Mid Atlantic Impreza Club
Closed Thread
Old 12-30-2012, 08:11 PM   #4251
I WANT AN STI
Member#: 79983
2005 STI
traded my trunk from wingless back to sti goodness with a cool local vb guy. Glad to have the spoiler back on there. Makes me happy in the pants.
I WANT AN STI is offline
Old 12-30-2012, 08:39 PM   #4252
okayh
Member#: 338233
2012 WRX
Open sessions at Allsport for my birthday. Sadly, a lot of folks there didn't have any clue on anything....
okayh is offline
Old 12-30-2012, 08:46 PM   #4253
STiWanabe
Member#: 41447
---- _________
Good choice, good 1,000th post
STiWanabe is offline
Old 12-30-2012, 09:41 PM   #4254
ManualOverAuto
Member#: 304662
2001 Impreza L coupe
Sedona red Pearl
Finished up the driver's side a few hours ago. In a few days or so I guess I'll see if it holds up.
Passenger side pic:
I like when bolts break free easily, like how the valve covers were, not torqued down like suspension parts are.
ManualOverAuto is offline
Old 12-30-2012, 09:51 PM   #4255
STiWanabe
Member#: 41447
---- _________
Passenger side pic:
N/A valve covers? So easy, not fair. LOL
Old 12-30-2012, 09:59 PM   #4256
ManualOverAuto
Member#: 304662
Sedona red Pearl
That's why I'm not too concerned if they leak again. I'll just buy a different brand of gaskets and re-do it real quick, lol.
Old 12-30-2012, 10:03 PM   #4257
skatin707
Member#: 251552
Chapter/Region: HIIC
2014 FXT
Satin White Pearl
I have suspension repairs/replacements/upgrades.
I fixed my axle today with the help of a neighbor and fellow NASIOC member!
I also prepped my rear suspension. I soaked that **** in PB blaster, I can't break the bottom bolts free (where the strut connects to the hub). Broke one of my craftsman 1/2 drives too!
Any tips? I keep hitting it with PB blaster to hopefully break the rust.
skatin707 is offline
Old 12-30-2012, 10:11 PM   #4258
STiWanabe
Member#: 41447
---- _________
Only suggestion is air tools. I swear by them
Old 12-30-2012, 10:15 PM   #4259
ManualOverAuto
Member#: 304662
Sedona red Pearl
Or a 3'-4' long steel pipe on the end of your ratchet + more pb blaster.
Old 12-30-2012, 10:21 PM   #4260
skatin707
Member#: 251552
2014 FXT
Satin White Pearl
I did that, broke the pipe.
I need a breaker bar. I have such little clearance without whacking the fender or brakes.
I figure another 24+ hrs of soaking will help. I let the rusted bolts soak in PB blaster for a couple hours and then I used a wire brush to clean the crud off. I'm going to put anti seize on the threads to avoid this in the future.
Old 12-30-2012, 10:26 PM   #4261
Uncle Tattoo
Member#: 139542
2007 Civic Sedan
Daily driver status son
this.
today i helped install tein coilovers on an 01 RSTi and with airtools in my garage it took 2 hours total. i refuse to do suspension without air tools for the bottom bolts.
Uncle Tattoo is offline
Old 12-30-2012, 10:28 PM   #4262
STiWanabe
Member#: 41447
---- _________
Originally Posted by Uncle Tattoo View Post
this.
I'm spoiled, I refuse to do anything but an oil change without air...and a lift
Old 12-30-2012, 10:34 PM   #4263
ManualOverAuto
Member#: 304662
Sedona red Pearl
How did you break the pipe???
When I did my wheel bearings I used the bar for almost everything. I had a 250lb adult putting their weight on it for the axle nuts, and it didn't break.
Someone on here told me about a penetrant for stuck bolts before.....I think it was a mix of acetone and ATF?....not sure about amounts though. Suspension work is just not fun.
Old 12-30-2012, 10:44 PM   #4264
skatin707
Member#: 251552
2014 FXT
Satin White Pearl
It was a crappy pipe, it broke the socket too.
I'm tempted to just hold off and drive my car the the auto shop on base and use their air tools. It's cheap (like $5-$15 for 5hrs) and less than a mile away. I'm always worried about stripping the bolt though.
Old 12-30-2012, 10:45 PM   #4265
Very WRXY
Member#: 295615
2010 Sea Tree Hundy
Mars Red
this.
I uninstalled my coils and reinstalled stock with hand tools.
Suck it up and be a man
Very WRXY is offline
Old 12-31-2012, 12:53 AM   #4266
OrbitalEllipses
Member#: 178811
2011 White Corolla
Over 400hp
Read the same article. Just straight ATF, the bottle was mislabeled from what I recall. I have some Kroil which works well, but I probably wouldn't buy again at the price point. According to that article Liquid Wrench had more power than everything except the Kroil and ATF, which is great because it's OTC and cheap.
OrbitalEllipses is offline
Old 12-31-2012, 07:35 AM   #4267
mhoerath
Member#: 131379
2003 354 [email protected] rpm
justablue hatch
tackled my rear bad bearing. removed rear knuckle and hub and bearings and races. indeed bearings were blue from heat. found have a wrong seal so car is waiting. Hope dealer has right seal and put all back together.
Any tips?
i bought a plug in electric impact gun. mine $160 from sears. good news is it's powerful and never runs out of battery and you don't need air. bad news is it's BIG, extensions are your friend.
two on sale at sears for $98:
Choose this Tough 1/2 in. Impact Wrench for Heavy Duty Use
Made of a lightweight composite, this Craftsman Heavy Duty Wrench is designed for a high torque output. The twin hammering system gives you the extra power when you need it most. This tool comes with a highly effective oil-lubricated twin hammer that churns out 580 ft/lbs. of torque making it a great addition to your garage or shop.
the other delivers 350 ft/lbs.
mhoerath is offline
Old 12-31-2012, 07:38 AM   #4268
OrbitalEllipses
Member#: 178811
2011 White Corolla
Over 400hp
This morning I gave my car a as I noticed what looked like a streak a bird bombs every 6 or so inches from the front bumper to the trunk. Upon closer inspection they're actually paw prints from a small critter.
Old 12-31-2012, 08:00 AM   #4269
skatin707
Member#: 251552
2014 FXT
Satin White Pearl
That's not bad. I'll stop by Sears after work and take a look.
Old 12-31-2012, 02:37 PM   #4270
CamaroFS34
Member#: 6850
1996 Camaro Z28 1LE
& 2006 IAG WRX (ForSale!)
Picked it up from its vacation at IAG and started the break-in miles!
CamaroFS34 is offline
Old 12-31-2012, 03:42 PM   #4271
SneakySh0rty
Member#: 280516
03 WRX v9 trans
pissed as hell. was working on removing power steering pump. That way by thursday when i pick up the rebuild kit and can assemble right away and start driving the bugeye again. took only 20 mins to remove from car. Found an 8mm hex bit for the pulley bolt. Wont budge at all. used an impact wrench did nothing. 2hrs of nothing! wish it was easy like 04wrx+ removals look
Much appreciated if someone can PM some suggestions on removal. I mean it has to be able to come off, else why would they sell a rebuild kit with two seals that require the pulley to come off?
EDIT: Finally figured it out! took the back of the pump off and looked at the shaft. A little clip was holding the shaft/pulley assembly to the pump. Now when the new rebuild kit comes i can use all the seals.
SneakySh0rty is offline
Old 12-31-2012, 09:23 PM   #4272
shadowmd
Member#: 193222
05 Wrx 1.5xtr 6spd
2.5 hybrid 367whp/363wtq
Put it up for sale :-/
shadowmd is offline
Old 12-31-2012, 09:31 PM   #4273
STiWanabe
Member#: 41447
---- _________
Oh come on now, quit copying.
Old 12-31-2012, 09:34 PM   #4274
shadowmd
Member#: 193222
05 Wrx 1.5xtr 6spd
Yeah well I have some bills I want to get rid of, mainly due to this damn car lol but I'm getting an is300 which has plenty of future potential
shadowmd is offline
Old 01-01-2013, 07:51 AM   #4275
I WANT AN STI
Member#: 79983
2005 STI
Took the interior apart and out than spent 6 hours cleaning it. Alot easier to clean a car when there are no seats in it ha.Used a few hundred qtips and a package of cleaning wipes. Need some more and gonna go buy a shop vac to get this carpet actually clean or take it out and pressure wash it. Boggles my mind how dirty people let their 20k dollar car get. Took switches and panels off cause the build up was grossing me out. I guess my standard of clean is a little more than some. Hope to get it all finished up this week.
Closed Thread
What did you do to your car today? Jester808 Texas Impreza Club Forum -- TXIC 3235 08-05-2013 12:55 AM
what did you do to your car today? Schrecken Bay Area Impreza Club Forum -- BAIC 11 09-25-2012 03:08 AM
What did you do to your Scoob today? Sheehan North West Impreza Club Forum -- NWIC 27 11-23-2007 12:02 PM
