Old 02-23-2012, 01:37 PM   #1
sizzflair
Member#: 94268
1995 JDM STi RA ver2
2010 Exige S240
Default EJ20G clutch master & slave cylinder
Are the clutch master and slave cylinders the same for the EJ20G as the USDM 2.5RS ones? Thanks!
My clutch keeps getting "stuck" halfway during hard acceleration so I figured I'll replace these on top of SS clutch line.
sizzflair is offline   Reply With Quote
Old 02-23-2012, 02:05 PM   #2
eg33GC
Member#: 206851
56 Belair
Pro Street
you can use the master, but the slave is usdm turbo style. Opt for post 2003 without the relief valve
eg33GC is offline   Reply With Quote
Old 02-23-2012, 02:20 PM   #3
sizzflair
Member#: 94268
2010 Exige S240
I see.
Thanks for the info!
Old 02-24-2012, 06:26 PM   #4
69subaru360
Member#: 159682
1995 WRX
2015 F150
You need a RHD master for your car. The slave is the same as usdm wrx.
I have a good used EJ20G master/hose/slave if you want it. $40 shipped.
It came with my swap, my car is LHD I'll never use it.
Old 02-24-2012, 07:03 PM   #5
eg33GC
Member#: 206851
56 Belair
Pro Street
Op actually has a real one?
Old 02-27-2012, 08:51 PM   #6
sizzflair
Member#: 94268
2010 Exige S240
has a real what? RHD? Yea.
RHD Master is different from LHD? hmmm...
Old 02-27-2012, 11:51 PM   #7
69subaru360
Member#: 159682
1995 WRX
2015 F150
The line comes out the other side.
Old 02-29-2012, 11:52 AM   #8
sizzflair
Member#: 94268
2010 Exige S240
I see. Well I just wanted a brand new part since I won't have to worry about it giving out again anytime soon. Any idea where I could source one (new)?
Old 02-29-2012, 11:58 AM   #9
69subaru360
Member#: 159682
1995 WRX
2015 F150
You could buy from rhd japan or japan parts. If you looked up the part number on opposed forces you might be able to order it here.
One other thing you could do if you wanted to use the lhd master is replace the whole line from master to slave with braided stainless, eliminating the steel section and use a banjo fitting on the master end. That should give enough clearance.
Old 02-29-2012, 11:58 PM   #10
sizzflair
Member#: 94268
2010 Exige S240
FS : Subaru Impreza Clutch Master & Slave Cylinder lethaldose Drivetrain 14 02-11-2012 05:32 PM
'02 WRX clutch master & slave cylinder bore sizes stewgod Transmission (AT/MT) & Driveline 3 01-20-2012 05:54 PM
clutch master & slave cylinder question turbonick Transmission (AT/MT) & Driveline 7 12-04-2010 02:46 AM
FS: '02 WRX Clutch Master and Slave Cylinders Hank3 Drivetrain 6 03-01-2008 09:28 AM
WRX Clutch Master and Slave Cylinders Sherb Private 'For Sale' Classifieds 4 12-18-2005 10:12 PM
