Mid Atlantic Impreza Club
Closed Thread
Old 06-06-2012, 09:34 AM   #1501
Uncle Tattoo
Member#: 139542
2007 Civic Sedan
Daily driver status son
Originally Posted by gaedikus View Post
if anyone has seen this problem where within the first 1/2 to full turn (at idle) of the steering wheel you get a sort of resistance and squeal? if i push the revs up a little the problem rights itself, but if i let them go back down to idle it'll squeal again when i try to turn the wheel.
i had that once. i tightened the belt a little and sprayed some stop squeak stuff and it went away. if you end up needing a new pump though, i happen to have one.
i need to clean my IACV, swap out hubs from my parts car so my wheel bearing noise will stop, and piece together my broken vlimited rep lip for OCAWD this weekend
Uncle Tattoo is offline
Old 06-06-2012, 09:44 AM   #1502
gaedikus
Member#: 310254
04 Forester XT
a gentleman and a scholar! thanks friend. (shut up and take my money!)
gaedikus is offline
Old 06-06-2012, 09:53 AM   #1503
Uncle Tattoo
Member#: 139542
2007 Civic Sedan
seriously, GIVE ME YOUR MONEY
Old 06-06-2012, 10:47 AM   #1504
gaedikus
Member#: 310254
04 Forester XT
gonna have to wait till the end of the month, just purchased plane tickets to go home to Wisconsin for the 4th of July
gaedikus is offline
Old 06-06-2012, 11:18 AM   #1505
EvileyeZ88
Member#: 233501
07AD 337/335SAXWAGON
99 outback sport
Need to get Wrx to pass inspection before OCAWD!!!
EvileyeZ88 is offline
Old 06-06-2012, 06:31 PM   #1506
lilblue619
Member#: 288292
2004 sti
wrb. the blue one.
I got a stiffy.
lilblue619 is offline
Old 06-06-2012, 07:44 PM   #1507
Zachfeen
Member#: 277479
2011 WRX
Roof rack and bike mount and fairing installed
Zachfeen is offline
Old 06-06-2012, 08:00 PM   #1508
apexhero
Member#: 309067
08 WRX STI
Dark Grey Metallic
Looks nice!
apexhero is offline
Old 06-06-2012, 08:22 PM   #1509
Zachfeen
Member#: 277479
2011 WRX
Thanks bud. I'm not really a huge fan of roof racks, but I need it for bike transport. Tearing the bike apart to put it in my rear seat was getting annoying and it was starting to take a toll on the rear interior trim pieces.
Zachfeen is offline
Old 06-06-2012, 09:06 PM   #1510
skatin707
Member#: 251552
Chapter/Region: HIIC
2014 FXT
Satin White Pearl
Originally Posted by lilblue619 View Post
I got a stiffy.
Looks good! I've always been curious how you install those. I'm really tempted to get some, how much were they?
skatin707 is offline
Old 06-06-2012, 09:12 PM   #1511
SneakySh0rty
Member#: 280516
03 WRX v9 trans
Just installed my kenwood nav system successfully, (still need to attack parking brake and speed wire for it though) If anyone has a wire diagram/pics, location, help where I should hook up those last 2 wires, PM me please?
Also, attempted to wire up my gauges (Boost, EGT, Oil Press.) but then it got too dark for me to finish.
SneakySh0rty is offline
Old 06-06-2012, 09:25 PM   #1512
lilblue619
Member#: 288292
2004 sti
wrb. the blue one.
Thanks alot!! Not to hard at all 3 fit really nice the two on the ends have slight gaps but I'm OK with it right now. They were a gift but my gf bought 4 from amazon for 150 and i bought the fifth one for 50 from perrin.
Old 06-06-2012, 09:31 PM   #1513
08WRXNUBE
Member#: 166524
2008 Spec C
SSM
PM sent
08WRXNUBE is offline
Old 06-06-2012, 09:56 PM   #1514
ImNOrobo
Member#: 255716
Itsa bugeye 04, V9
RHD and it makes me smile
Installed the front axles, installed the shifter linkage, hooked up about 70% of the engine plugs and hoses. I also painted my brembo's, I will have pics of those tomorrow, they were still drying when I left for work.
I need to drop the rear diff and axles and put the driveshaft on. Still looking good to have her on the road by this weekend.
My trans crossmembers should be here tomorrow and the avcs wiring will be here on Friday. Then it is time to tune.
ImNOrobo is offline
Old 06-06-2012, 10:51 PM   #1515
skatin707
Member#: 251552
2014 FXT
Satin White Pearl
Nice! I'd like to get 3, but I've got too much other stuff I want first.
Old 06-07-2012, 07:12 AM   #1516
DjTrav
Member#: 291264
2015 WRX Limited
Ice Silver Metallic
In time for ocawd?
DjTrav is offline
Old 06-07-2012, 08:57 AM   #1517
gaedikus
Member#: 310254
04 Forester XT
brake lights and fluids checked/replaced/filled. stupid power steering is still fuxxing up, i didnt get the chance to get it fixed it yet :/
gaedikus is offline
Old 06-07-2012, 09:21 AM   #1518
Lurch33
Member#: 261832
06 WRX TR
Cleaned the inside of the windshield for the first time in at least two years. Stared at it.
Lurch33 is offline
Old 06-07-2012, 09:46 AM   #1519
2.5_IMP
Member#: 163604
I have that same problem on my 2005 Legacy. I'm going to drain and replace the fluid to see if that helps. Cheaper than a new p/s pump, that's for sure.
2.5_IMP is offline
Old 06-07-2012, 10:36 AM   #1520
Hokie-wrx wagon
Member#: 87194
Nice! I have a similar setup. OEM cross bars, Inno fairing, and 2 Thule Peloton racks (looks like you have the Echelon).
Hokie-wrx wagon is offline
Old 06-07-2012, 11:07 AM   #1521
gaedikus
Member#: 310254
04 Forester XT
well i just went and had a subie guy i work with check it out with me. with the car at idle, when you turn the steering wheel, the power steering pump pulley slows down (visually), and the belt squeals. however, when the rev's are up, the pump acts accordingly. so i believe it's either a tension, fluid line, or fluid issue.
the belts might just need changing as well. theyre probably old :/
gaedikus is offline
Old 06-07-2012, 11:07 AM   #1522
96accord
Member#: 145105
2015 WRB WRX Limited
2007 WRX Limited (sold)
Drove to work..
96accord is offline
Old 06-07-2012, 01:12 PM   #1523
ImNOrobo
Member#: 255716
Itsa bugeye 04, V9
Originally Posted by DjTrav View Post
In time for ocawd?
Maybe buy I cant go anyway. I have to play navy this weekend, stupid duty
ImNOrobo is offline
Old 06-07-2012, 01:26 PM   #1524
skatin707
Member#: 251552
2014 FXT
Satin White Pearl
Lol I remember those days...12 day weeks thanks to unit training assemblies. For some reason I re-enlisted as active duty for this contract
Old 06-07-2012, 07:40 PM   #1525
Smurftastic
Member#: 243697
02 | BLOD Founding
Member | TopScoob 031
I turned my MAF around so it wasn't backwards and my car worked again.
For an entertaining story of my pain, check out this thread:
http://forums.nasioc.com/forums/show....php?t=2362585
Smurftastic is offline
Closed Thread
What did you do to your car today? Jester808 Texas Impreza Club Forum -- TXIC 3235 08-05-2013 12:55 AM
what did you do to your car today? Schrecken Bay Area Impreza Club Forum -- BAIC 11 09-25-2012 03:08 AM
What did you do to your Scoob today? Sheehan North West Impreza Club Forum -- NWIC 27 11-23-2007 12:02 PM
