Old 02-23-2012, 10:13 PM   #1
Isoh
Member#: 292691
2012 WRX
World Rally Blue
Found additional problems, created new thread.
Isoh is offline   Reply With Quote
Old 02-23-2012, 10:50 PM   #2
2Fast4U1DAY
Member#: 250152
2006 WRX Limited
Originally Posted by Isoh
Hey everyone. I have a 2012 wrx and i believe I'm overboosting. The mods installed on the car at the moment are: Invidia N1 street catback, Invidia catted downpipe, Cobb SF intake, and Cobb Accessport. I called cobb tuning and they told me that the Invidia downpipes was known to have overboost creeps on the wrx's. Originally, i was using the ACN Stage 2 + SF intake map but i switched the the LWG version of it since i was overboosting. It seems like i'm not overboosting as much now with this map. I think i'm overboosting the most when im going 115mph+. This data log was from a 20mph roll on first gear to 120mph. The map states that: Boost targets: ~16.5psi peak boost pressure tapering down to ~12.5psi by the 7000 rpm readyline +/- 1psi. Can someone read my entire data log and tell me if my car is acting properly? Thanks in advice.
Data Log: https://docs.google.com/spreadsheet/...GMlpEamc#gid=0
First off logs are done in ONE gear, not 4. Try again. Third gear pull from 2500 to near redline if you can do so safely. Also make sure your firmware is up to date on the AP, and set your logging parameters to default.
2Fast4U1DAY is offline   Reply With Quote
Old 02-24-2012, 02:29 AM   #3
Isoh
Member#: 292691
2012 WRX
World Rally Blue
bump!
2007 WRX Cobb Stage 2 Overboosting, P0244 code, issues lancelot86 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 06-24-2012 01:31 PM
FS : RI: 2003 PSM WRX,Stage 2 *SOLD* midnitefx Private Vehicle 'For Sale' Classifieds 14 03-04-2012 11:15 AM
2012 WRX Stage 1+SF Data Logs KitKatJim AccessPort 14 02-22-2012 10:45 AM
2011 wrx stage 1 acn91 data log assist - overboosting? mattesonb AccessPort 9 02-10-2012 07:36 PM
2011 WRX Stage 2 overboosting issues Jaker AccessPort 32 02-23-2011 03:01 PM
