s pump. used brake cleaner to clean everything up and a rag to dry up all the fluid. poured some fluid into the reservoir, every hose connection was dry, then i saw a pool forming on the block underneath the pump and now have a slight whine
Hopefully a rebuild kit can save my pump. also thinking about picking up the o-rings for lines near the rack. Perhaps even better hose clamps to and from the reservoir. I feel its better to take care of those weak spots at once rather than fix one thing to only cause another problem else where.
Old 12-29-2012, 10:06 AM   #4235
spintheground
Member#: 239638
2007 WRX TR UGM
Sounds a lot like an EVAP issue a lot of people have had.
http://forums.nasioc.com/forums/show....php?t=2023595
spintheground is offline
Old 12-29-2012, 11:34 AM   #4236
NutWagon
Member#: 230925
04 WRX Wag Stage 4
06 Impreza 2.5I
looked at it and smiled. wife got it for me for christmas. ive been looking at it for 2 months, she told me I couldnt get it and got sneaky and contacted the seller. I walked out xmas morning after she asked me to take out the trash and I nearly pissed myself. Im back in the suby saddle again. a few changes in store but not much.might looked familiar to some of you. I am super stoked.
Wait wait, Damn man shes a keeper. lol Congrats. Thats the best gift ever. Becides a kid lol.
NutWagon is offline
Old 12-29-2012, 12:47 PM   #4237
karmaSRT
Member#: 231457
2015 STI
That's awesome that's mike aka stimania's old car I think he kicks himself everyday for getting rid of it.
karmaSRT is offline
Old 12-29-2012, 03:37 PM   #4238
Lurch33
Member#: 261832
06 WRX TR
Put the winters back on.
Lurch33 is offline
Old 12-29-2012, 05:41 PM   #4239
slocar
Member#: 338774
2013 WRX
black
Made a trip up to IAG yesterday and had my TBE, stage 2, and kartboy shifter installed!
slocar is offline
Old 12-29-2012, 07:21 PM   #4240
Joslin Rae
Member#: 280613
PSM & Aqua
Bought this from Hiburn at the meet tonight!
Can't wait to put it on my fozzy tomorrow!
Old 12-29-2012, 09:41 PM   #4241
Smurftastic
Member#: 243697
02 | BLOD Founding
Member | TopScoob 031
Hmmm....
Smurftastic is offline
Old 12-29-2012, 09:50 PM   #4242
bill-e-wrx
Member#: 339462
07 wrx ane eclipse
black/blurple
Since its winter and getting wet I threw some plastic floor mats on my floor mats
bill-e-wrx is offline
Old 12-29-2012, 09:50 PM   #4243
I WANT AN STI
Member#: 79983
2005 STI
haha, yea she has already given me one of those. beautiful baby boy..this was a close second .
I bet he does, car is ridiculous. Needs a little paint work but thats what I do. Ive been meaning to message him about the tune and some other questions.
Ill be fixing the paint issues on the front and rear bumper and the front fenders but no big deal, maybe add some aeroguards and if I can ill trade the trunk and hood. I know alot of people like the scoopless and wingless look, and since it has a front mount it doesnt really need a scoop. But I can't help it, I love the scoop, and the I love the spoiler, its just not an sti without it. But well see. This look is growing on me. It does look super slick.
I WANT AN STI is offline
Old 12-30-2012, 12:14 AM   #4244
Bluemachine
Member#: 302496
2016 STI LIMITED
Paint the inset black, super awesome
Bluemachine is offline
Old 12-30-2012, 12:33 AM   #4245
CarTuned
Member#: 42203
2011 WRX
Installed Cobb springs and Alpine front door components.
CarTuned is offline
Old 12-30-2012, 02:51 AM   #4246
karmaSRT
Member#: 231457
2015 STI
He took great care of the car def pm him he's a good friend and will def fill ya in on everything, I always told him to get the normal trunk and good back to haha
karmaSRT is offline
Old 12-30-2012, 09:11 AM   #4247
Joslin Rae
Member#: 280613
PSM & Aqua
That's what I'm doing today before I install it
Edit:
Installed it this morning
Old 12-30-2012, 03:55 PM   #4248
ManualOverAuto
Member#: 304662
2001 Impreza L coupe
Sedona red Pearl
Just finished up the passenger side valve cover gasket/seals/grommets. 15 min after, I drove around and can already see a very small amount of seepage....
-_-
Gonna snug up the bolts a little more, and see where I am. Taking a break now.
Edit: actually, I don't think it's leaking, hard to tell. I'm still taking a break lol, figure it out in a little while
ManualOverAuto is offline
Old 12-30-2012, 06:22 PM   #4249
SneakySh0rty
Member#: 280516
03 WRX v9 trans
Took some measurements of my powersteering lines. sometime this week going to get some worm clamps for the rubber pieces. Then thursday will be picking up my p/s pump rebuild kit from annapolis subaru. ran dry for about a mile, hoping it's still okay. Praying the rebuild kit + the o rings for the bottom portion of the lines will cure my leak and save my pump.
Old 12-30-2012, 07:17 PM   #4250
FunnyRico
Member#: 92311
2005 STI : Gone.
2007 STI : Forever.
Yesterday ResidentR, Syn3rgyz, and Hareball drove me to IAG to pick up my car!!
IAG did something neither Car Max or Dulles Subaru could do... they fixed my car.
FunnyRico is offline
Closed Thread
What did you do to your car today? Jester808 Texas Impreza Club Forum -- TXIC 3235 08-05-2013 01:55 AM
what did you do to your car today? Schrecken Bay Area Impreza Club Forum -- BAIC 11 09-25-2012 04:08 AM
What did you do to your Scoob today? Sheehan North West Impreza Club Forum -- NWIC 27 11-23-2007 01:02 PM
