Mid Atlantic Impreza Club
Closed Thread
Old 06-09-2012, 08:51 AM   #1551
08WRXNUBE
Member#: 166524
2008 Spec C
SSM
Originally Posted by EvileyeZ88
Topped off the brake fluid, changed the rear brakes, and a real nice cleaning of my snazzy new bbs. Thanks again Gaedikus
I'm confused. Why did you top off the brake fluid?
08WRXNUBE is offline
Old 06-09-2012, 08:56 PM   #1552
FakeIt2MakeIt
Member#: 240500
2006 STI
SGM
Finally fixed the outer CV boot and mounted my painted BBS wheels (black). Next purchase is the V-Limited front lip from MachV.
FakeIt2MakeIt is offline
Old 06-09-2012, 09:38 PM   #1553
EvileyeZ88
Member#: 233501
07AD 337/335SAXWAGON
99 outback sport
Because it was low silly
EvileyeZ88 is offline
Old 06-09-2012, 10:00 PM   #1554
STiWanabe
Member#: 41447
---- _________
low brake fluid is an indicator of worn friction material. Or if its real low, a leak. I never top off my brake fluid as the level shows me how they are wearing. Chances are you may need to replace your pads if the brake fluid was that low...
STiWanabe is offline
Old 06-09-2012, 10:15 PM   #1555
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
Added a fancy new pioneer head unit.
HinshawWRX is offline
Old 06-09-2012, 10:35 PM   #1556
EvileyeZ88
Member#: 233501
99 outback sport
Yuuuuuup
My fronts are a bit low, but the last time I messed with the brakes I had to remove a caliper because of a seized bolt. I probably didn't add enough.
Soooo problem solved ;-)
Old 06-10-2012, 08:08 AM   #1557
prescottn6ft7
Member#: 268918
2002 WRX Wagon
Decided to sell the WRX and bought a 2004 STi
prescottn6ft7 is offline
Old 06-10-2012, 08:31 AM   #1558
Smurftastic
Member#: 243697
02 | BLOD Founding
Member | TopScoob 031
I made the Bugeye jealous by driving an E92 M3
Smurftastic is offline
Old 06-10-2012, 09:39 AM   #1559
08WRXNUBE
Member#: 166524
2008 Spec C
SSM
Yuuuuuup
First you should never add brake fluid, unless you have a leak that you just fixed. Then you also need to bled the system to get the air out. You need to go back and read brakes 101 o not.
I really hope you didn't add to much fluid. When you go to do your front pads, you are going to most likely make a mess when you compress the pistons on the front calipers.
To each their own.
Old 06-10-2012, 10:37 AM   #1560
EvileyeZ88
Member#: 233501
99 outback sport
As I said, I had to remove a caliper a wile back and most likely didn't add enough fluid.
I know how to do brakes, I've been working on cars since I could stand.
Thanks for all the info though
As far as what I did with my car today, I stared at it coming out of Walmart.
Old 06-10-2012, 11:05 AM   #1561
Matt_H
Member#: 107000
2015 BMW X1
You should help me install block off plates.
I saw you post over in that thread quite a bit. haha
Matt_H is offline
Old 06-10-2012, 11:32 AM   #1562
STiWanabe
Member#: 41447
---- _________
one of my favorite thing to do to my car
Old 06-10-2012, 12:28 PM   #1563
EvileyeZ88
Member#: 233501
99 outback sport
Yeah, I happen to know quite a bit about the removal of that god awful system, lemme know when you want some help
Ever since the addition if the BBS I'm stuck in a death stare with my car
Old 06-10-2012, 12:31 PM   #1564
Matt_H
Member#: 107000
2015 BMW X1
I think the next day I have free is the 23rd, although, I don't believe removing my down pipe is an option. : /
I do have an exhaust manifold, trans mount and crossmember bushings that need to go on too.
Forgot I loaned out my Tatrix cable though, so I won't be able to turn off codes.
Matt_H is offline
Old 06-10-2012, 12:59 PM   #1565
EvileyeZ88
Member#: 233501
99 outback sport
I've done a dew of these deletes with out removing the UP or DP.
Its just a pita, but going into it knowing that makes it better
As far as the other parts, I'm sure we can work soooomething out
Old 06-10-2012, 01:14 PM   #1566
STiWanabe
Member#: 41447
---- _________
Ever since the addition if the BBS I'm stuck in a death stare with my car [/quote]
Lol, same thing happened when I put my rotas on
Old 06-10-2012, 01:43 PM   #1567
Matt_H
Member#: 107000
2015 BMW X1
Heh, well I haven't been under my car since the rotated setup went on, so it could be easier, or much harder. I'll have to crawl under it one of these days to give it a look.
Matt_H is offline
Old 06-10-2012, 03:02 PM   #1568
ImNOrobo
Member#: 255716
Itsa bugeye 04, V9
RHD and it makes me smile
Hoping to finish my car up today. The whole rear end, bleed brakes and clutch and then flash the new map made by Phatron.
ImNOrobo is offline
Old 06-10-2012, 03:21 PM   #1569
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
Just did the parking brake bypass for my Pioneer HU. Will be running the satellite radio antenna and mounting that unit later.
Old 06-10-2012, 06:16 PM   #1570
08WRXNUBE
Member#: 166524
2008 Spec C
SSM
Which AVIC unit did you get?
Old 06-10-2012, 08:21 PM   #1571
prescottn6ft7
Member#: 268918
2002 WRX Wagon
Installed intake, radiator plates, belt cover, turbo back exhaust, uppipe, heat shields, bypass valve, pitch stops in 2... yes 2 vehicles. Sold my acces port for the WRX, and had a prospective buyer come by the house and take the WRX for a test driver after it was returned to stock. I am ****ing spent and so sun burnt it hurts to flinch.
Old 06-10-2012, 08:33 PM   #1572
04boosted-rex
Member#: 297212
2004 suabru wrx
blue
put in new motor hooked everything up and got her to turn over. Then sprayed half a quart of oil from turbo area and underneath motor somewhere. First time I built a motor!! Did it all myself pretty happy of myself. :-) Now to investigate oil problem :-[
04boosted-rex is offline
Old 06-10-2012, 09:50 PM   #1573
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
That's about the strangest bit of advice I've ever read. So I should just live with the "BRAKE" light rather than filling the fluid to the proper level? On both of the cars I own that actually have fluid level sensors in the MC reservoir, the light is triggered well before the pads are worn out. And it's not like removing the fluid when you change the pads is some sort of crippling inconvenience. A couple seconds with a turkey baster (which you already have in your tool kit, unless you never flush your brake fluid) and you're done.
Patrick Olsen is offline
Old 06-11-2012, 12:59 AM   #1574
ImNOrobo
Member#: 255716
Itsa bugeye 04, V9
Fought the rear end stuff yesterday. (Rear diff, lateral links, trailing arms, hubs) It took waaaaaay too long to get just two bolts out. I was able to put the r180 diff and driveshaft in before I needed to get ready for work. I knew this whole swap was going too smoothly for nothing to happen.
Almost done with this crazy swap. It also sucks having to do most of the work by myself. I get a friend to help for a couple hours here and there.
I fired her up again to find any leaks, saw there is a few small exhaust leaks (header flanges and header to uppipe.) One small coolant leak at the back of the motor as well, just a bad clamp I presume.
I got my base tune from Phatron this weekend as well, that will be flashed once I can drive and do the logs.
ImNOrobo is offline
Old 06-11-2012, 01:04 AM   #1575
EvileyeZ88
Member#: 233501
99 outback sport
^Shes gettin close
Closed Thread
What did you do to your car today? Jester808 Texas Impreza Club Forum -- TXIC 3235 08-05-2013 12:55 AM
what did you do to your car today? Schrecken Bay Area Impreza Club Forum -- BAIC 11 09-25-2012 03:08 AM
What did you do to your Scoob today? Sheehan North West Impreza Club Forum -- NWIC 27 11-23-2007 12:02 PM
