Old 02-23-2012, 11:29 AM   #1
Needablk07
Member#: 188216
2006 STI
Default 05 RS to 08 2.5I ECU
I found this from another forum and it is the exact swap i am currently doing and i just need a little help with some wiring. I have a 05 RS with a bad motor and I got a motor out of a 08 Impreza 2.5I that i want to swap into my 05 RS. Need help thanks you. Below was taken from other forum but explains exactly what i need help with. Thanks.
About 3 Months ago my 05 RS developed an odd little rattle. Then...the gold flecks in the oil. And for those who remember my Yellow WRX...yes, the car had oil, and yes, it was changed regularly. Anyway, After verification that it was the rod bearing I changed the engine out for an 08 2.5i engine. In most ways they are identical, however the 08's had Variable Valve Lift. The engine runs fine, however it's slightly underpowered due to the fact that the system isn't being used, and it was set up to have it. As the 05's were a change over year (had the Direct throttle body, but did not have the VVL), the question is how different is the information inlet into the 08 ECU from the 05 ECU? I'm curious as to wether all of the dash information (side plug in to the ecu)plug ins are identical, hence, if the ECU's could be swapped out with no cutting of wires. Any info would be most appreciated. Thank
Needablk07 is offline   Reply With Quote
Old 02-23-2012, 08:35 PM   #2
SplatWRX
Member#: 85932
2005 STi / 2013 STi
2005 Forester XTi
SplatWRX is offline   Reply With Quote
FS : 05 R.S DBW intake manifold.08 2.5i cylinder heads, 05 LGT manifold ..more sense of nature Engine/Power/Exhaust 12 09-08-2011 04:27 PM
What does it take to swap 04 STi rear hub to fit on my 08 2.5i? VDMTom Brakes, Steering & Suspension 5 03-26-2011 10:10 PM
anyone did any mod to there 08 2.5i?? itchymorb North West Impreza Club Forum -- NWIC 15 07-10-2008 09:27 PM
Possible to modify 08 2.5i hood to fit a scoop? AfflxnPB Interior & Exterior Modification 34 05-09-2008 03:31 PM
Questions. 08 2.5i sedan swapable to ____? AfflxnPB Subaru Conversions 5 05-06-2008 08:38 AM
