Old 02-23-2012, 10:50 AM   #1
cloudconnects
Member#: 188777
Default What to do with blown 01 legacy
So my 01 legacy GT limitied died the other day. engine just shut off, tried to restart and it was knocking like crazy so i had it towed to a shop. shop says the engine is screwed.
quote for a new engine installed is $4300.
what are my options here? what engines will literally drop in and bolt on and plug into the harness without modification? are there places that sell harnesses that will let me drop in other engines? is doing this going to be too much more of a pain in the ass then just letting the shop do it?
keep in mind im in northwestern canada so shipping of engines and stuff can get expensive.
thanks.
cloudconnects is offline   Reply With Quote
Old 02-23-2012, 01:19 PM   #2
S53089
Member#: 172942
1992 Mazda B2600i
Drift Slut
the same engine will be the only one to drop in bolt and plug without any modification. you would need to modify your harness to drop in a different engine. if you get the same engine and just swap them out, it wouldnt be to much of a task, being that you are comfortable doing something like that.
S53089 is offline   Reply With Quote
Old 02-23-2012, 06:00 PM   #3
cloudconnects
Member#: 188777
ok thanks. i think this is probably what i will end up doing.
That being said, is merging the harness really that difficult? with the amount of knowledge on NASIOC and other subaru forums im sure i can find some sort of an "attach this wire to this wire" guide
Old 02-23-2012, 06:01 PM   #4
cloudconnects
Member#: 188777
also are all the EJ251s the same? Assuming it came from a car with a 4eat?
Old 02-24-2012, 12:32 AM   #5
RexWagonWA
Member#: 221945
Default wiring harnesses
You may want to check out iWire. They offer a couple of harnesses. You need to pick the engine and ECU. Then figure out what is needed for your swap. AVCS may or may not be worth the hassle. E85 is another path you could take? Depending upon if it is available in your area.
RexWagonWA is online now   Reply With Quote
Old 02-24-2012, 05:57 AM   #6
Marnix
Member#: 51480
1984 AM5, 1994 BC4,
2010 BR5
You can re-use your intake manifold and wiring on any SOHC EJ25 longblock. No hassle.
Marnix is online now   Reply With Quote
Old 02-24-2012, 12:22 PM   #7
Beenyboy
Member#: 311401
2002 Forester
grey
X2, including 06-11 2.5L, just use the long block, if you don't hook up the VVT (no problem), you will loose a bit of power, not much.
I have an 09 in my 02 Forester, since a year now, I can manually activate the VVT.
Ben
Beenyboy is offline   Reply With Quote
Old 02-24-2012, 05:21 PM   #8
cloudconnects
Member#: 188777
Thanks guys great info.
Old 02-26-2012, 12:26 PM   #9
cloudconnects
Member#: 188777
What are the complications in going to a DOHC from a SOHC engine. I have found a few EJ25 DOHC motors at reasonable prices so I'd like to use one of them....
Speicifically I want to use a EJ25 DE DOHC motor in my 01 subaru legacy.
Old 02-26-2012, 12:27 PM   #10
cloudconnects
Member#: 188777
What about an EJ20 DOHC turbo?
Old 02-27-2012, 11:41 PM   #11
WoodsWagon
Member#: 180769
lots of junkers
No, you don't. It's a worse motor, less power, and blows headgaskets like clockwork. It also has piston slap issues.
If you want to do a turbo swap, you need to rewire the car and swap front crossmembers to clear the up-pipe.
WoodsWagon is offline   Reply With Quote
Old 03-15-2012, 08:37 PM   #12
cloudconnects
Member#: 188777
thanks for the info Woods, I have definitely decided against the DOHC motor.
Old 03-15-2012, 08:59 PM   #13
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Why not rebuild the engine you have? Unless its really messed up.
If you ever want to get rid of the bad parts I might be interested
Need opinions on what to do about blown engine NYHC4G63 General Community 9 04-23-2011 05:13 PM
What to do with extra suede after doing the headliner? Alan l. Interior & Exterior Modification 26 04-01-2008 08:51 PM
What to do with 93 Legacy Wagon L FWD Ostrowrx General Community 11 06-16-2007 08:31 PM
Mechanically knowledgeable but I dont wont to do the work.. what to do with $2000.00 motormojo Newbies & FAQs 15 01-14-2006 11:30 PM
What to do with a dead 1991 Legacy Turbo? armcomdes Tri-State Area Forum 9 09-25-2004 09:28 AM
Message Board Statistics All times are GMT -4. The time now is 01:57 PM.
