Mid Atlantic Impreza Club
Closed Thread
Old 03-06-2012, 08:37 PM   #101
God&Sme
Member#: 256567
2002 PSM WRX - SOLD
97 GSXR = FAST
dang, good looking amigo! haaaaa, that was a quick answer. I was searching through the suspension threads but couldn't find anything addressing my situation.
another question, i know everyone would say that my car is due based on mileage for new shocks/springs, but I'm just curious, isn't a solid test to push down on the corners of the car and when the shocks are gone there is a lot of bouncing? Because there is little to no bounce when i do this and i feel like it's fairly tight, but I never knew what stock felt like either...
God&Sme is offline
Old 03-06-2012, 08:39 PM   #102
blackfang
Member#: 131347
2007 Legacy 2.5i SE
98 Z/28, VN 900 custom
Well if it was a suspension issue, you should notice the vibration at slower speeds too. If it gets worse the faster you go, that is a strong indication of a wheel/tire out of balance. Plus worn suspension components also tend to make noises too. Yes, usually when the struts are bad, they will have a lot of fluid leaking from them. Do not confused this is a little bit of fluid seeping. Also there will be a lot of bouncing as well. Plus irregular wear patterns on the tires will be a sign too.
blackfang is offline
Old 03-06-2012, 08:42 PM   #103
God&Sme
Member#: 256567
2002 PSM WRX - SOLD
97 GSXR = FAST
so if I dont have any leaking or bouncing, but the inner's wore down like crazy in 20k and I somehow managed to get some bulges in them, does that sound like they are done?
i mean 90k does sound like a bit, but my wife's eclipse has the stock suspension n that thing is at like 180k n the handling is tight.
God&Sme is offline
Old 03-06-2012, 08:46 PM   #104
blackfang
Member#: 131347
2007 Legacy 2.5i SE
Inners are worn down? Like the inner portion of the tire? If so that is an indication the alignment is out. The bulges in them? Like on the sidewall?
Old 03-06-2012, 08:51 PM   #105
God&Sme
Member#: 256567
2002 PSM WRX - SOLD
97 GSXR = FAST
yup, inner portion, like inner 20% of tread. and yeah the bulges are actually in the tread...like when i was rolling them they would roll weird b/c they were rolling over the bulges. really odd
God&Sme is offline
Old 03-06-2012, 08:57 PM   #106
blackfang
Member#: 131347
2007 Legacy 2.5i SE
The inner tire wear is an alignment issue and the bulges, do they look like this?
Old 03-06-2012, 09:04 PM   #107
God&Sme
Member#: 256567
2002 PSM WRX - SOLD
97 GSXR = FAST
Ya & u can feel it. As I was rolling the tires into the garage it was almost making them tip over
God&Sme is offline
Old 03-06-2012, 09:08 PM   #108
blackfang
Member#: 131347
2007 Legacy 2.5i SE
That is a cupped tire and an indication the struts are worn.
Old 03-06-2012, 09:12 PM   #109
God&Sme
Member#: 256567
2002 PSM WRX - SOLD
97 GSXR = FAST
Aaaaahhhhhh ha, thanks phil. I always thought a cupped tire had like a bulge all the way around, not just in spots.
God&Sme is offline
Old 03-06-2012, 10:46 PM   #110
Troll Boy
Member#: 58910
2015 WRX STi
2005 Legacy 2.5GT Limited
Well the sti is still in the shop and when I stopped in today to see what is going on cause I never got a call, he states they are to busy and never even looked at my car, and didn't even know when they can even look at it. Looks like it doesn't apply for the lemon law either, looks like 3 years is the time period, not the length of your warranty like I hoped. But I have to check the Subaru manuals in my sti to be sure. Subaru also said they will not increase the warranty period on my car also even though this is the third time my motor blew.
Troll Boy is offline
Old 03-06-2012, 11:57 PM   #111
God&Sme
Member#: 256567
2002 PSM WRX - SOLD
97 GSXR = FAST
I've said it once, and ill say it again: The legend of dirty joe continues
sorry to hear buddy
God&Sme is offline
Old 03-07-2012, 06:07 AM   #112
blackfang
Member#: 131347
2007 Legacy 2.5i SE
That sucks man. Sounds like the typical we are f'n tired of dealing with you and we will get to it when we can response. They are not that busy and never have. You are a third time comeback and should be priority!!
Yeah i mentioned in the other thread you're vehicle wouldn't qualify. IIRC, it has to be in for at least 3 repair attempts within the first 18 months of ownership or out of service over 30 days.
Old 03-07-2012, 06:42 AM   #113
mhoerath
Member#: 131379
2003 354 [email protected] rpm
justablue hatch
finally decided to fix my front lip, several cracked areas and pieces hanging on. bondoed and sanded ($15). bought true color color match rattle can paint along with plastic adhesion promoter/primer/color/clear coat ($70).
paint color is a 100% match. clear coat is gloss, but high gloss required. and with paint can now see my crap sanding job.
soooo i'll wet sand and repaint. and use high gloss. and front will look awesome. also picked up 4 door cards and a backseat for $120, going black interior to match my (painted) black rug. will prob source front seats from jspec.
i went with tokico spec d struts...decent coil overs $ much for me.
sorry to hear about the motor probs...if you have spend money out of your own pocket what would you do different?
mhoerath is offline
Old 03-07-2012, 09:29 AM   #114
Troll Boy
Member#: 58910
2015 WRX STi
to bad it is past that time period, cause i didn't have it for 30 days the first 2 times they had it, they had it for 2 weeks now this time already and never looked at it.
Would replace more parts, not just the pistons or shortblock, or would have sent it to IAG and make sure it was done right
Old 03-07-2012, 06:50 PM   #115
blackfang
Member#: 131347
2007 Legacy 2.5i SE
It only applies to new vehicles though not used ones.
Old 03-07-2012, 07:40 PM   #116
farmboss
Member#: 252324
04 STi
JBP
These people are asking 13k for this WRX. I don't see how its worth anymore than 9k... http://www.coast2coastautosales.com/...u-Impreza.aspx
farmboss is offline
Old 03-07-2012, 09:06 PM   #117
God&Sme
Member#: 256567
2002 PSM WRX - SOLD
97 GSXR = FAST
haaaa they clearly have no idea what car they have, or that car has some work done. 6speed???
I paid 8.5 for a car that looked just like that and had 67k
God&Sme is offline
Old 03-07-2012, 09:14 PM   #118
farmboss
Member#: 252324
04 STi
JBP
You get yours from a private owner? Thats the best way to go apparantly, dealerships are charging out the ass. I guess they have to though.
farmboss is offline
Old 03-07-2012, 09:28 PM   #119
Troll Boy
Member#: 58910
2015 WRX STi
I bought it brand new in, but yea I'm out of the time period, i like how subaru is not looking after me though and not getting on Moore....their field rep was suppose to look at it....
Old 03-07-2012, 10:02 PM   #120
God&Sme
Member#: 256567
2002 PSM WRX - SOLD
97 GSXR = FAST
dang daniel, that did surprise me. You interested in driving the LGT to C&C saturday?
and actually Hunter it was from a dealer up in nova, but he literally bought it at auction thurs, and i was there to put down a deposit on friday
God&Sme is offline
Old 03-07-2012, 10:17 PM   #121
blackfang
Member#: 131347
2007 Legacy 2.5i SE
I would keep calling SOA and Moore. Make numerous phone calls a day to let them know you mean business.
Old 03-08-2012, 01:24 PM   #122
Troll Boy
Member#: 58910
2015 WRX STi
dang daniel, that did surprise me. You interested in driving the LGT to C&C Saturday?
I can, didn't know anyone was going.
I can never get ahold of the person that is dealing with my case at Subaru. I'm going to highly suggest sending it to Pence Subaru if she ever calls me back. This hold thing is pissing me off though, motor blew 3 times in a few months, they must not know what they are doing at Moore, and some how that is my fault?
Old 03-08-2012, 05:23 PM   #123
mhoerath
Member#: 131379
justablue hatch
[quote=Troll Boy;36577739]I can, didn't know anyone was going.
i'll be there
mhoerath is offline
Old 03-08-2012, 05:51 PM   #124
God&Sme
Member#: 256567
2002 PSM WRX - SOLD
97 GSXR = FAST
Well Smurftastic Dave is meeting me around 8. We can either meet up at your crib daniel b/c its on the way or my dads casa. Anybody else wanna meet up before to cruise in together?
God&Sme is offline
Old 03-08-2012, 08:00 PM   #125
farmboss
Member#: 252324
04 STi
JBP
Put my summer Wheels/Tires back on. The right front winter wheel was giving me trouble while I was trying to take it off. It took 140psi to get 4 lugs off and the last one I had to get my dad to break loose with the torque wrench while I held the brake. Finally got it off and the stud that the last lug came off of was destroyed and a couple of the others weren't to good. It must have happened when I put them on I guess.
But I called Subaru of richmond and they happened to have 4 studs in stock so I picked them up and installed them. Wasn't as bad as I thought it was going to be. Their was 1 stud that was ok but the rest were crap so I only needed 4.
farmboss is offline
Closed Thread
Calling All 97-99 LGT 2.5 N/A mpg thread illegal2.2 Legacy Forum 20 10-08-2008 10:27 AM
Calling All Subarus In Edmonton ArcAnGeL Western Canada 25 09-17-2006 03:55 PM
Calling all Clemson Area Subarus Cannonbolt South East Region Forum 8 11-04-2004 11:39 AM
calling all stock solo 2 WRX's Akiata North West Impreza Club Forum -- NWIC 39 07-27-2004 02:42 AM
