Old 02-23-2012, 06:28 PM   #1
02MBPWRX
Member#: 310772
MBP
Default 02 Stage 1 WRX
Hello, I'm currently running stage 1 on my WRX, and in about a day or 2, im about to run stage 2 with an Invidia Turbo-back. Before I do so, I want to see if my car is running ok stage 1 before switching. I've noticed that my fine knocking learning has an instance of over -2 for a second and slightly over 0 as well. I just wanted to know if this is fine and normal.
My Mods - COBB SF Intake, and a no name Cat-back.
Edit:Sorry about that. I didn't know you had to make the link public.
https://docs.google.com/spreadsheet/...jNYSUd3SWdSYkE
02MBPWRX is offline   Reply With Quote
Old 02-23-2012, 08:11 PM   #2
LoneDubR
Member#: 253337
you need to make it public. link doesnt work currently.
LoneDubR is offline   Reply With Quote
Old 02-24-2012, 02:38 PM   #3
02MBPWRX
Member#: 310772
MBP
The link has been fixed. Can anybody please reply with some feedback? I'll be stage 2 by tomorrow. I just want to be sure that the knocking is nothing to worry about.
Old 02-24-2012, 04:17 PM   #4
2Fast4U1DAY
Member#: 250152
2006 WRX Limited
When was this flashed? Your DAM hasn't learned up yet. It's actually lower then what it should start on a reflash which tells me it knocked and DAM dropped in an effort to save the motor. How long have you driven on this flash?
Also you need to do a proper datalog. Third WOT gear pull from ~2500rpm to near redline if you can do so safely. Also make sure your AP is up to date with the latest firmware and Maps. Reset your logging parameters to default.
There is a lot of knock in that log. Something is definately not right. I wouldn't go any father until you get this sorted out. Reset the ECU, drive it around until the DAM learns up to 16, and get a datalog. If it doesn't learn up, then its seeing too much knock and is trying to save the motor.
2Fast4U1DAY is offline   Reply With Quote
Old 02-24-2012, 04:30 PM   #5
LoneDubR
Member#: 253337
correct me if i am wrong but shouldnt the throttle position % be at 100% during a pull for a proper datalog?
Old 02-24-2012, 05:10 PM   #6
2Fast4U1DAY
Member#: 250152
2006 WRX Limited
Yes. That's why I instructed him how to perform a proper datalog
Old 03-11-2012, 10:36 PM   #7
02MBPWRX
Member#: 310772
MBP
Well upon research a few days ago, I realized that I was running Cobb's v3.00 maps and not the newly revised v3.10 one. So I updated and flashed the new version. To my suprise, my DAM has been 16 ever since with no signs of knocking. After seeing that, I would recommend that everyone checks their OTS map out and make sure its the newest version. I also ran stage 2 the day after I chose to post one of my logs.
Here is one of my new data logs running stage 2. This log was the run after I had just reflashed the new v3.10 stage 2 map. I usually boost more now.
https://docs.google.com/spreadsheet/...uckc3cWc#gid=0
Can somebody please verify how my car is running right now after the stage 2 reflash? The highest boost I've hit was in 3rd gear and it was 17.5. On average I hit 17 and sometimes 16.4. Is this normal for stage 2?
Old 03-12-2012, 07:03 PM   #8
Cobb Tuning
Member#: 4803
Those logs look great! Target boost will vary on Stage 2 from 16 psi - 17 psi depending on the octane level of the gas you are using, so it sounds like you are right in this range (+/-1 psi).
Ian
06 wrx Stage 3 vs. 02 Stage 4 wrx Sypher Off-Topic 22 08-19-2006 05:42 PM
02 stage 2 wrx, wrb, MUST GO!! RoninSTI Private Vehicle 'For Sale' Classifieds 2 06-09-2004 12:51 PM
FS: 02 Stage IV WRX...I need to sell fast BlueDevil Tri-State Area Forum 20 12-17-2003 10:33 AM
FS: 02 Stage 4 WRX BlueDevil New England Impreza Club Forum -- NESIC 7 12-16-2003 01:34 PM
TN: For Sale: 02 Stage 4+ WRX, WRB, 5sp, extras Gaspipe Private Vehicle 'For Sale' Classifieds 8 08-29-2003 09:30 AM
