#26 | |
Member#: 90513
Vehicle:2003 wrx wagon black |
#27 |
Member#: 153343
Vehicle:08 SpecB QSM |
hey guys, im up here for school and ive seen a bunch of subys rollin around. looking forward to meet up with the crew up here. Also im looking for a reputable performance shop up here because im having some steering issues after my coilover install, so if anyone know one it would be much appreciated. also i drive a 08 grey spec b, think im one of the only lgts around, but that cool with me
#28 |
Member#: 131998
Vehicle:2011 DGM WRX |
Does the SCCA down here do RallyX, or is it just AutoX? I know the CNY and finger lakes ones put them on, but did not see anything for them on the SNY(?) site.
#29 | |
Member#: 234769
Vehicle:2010 WRX 4dr OBP TorquedPerformance STG2+ |
Lol, It was a joke because this "winter" has been a waste of my snow tires. I figured that if I say I should take them off that maybe we would actually get snow... Not likely!
-Evan |
#30 | |
Member#: 234769
-Evan |
#31 |
Member#: 153343
Etinder, well as i was trying to get the right front on, the axle popped out and i lost the snap ring at the end, got a new one put it on, my dads friend put the axle back in but but seemed to have done it the long way dissembling everything, I mean everything. So long story short the car pulls to the left pretty good, had the matthews subaru check out the brakes cause i thought it was a stuck caliper which they said it wasnt. Soooooo, im pretty sure than when he assmebled everything back together something went wrong.
#32 |
Member#: 153343
almost forgot, ive got a downpipe, cat back waiting at home, and a road tune from one of my friends back home
#33 |
Member#: 311794
Just done
![]() as she currently sits, plus a white fairing on the roof racks ![]() the old ride/still fast beater (no current flat black, but the vinyl is sitting behind the couch for it... ![]() i've seen another white sti/'11+ hatch on 86 a few times, anyone on here? |
#34 |
Member#: 103232
Vehicle:MY05 GDA, MY04 FXTI 2.5ltr,PPG,Front LSD,4.44 |
Sounds like he loosened the outer tierod, and now the alignment is poo. Could be other stuff but hard to say without looking for it.
The Fozzy is going down this week for wiesco pistons, manely rods, acl bearings etc refreshing my heads and a slight Port and Polish on them. Trying to keep it simple as the wrx has my hands full... |
#35 |
Member#: 153343
oh yea forgot to mention, i had the alignment done by my friend at a local toyota dealership, hes pretty knowlegable about cars, but ill get another alignment done just to be sure, anyone know of a good place to have it done?
#36 | ||
Member#: 234769
#37 | |
Member#: 98210
Vehicle:2011 SWP WRX 5 Door TorquedPerformance Stage2 |
I have a white 11 hatch ![]() you guys have any opinions on downpipe brands? |
#38 |
Member#: 103232
Its ok, still not done. needs work but its hard to find the time. should have my KW varient 3 coilovers rebuilt with custom valving. Have to swap in another 4.44 rear diff I put a cusco differential. I had it setup 2 way, but rebuilt it 1.5 way last year but didnt have a case to put it in or time. Im building a swirlpot for the trunk with a second aeromotive fuel pump.
A moderate break-in for about 1500 miles then on to E85. FYI... Fuel Injector Clinics, Z series 1680cc topfeed injectors have been recalled because they were having issues when running pumpgas. You could imagine I wasnt very happy. We have sent in a few from at work for testing. |
#39 | |
Member#: 234769
Catted or Cattless?
#40 |
Member#: 98210
well I was going to get an invidia catless but some people are saying CNT is just as good and their catted dp is only $350. I'm skeptical about cnt though.
people say catless can give you boost creep issues so that is a concern too. |
#41 |
Member#: 234769
If you want to go catted I would suggest getting a pipe with the cat as far away from the turbo so it gives the air flow to balance out and flow through the cat easier. If you want to go catless, then invidia is a great brand. I picked up a barely used Harman Motive Catted that is Grimmspeed heat coated for only $400. Catted costs more, but gives you piece of mind that you still have a cat. Catless is cheaper, but I don't see it affecting power gains until you are a high hp car.
#42 |
Member#: 103232
downpipes are for sissy's, I dont even run a exhaust!
jk.I install alot of invidia downpipes and like them for the most part. Ive worked on a few cars with the CNT downpipe and it was "ok" IMO. |
#43 |
Member#: 98210
so basically harmon motive or cobb to get the cat on the other end?
what about this thing? you keep the 2nd oem cat. http://www.daddysscp.com/product_p/mdsh08.htm |
#44 |
Member#: 234769
I'm just not so sure about the cast iron to stainless connection on the CNT compared to a full stainless steel pipe. Plus the cat is right next to the turbo.
That is correct that it's either cobb or harman motive. The cat's that are on the car are not high flow cat's, so it wouldn't be the same still. |
#45 |
Member#: 98210
#46 |
Member#: 274785
Vehicle:2011 WRX sedan silver |
I know the guys at EFI Logics (Bethel, CT) recommend Invidia DP as well as exhaust
#47 |
Member#: 98210
yeah I think I'm going to stick with invidia
#48 | |
Member#: 131998
Are there any shops that stock real fixed back "racing" seats (FIA homologated)? I want to try out a bunch before I drop the money on 2.
#49 |
Member#: 204397
Vehicle:02 WRX WRB |
I will be selling my Sti. V7 pink springs and struts with adjustable top hats.
Anyone have any idea what I should ask for them? They're in great shape. Thanks |
#50 |
Member#: 234769
For all you 08+'s I have a set of FastWRX color changing blinkers for sale. I just picked them up, but they aren't the look I was hoping for.
http://forums.nasioc.com/forums/show....php?t=2318564 |
| Thread Tools | |
| Display Modes | |
| CNY/Binghamton Area Chat | rexworx | Tri-State Area Forum | 4600 | 02-24-2012 09:38 AM |
| so who wants to do a BINGHAMTON area meet? | legacy2003 | Tri-State Area Forum | 33 | 10-03-2004 10:14 PM |
| Ithaca/Binghamton area auto-x (2nd attempt) | kiefer | Tri-State Area Forum | 6 | 10-02-2004 11:56 PM |
| binghamton area | creaquack | Tri-State Area Forum | 7 | 02-03-2004 09:01 PM |
| trans swap in binghamton area? | legacy2003 | Tri-State Area Forum | 5 | 01-05-2004 11:02 AM |
