Welcome to the North American Subaru Impreza Owners Club Monday May 25, 2015
Tri-State Area Club
Go Back   NASIOC > NASIOC Regional Areas > Tri-State Area Forum
Old 07-15-2013, 04:26 PM   #701
R L Newb
Member#: 185318
06 AW STi
13 LR BRZ
good lord do you log a lot of parameters!
Your idle looks like mine although I never get down to 0 rpm :P. Anyways, I think you're correct, the left tumble voltage reads way to constant to be working. I didn't see anything else that precludes the idle dip. may as well check for vacuum leaks while you're fixing the tgv though. Can't hurt.
If it's really water affecting it then you have a loose connector or wire that's letting it seep in and short. I advise putting the whole car in a waterproof bag; 60% of the time, it works every time
R L Newb is offline   Reply With Quote
Old 07-15-2013, 04:33 PM   #702
Celery GT-5
Member#: 98210
2015 WRX Premium 6MT
lol I was just logging all that stuff to try to find the issue. I've been looking for vac leaks, I think everything is ok but if I do the tgv delete ill definitely be able to check more thoroughly.
also ordered a couple of these like you said
actually I think maybe ill try getting a spray bottle and misting the engine to see if i can get it to misfire
Celery GT-5 is offline   Reply With Quote
Old 07-15-2013, 07:27 PM   #703
illldeca
Member#: 361233
2002 wrx
silver 01g
Hey i live in the area an im new to the forums
illldeca is offline   Reply With Quote
Old 07-15-2013, 08:13 PM   #704
R L Newb
Member#: 185318
06 AW STi
13 LR BRZ
Welcome! I'm not actually a local anymore.
Old 07-15-2013, 08:17 PM   #705
Celery GT-5
Member#: 98210
welcome
Old 07-19-2013, 09:20 AM   #706
cond
Member#: 339416
2015 STI
Welcome: D
cond is online now   Reply With Quote
Old 07-19-2013, 11:14 AM   #707
rexworx
Member#: 103232
MY05 GDA,MY04FXT6spd
2.5ltr,PPG,Front LSD,4.44
Welcome,
On a side note, Sean did I see you the other day on the BU campus? I drove through to see the newer finished buildings. I havent been up there in a long time so i figured id check it out. I thought I saw you driving one of the PD cars.
I almost gave you the finger but it prob wasnt you so good thing i didnt. lol
rexworx is offline   Reply With Quote
Old 07-20-2013, 06:57 PM   #708
cond
Member#: 339416
2015 STI
Anyone drive a red wrx? Looks to be an 05 possibly, I saw it today on vestal parkway and about 2 weeks ago on upper front st.
Old 07-20-2013, 07:14 PM   #709
illldeca
Member#: 361233
2002 wrx
silver 01g
put some wheels on my car
Old 07-20-2013, 07:15 PM   #710
iceman22
Member#: 180296
2006 STI
Originally Posted by rexworx View Post
Welcome,
Haha, it's a good thing you didn't. I won't be over there till November. The academy is 8 months long! I can't wait for the weeks to click by
iceman22 is online now   Reply With Quote
Old 07-21-2013, 10:35 AM   #711
rexworx
Member#: 103232
LOL yeah glad I didnt.
Old 07-22-2013, 11:01 AM   #712
rexworx
Member#: 103232
Just throwing this out there before I post it up for sale.
Im swapping out my 08 LGT Spec-B 6spd tranny with sti front lsd in the forester.
Im putting in a 07 sti 6spd in the next week or so.
Not giving it away, but Ill try to hook it up.. If anyone is interested in the swap I have a OEM clutch/flywheel, ACT 6puck sprung clutch/streetlight flywheel, shifter/linkage/kartboy bushings, R160 in proper 3.54FD for the specB tranny, Drive shaft, halfshafts, starter, etc etc
If anyone might be interested in the tranny or the whole swap pm me.
Ian,
Old 07-22-2013, 10:21 PM   #713
Tavery92
Member#: 312331
Sedona Red
Anyone have fog light brackets and light(s) off a bugeye they wanna sell
Tavery92 is offline   Reply With Quote
Old 07-23-2013, 09:42 PM   #714
illldeca
Member#: 361233
2002 wrx
silver 01g
Theres a yard in syracuse full of bugeyes i might go an get a front bumper. Ill let you know
Old 07-23-2013, 10:52 PM   #715
cueball89
Member#: 90513
2003 wrx wagon
black
What yard is that at?
cueball89 is offline   Reply With Quote
Old 07-24-2013, 08:22 AM   #716
rexworx
Member#: 103232
^pics or it didnt happen! lol where in cuse?
Old 07-24-2013, 05:56 PM   #717
illldeca
Member#: 361233
2002 wrx
silver 01g
webster motors has a parts car yard some used subi dealer
Old 07-28-2013, 02:14 PM   #718
cond
Member#: 339416
2015 STI
Anyone know of a reputable mechanic in the area?
Old 07-28-2013, 02:33 PM   #719
iceman22
Member#: 180296
2006 STI
What are you looking to have done?
Old 07-28-2013, 03:24 PM   #720
cond
Member#: 339416
2015 STI
I think I need a leak down test and would like to install new engine/tranny mounts In near future.
Old 07-28-2013, 03:42 PM   #721
iceman22
Member#: 180296
2006 STI
As in boost leak testing like you think you have a vacuum line loose or as in you want a compression/leakdown of the motor itself cause you think you've lost compression?
What motor and tranny mounts did you go with?
Old 07-28-2013, 03:56 PM   #722
cond
Member#: 339416
2015 STI
Thinking about getting the kartboy pitch stop, STI tranny mount 5mt, and STI groupN right and left engine mounts.also need to replace the tranny fluid with a cocktail or somthing.. starting to notice a grind when shifting into 5th I don't drive it really hard or anything so hoping replacing the fluid will help.
As for the leak down test.. My A/F Learning 1 Gets pretty high on the Access port when cruising somtimes around 5.5..always goes to 0 at WOT so maybe I'm just being paranoid and no signs of really over or under boosting
Old 07-28-2013, 06:52 PM   #723
rexworx
Member#: 103232
Well Im not sure what your thoughts are for install/ diag. I can perform a boost leak test as thats what it sounds like your talking about.
The A/F learning goes to 0 because the ecu into open loop fueling. This means there is no A/F correction and/or learning... This could mean the car "could" be running lean during wot. No you cant trust the afr1 sensor reading of 11.02 or whatever it says at wot as the sensor is very inaccurate and can not be used for monitoring during these conditions. This is why having the engine free of leaks is so important.
I can also perform a cylinder compression and leakdown/leakage tests.
Im actually already going to be up in bingo tomorrow on monday working on another customers car. Steve "Mesk8tin247" 08 forester xt sport
Ill be doing comp/leakage test and fresh sparkplugs, boost/vacuum test, timingbelt, pulleys, thermostat, and water pump. A bunch of other maintenance. Once this is done Ill be installing some parts and tuning the car.
Mod list for this round of installs before the tune "with a wideband afr gauge".
Kstech 73mm CAI, Turbo inlet pipe, Kinugawa TD06SL2-20G 8cm/2.4, STI TMIC, Grimmspeed 38mm EWG uppipe, TBE, Grimmspeed EBCS/ Hallman MBC for hybrid boost control, 800cc fuel injectors, walbro 255 fuel pump, and a underhood fuel filter conversion "getting rid of and replacing the intank fuel filter". I prob missed something but you get the picture.
If your interested in having any work done pm me and I can give you a quote... NP if your more trying to do the BBQ install day with local members sort of thing to figure it out rather then paying to have work done...
Ian,
Old 07-28-2013, 10:34 PM   #724
R L Newb
Member#: 185318
06 AW STi
13 LR BRZ
5.5% learning isn't too bad. I would think that's more of a slight boost leak than a compression/leakdown worry. Read Bad Noodles guide to tuning, it's a great overview and will help you understand what is going on with the car. Or just sit down with Ian for a couple hours and he'll talk till your ears bleed :P
but if you pay attention you'll be set.
PS: illldeca's post makes me miss my red mudflaps but going from 5 cones a run to FTD is kinda worth it....
Old 07-31-2013, 10:14 AM   #725
cueball89
Member#: 90513
2003 wrx wagon
black
Results of the 20g?
CNY/Binghamton Area Chat rexworx Tri-State Area Forum 4600 02-24-2012 09:38 AM
so who wants to do a BINGHAMTON area meet? legacy2003 Tri-State Area Forum 33 10-03-2004 10:14 PM
Ithaca/Binghamton area auto-x (2nd attempt) kiefer Tri-State Area Forum 6 10-02-2004 11:56 PM
binghamton area creaquack Tri-State Area Forum 7 02-03-2004 09:01 PM
trans swap in binghamton area? legacy2003 Tri-State Area Forum 5 01-05-2004 11:02 AM
