Old 02-23-2012, 07:33 PM   #1
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Default EQ - 06 STI, 20G - Aggressive 91 Octane Tune - 350whp/380ft-lbs!
It's always fun when a customer comes in and tells me to push the setup to the limits and beyond without caring about engine longevity. After discussing the risks and plans, this customer asked me to push 24psi on this setup. The stock engine has nearly 100k miles on it with the last ~30k running this setup at about 20psi. It was still running strong but he is planning on building it soon anyway so he wanted to see what was possible with a very aggressive tune on California 91 Octane. We went ahead with the tune and the results are pretty awesome.
Event: Custom Tune/Dyno
Ambient Temp: 70 degrees Fahrenheit
Elevation: ~100ft above sea level
Car: 2006 Subaru STI
Tuner: ED @ Equilibrium Tuning
Peak HP at RPM: 350whp @ 5900RPM
Peak Torque at RPM: 380ft-lbs @ 4500RPM
Target Boost: 24psi peak tapering to 20psi
Fuel: Cali 91 Octane
Engine/Power Modifications:
Catless TBE
EL Headers
KSTech 73mm Intake
TMIC
Five-O 850cc Injectors
EWG
Hallman MBC
Custom Tune
*** Standard Dyno Chart Disclaimer ***
This dyno reads low and should be compared to the lower reading mustang dynos. Here are some proven numbers and trap speeds for reference:
Stock 02-05 WRX - 155-165whp
Stock 04-07 STI - 210-220whp
Stock 08-11 STI - 195-205whp
265-275whp - 107-108mph traps
300-310whp - 112-113mph traps
325-335whp - 115-116mph traps
Thanks
-- Ed
Equilibrium Tuning is offline   Reply With Quote
Old 02-23-2012, 08:28 PM   #2
hunteragp
Member#: 266880
2004 WRX STi
WRB on gold
Those are great numbers for that setup and 91 Oct. Your customer doesn't want to run meth? I hope the engine lasts...
hunteragp is offline   Reply With Quote
Old 02-23-2012, 08:29 PM   #3
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
he realizes that blowing the motor could possibly cost him thousands and thousands more than if he were to build it right now?
Old 02-23-2012, 08:50 PM   #4
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
It won't cost that much more. He's already planning on using a new case and crank so no added cost as long as the heads don't take a beating. You know with the stock motor all that really happens are cracked ringlands which generally don't cause any other real harm.
-- Ed
Old 02-23-2012, 08:51 PM   #5
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Yep... its a good experiment to see how long it can hold up like this.
-- Ed
Old 02-23-2012, 08:59 PM   #6
Phatron
Member#: 36033
CEO PhatBottiTuning
send him to the track i wanna see some 118mph traps on a 91 oct 20g!
Old 02-23-2012, 09:09 PM   #7
07pearlwht
Member#: 212576
2007 impreza wrx sti
pearl white
Which 20g is this?
07pearlwht is offline   Reply With Quote
Old 02-24-2012, 12:05 AM   #8
hunteragp
Member#: 266880
2004 WRX STi
WRB on gold
-- Ed
I'm very interested in this. Please update us on the status of that engine if something happens. I would like to see how many miles it lasts! Also I would love to see what that beast does at the track! Is that a Blouch 20g?
Old 02-24-2012, 12:56 AM   #9
flycaster
Member#: 60142
2011 WRX
Grey
...on a 91 oct 20g!
Good numbers on Cali 91!
flycaster is offline   Reply With Quote
Old 02-24-2012, 12:57 AM   #10
Eisenbergs blue boo
Member#: 297902
What's the afr looking like
Eisenbergs blue boo is offline   Reply With Quote
Old 02-24-2012, 05:02 PM   #11
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
10.9-11:1
A bit leaner than I normally tune, but I kept timing pretty relaxed.
Car has been running for about 2 weeks now
-- Ed
Old 02-24-2012, 08:08 PM   #12
Boostises
Member#: 125586
2004 WRX STi
Platinum Silver Metalic
I'll be visiting you guys soon. But I want mine to last
Boostises is offline   Reply With Quote
Old 02-24-2012, 08:46 PM   #13
ArSoN9
Member#: 285777
2004 STi-
Wow great numbers Ed, Id like to see the timing tables to see how much ur holding out till redline..and how quick did you see the boost taper down to 20psi? It looks like it dropped out pretty quick, what TMIC did the customer have on?
What will go first @ 24psi and 100k+ miles, Turbo or motor?
ArSoN9 is offline   Reply With Quote
Old 02-24-2012, 09:06 PM   #14
Kastley85891
Member#: 127704
2015 Boosted Stang
MAP tuned
Great result on piss water, must have a really smart timing curve to hold that boost initially, clever tuning, bet it rips
Kastley85891 is offline   Reply With Quote
Old 02-24-2012, 11:55 PM   #15
karmasi16
Member#: 145243
2006 wrx wagon
Urban Gray Metallic
20G's are great.. I hear the Synergy turbo 20g-8cm turbos make that type of power off pump gas.
karmasi16 is offline   Reply With Quote
Old 02-25-2012, 12:55 AM   #16
ArSoN9
Member#: 285777
2004 STi-
Is this on a 20g turbo? I must have missed that post I thought this was a aggressive stock turbo tune
Old 02-25-2012, 01:18 AM   #17
Phatron
Member#: 36033
CEO PhatBottiTuning
Read title of thread
Old 02-27-2012, 02:44 AM   #18
SoCal_Scooby
Member#: 210777
Don't worry bout' it Brah
how much power was it making off the first 20psi tune?
SoCal_Scooby is offline   Reply With Quote
Old 02-27-2012, 02:12 PM   #19
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
About 325whp/330ft-lbs.
-- Ed
Old 02-27-2012, 02:12 PM   #20
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
You could only get these kinds of numbers out of the stock turbo on E85 on our dyno.
-- Ed
Old 02-27-2012, 10:19 PM   #21
ArSoN9
Member#: 285777
2004 STi-
Yeah sorry need to read the title much more closely...I knew something wasnt right when I asked the first time
Old 04-08-2012, 07:04 PM   #22
Evo_Kid
Member#: 100218
04 AW STI
04 WW EVO 8 RS
Any updates? Has this thing gone to the track yet?
Evo_Kid is offline   Reply With Quote
Old 04-08-2012, 09:53 PM   #23
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
No I heard he crashes it and broke a wheel and some suspension. Getting repaired now. The motor is still running though .
-- Ed
Old 01-28-2013, 11:39 PM   #24
subysportSTI
Member#: 207923
2006 STI paperweight
-- Ed
Ed,
Any updates? Hope this guy had better luck than me lol. A few years ago i installed a 35r/supporting mods on my 06 sti(stock longblock). Drove to CO on a limo map and dynoed 425/380 on 91. About a month later piston #3 exploded; broke through the cylinder wall, bent valves and chunks of piston in the turbo. Look me up in ppb to see pics of the carnage.
Its back up and running now with a donor motor and a 20g. Can you do an open source tune via email? Thanks
Paul
subysportSTI is offline   Reply With Quote
Old 01-28-2013, 11:49 PM   #25
achavez
Member#: 139320
2006 RA 1-4 5mt
wrx obp needs a e85 tune
Op sold the car last year shortly after. Last word on the forums its still running strong with new owner; as of a few months ago
achavez is offline   Reply With Quote
Safety benefit of non aggressive 91 octane map vs stock tune? pharmamatt AccessPort 4 02-13-2012 09:08 PM
93 octane on stage 1 91 octane tune jmikeumo AccessPort 3 10-19-2011 08:31 AM
EQ - 2006 WRX, OG FP Green, 91 Octane - 333whp, 325ft-lbs Equilibrium Tuning Proven Power Bragging 11 05-13-2011 10:10 AM
EQ - 06 STI, EQ FMIC, EQ EL Headers, ATP GT3076 - 343whp/345ft-lbs w/ in car VIDEO! Equilibrium Tuning Proven Power Bragging 34 11-05-2010 10:41 PM
91 octane tune effective for 93 octane? relliMmoT Engine Management & Tuning 8 06-26-2009 11:17 AM
