Old 02-23-2012, 06:15 PM   #1
stealth1281
Member#: 306298
2008 STi
Default Stage 2 logs - is my car happy?
I flashed to stage 2 a week ago and took some logs today. I'd appreciate if someone would please take a look at them. They are both a 3rd and 4th gear pull.
https://docs.google.com/spreadsheet/...DhvVmdtY1FWcGc
https://docs.google.com/spreadsheet/...mlQV2ZBSERmSmc
stealth1281 is offline   Reply With Quote
Old 02-23-2012, 09:46 PM   #2
2Fast4U1DAY
Member#: 250152
2006 WRX Limited
What year and Model? Logs look good. Is this a protuned map? What is your target Boost?
A little bit of knock in the last log, but it appears to be from the throttle lift. I wouldn't be too concerned. FBKC started learning the other way so that's good.
2Fast4U1DAY is offline   Reply With Quote
Old 02-23-2012, 10:13 PM   #3
stealth1281
Member#: 306298
2008 STi
Sorry, it's a 2008 STI with catted downpipe and Cobb AP using OTS lwg stage 2 + Cobb intake. I believe the target boost is 19.5 +/- 1psi
Old 02-23-2012, 10:43 PM   #4
2Fast4U1DAY
Member#: 250152
2006 WRX Limited
Looks good!
Old 02-23-2012, 11:18 PM   #5
stealth1281
Member#: 306298
2008 STi
GREAT....thanks for taking the time to take a look at them
Old 02-26-2012, 11:18 PM   #6
AWDPWR12
Member#: 303314
lots of feedback knock at 5000rpm +, how is this good? Im new to this stuff...
AWDPWR12 is offline   Reply With Quote
Old 02-27-2012, 12:53 AM   #7
2Fast4U1DAY
Member#: 250152
2006 WRX Limited
It's not ideal, but small corrections that learn back towards maximum advance, are okay. It's when you have several knock events back to back to back and in WOT runs (ie one knock event would be -1.4 then the next -2.8, then -4.2 etc), that you should be really concened. In this case it starts off with a knock event -2.8, and starts learning the other way right away, so its okay. You also have to notice that DAM hadn't learned up to its maximum value until halfway through the first log. This tells me a recent reset or flash has occured and the ECU hasn't had an opportunity to learn Fine Knock learning corrections yet. It will clean that up so it doesn't knock by learning to automatically pull out timing in x load cells and y rpm ranges to prevent the knock events from reoccuring as often.
First Stage 2 logs - opinions please erikm Engine Management & Tuning 0 09-01-2010 10:52 PM
Cobb Stage 2 logs - not hitting boost target Drivinwest AccessPort 2 06-26-2009 10:51 AM
Cobb Stage 2 Log - Should I pull a little timing? IndyRacer Engine Management & Tuning 8 11-23-2005 10:39 AM
Stage 2 AccessECU now in my car Vegumkoho Rocky Mountains Impreza Club Forum -- RMIC 7 06-11-2003 11:28 AM
How would TXS stage 2 unichip responds to my car? WRXVII Factory 2.0L Turbo Powertrain 0 12-04-2002 01:48 AM
Message Board Statistics All times are GMT -4. The time now is 06:33 AM.
