Mid Atlantic Impreza Club
Closed Thread
Old 06-25-2012, 12:11 PM   #1776
Gro Harlem
Member#: 165782
2015 WRX Limitd Stg2
'02 Stg4 & JSW TDI Stg2
I'm using a VF34 v3.00 accessport OTS tune until i can get it pro-tuned later on. The parts shouldn't affect the tune aspect since I basically just replaced a louder TBE, and the inlet & fixed the coolant leaking issue. Engine mounts wouldn't effect the tune lol.
I just pulled the code, its P1088...TGV??? WTF? I didn't even touch those. It would explain why the car acts like its choking for air when i floor it. Also said something about a missfire & O2 sensor but no code for those. BAWLZ
Gro Harlem is offline
Old 06-25-2012, 12:19 PM   #1777
ppayer38
Member#: 234407
04 Self-tooned
STi
Inlet does affect the tune and some tbe are different enough to need the retune... Just my 2cents though
If your having trouble with tgv's get some seafoam and or check all connectors
ppayer38 is offline
Old 06-25-2012, 01:17 PM   #1778
Gro Harlem
Member#: 165782
just saw what happened, the clamp from the inlet crushed the fking sensor on the right bank a bit ...might have destroyed it. i just finished turning the clamp a bit so the clamp screw doesn't hit it.
god i hope i don't have to remove that sensor looks impossible without removing the turbo since the lower bolt is RIGHT THERE. If i have to do all that work again i'll just do the TGV delete mod also.
gonna reset the codes using my AP and go for a drive to get some lunch...hopefluly that code doesn't pop up
Old 06-25-2012, 01:19 PM   #1779
DjTrav
Member#: 291264
2015 WRX Limited
Ice Silver Metallic
Good luck
DjTrav is offline
Old 06-25-2012, 02:10 PM   #1780
gaedikus
Member#: 310254
04 Forester XT
nailed it, but that sucks bro. how much is a new sensor?
gaedikus is offline
Old 06-25-2012, 02:45 PM   #1781
H8BOOST
Member#: 319268
2005 Sti
Delete
H8BOOST is offline
Old 06-25-2012, 02:46 PM   #1782
H8BOOST
Member#: 319268
2005 Sti
Decided to spend the day installing my Agency Power Header and Up Pipe also changed the oil. Also a new turbo finally!
H8BOOST is offline
Old 06-25-2012, 03:29 PM   #1783
Gro Harlem
Member#: 165782
i read they are like 90$ from subaru, but i'm hoping they are pretty common TPS sensors used on older models cuz i can get one from a junkyard car for 10 bux maybe
It makes sense the car runs like it does, the butterflys aren't opening at all & the car feels like its missfiring. the 2 right cylinders are starving for enough air to run.
Running my AP in monitor mode shows 0 volts on the right TGV and 3.5-4.4 on the left one, so maybe the wire got jacked up somehow.
Old 06-25-2012, 03:37 PM   #1784
gaedikus
Member#: 310254
04 Forester XT
hope it works out for you bro, if i had another sensor chillin i'd throw it your way.
gaedikus is offline
Old 06-25-2012, 03:37 PM   #1785
Uncle Tattoo
Member#: 139542
2007 Civic Sedan
Daily driver status son
i believe i have the sensors sitting around in my garage.
Uncle Tattoo is offline
Old 06-25-2012, 04:57 PM   #1786
REDWRX05
Member#: 154171
2005 WRX (SRR)
In Need of More Power!!!
Changed out my oil separator gasket which was leaking, now on to plugging a tire with a nail in it.
REDWRX05 is offline
Old 06-25-2012, 06:46 PM   #1787
suBAEru
Member#: 235979
2011 WRX
Procrastinating on taking one of my summer class finals...
suBAEru is offline
Old 06-25-2012, 07:36 PM   #1788
ImNOrobo
Member#: 255716
Itsa bugeye 04, V9
RHD and it makes me smile
Finally able to do another log. Just sent it off to Ron. Can't wait to see how it goes.
ImNOrobo is offline
Old 06-25-2012, 10:03 PM   #1789
ppayer38
Member#: 234407
04 Self-tooned
STi
Driving myself nuts about making sure all my exhaust ID's are prefect for low-mid range power and mate up flawlessly all the way to the turbo
My little 2.0 will make boost in the early 3k with a 16g "Evil laugh"
ppayer38 is offline
Old 06-25-2012, 10:20 PM   #1790
ImNOrobo
Member#: 255716
Itsa bugeye 04, V9
Sounds ok to me.
I got a few new revisons tonight. The newest one is a third gear pull up to 6500. Unfortunatly I am at work now, I will do the pull in the am before I head home. I did flash that map before I got to work though, she is feeling stronger!!
ImNOrobo is offline
Old 06-26-2012, 09:37 AM   #1791
Noslow
Member#: 316326
I took off my HKS ssq, it no longer sounds like my car is sneezing between gears.
Noslow is offline
Old 06-26-2012, 01:06 PM   #1792
yuephoria
Member#: 64624
2008 FS XT
WR Blue Pearl
Oil change at Andrewtech and a car wash with ONR.
yuephoria is offline
Old 06-26-2012, 01:30 PM   #1793
mangostick
Member#: 256936
2013 FRS
pearl white beetches!
I keep filling up a leaking rr tire .. used to be on rf.. but I figure if it goes flat on the rear its just annoying.. vs going flat up front and killing me/others.
so pissed.. these tires are worn but still have lots of good tread left. The leak is a pinhole at the very corner of the tread/sidewall. No way it can be patched from inside or out. So this pretty much has me forced to prematurely buy a set of summers. guess paying down my cc isn't going to happen any sooner.
mangostick is offline
Old 06-26-2012, 02:01 PM   #1794
DjTrav
Member#: 291264
2015 WRX Limited
Ice Silver Metallic
I have some tires FS =)..... all seasons though =(
DjTrav is offline
Old 06-26-2012, 02:20 PM   #1795
mangostick
Member#: 256936
2013 FRS
size brand model? I'd prefer to run summers since I have a dedicated set of winter wheels/tires.. but if the price is right (aka supa cheap) I might be convinced otherwise. I really didn't want to worry about buying new summers until winter time when the summer set were off the car for powdercoating.
Old 06-26-2012, 02:39 PM   #1796
freddy121389
Member#: 294644
2011 WRX Agile Auto
DGM 440whp 420wtq
I got asked "is this a mazda speed 3?" today at our ECP
freddy121389 is offline
Old 06-26-2012, 02:44 PM   #1797
Gro Harlem
Member#: 165782
i got sumitomo a/s P01's on my toyota matrix beater, they are essentially a direct knock-off of Michelin pilot sport a/s for less than half the price. Paid like 90 each for some 205/45 17's. First thing i noticed, QUIET, good dry grip great wet grip great snow grip & they are supposed to help fuel econ too.
Old 06-26-2012, 02:45 PM   #1798
Gro Harlem
Member#: 165782
my buddies speed3 has been mistaken for an sti plenty of times lol...damn hood scoops!!
At least it has a legit TMIC & isn't some fake ricer scoop like you see on the toyota trucks
Old 06-26-2012, 02:55 PM   #1799
mangostick
Member#: 256936
2013 FRS
that's cheap.. but not "supa cheap" .. and I need a 235/45R17.
205's are quite a bit cheaper in every band.
Old 06-26-2012, 04:30 PM   #1800
CR22
Member#: 167470
2005 Subaru
Just got rid of that very annoying seat belt scream in my '04.
I would say it's easier to do than replacing windshield wipers (and free).
CR22 is offline
Closed Thread
What did you do to your car today? Jester808 Texas Impreza Club Forum -- TXIC 3235 08-05-2013 12:55 AM
what did you do to your car today? Schrecken Bay Area Impreza Club Forum -- BAIC 11 09-25-2012 03:08 AM
What did you do to your Scoob today? Sheehan North West Impreza Club Forum -- NWIC 27 11-23-2007 12:02 PM
