Mid Atlantic Impreza Club
Old 08-01-2012, 02:24 PM   #2801
MRF582
Member#: 48219
. Always drive
the race line .
Originally Posted by glhs377 View Post
whens the last time a storm rolled in? whens the last time you drove/rode something carbureted? or something with no baro reference?
just go pull 3% fuel and add 3% timing to your maps and see how it drives. the whole map. go on.
OK, I looked at the math and the altitude range is somewhere around +- 2000 feet from nominal before you start running into any practical issues. The front O2 is compensated for with atm. pressure changes. At 14.7psia there is no compensation. At 13.15psia, there is an 11% compensation. Going up in altitude will make the car run richer in Closed Loop.
To put this into perspective, typical atm. pressure of 13.1psia occurs at around 3000ft. So if doing my ECU hack, I would not drive the car anywhere with an altitude difference of +- 1500ft, just to be safe.
How much does the atmospheric pressure change by when a storm rolls in? Looks like about 3%. Less than .5AFR.
But timing really isn't affected on a SD car.
MRF582 is offline   Reply With Quote
Old 08-01-2012, 04:01 PM   #2802
glhs377
Member#: 125388
97 240hp NA GF6
giant Carbotron wing
i'm glad you changed that. we will talk later.
glhs377 is offline   Reply With Quote
Old 08-01-2012, 04:11 PM   #2803
glhs377
Member#: 125388
97 240hp NA GF6
oh yeah, better study up:
http://nationalmap.gov/ustopo/
Old 08-01-2012, 04:33 PM   #2804
saabarupp
Member#: 189032
2015 STI CWP
'12 Impreza Sport Ltd DGM
saabarupp is offline   Reply With Quote
Old 08-01-2012, 05:02 PM   #2805
The1SloR/T
Member#: 251879
1998 Neon R/T 178whp
2010 Wrx Sedan WRB
If anyone debadged and has these badges, bring them to the meet
I needs them
The1SloR/T is offline   Reply With Quote
Old 08-01-2012, 06:43 PM   #2806
isis
Member#: 73283
05 CTS-V
03 Z1000
PCBA is the assembly inside the ECU. The ECU includes the chassis, or housing. And most EE's I know call them Boards or Board Assemblies. We can see they are printed circuits and assume you can too.
isis is offline   Reply With Quote
Old 08-01-2012, 11:06 PM   #2807
Sin242
Member#: 317422
2005 sti
Guess i stumbled on the Pittsburgh crew meet tonight. I'll try and make the next one for a proper introduction and hazing.
Sin242 is offline   Reply With Quote
Old 08-02-2012, 07:45 AM   #2808
Tenacious Bee
Member#: 96452
So, what to play
with next ?
Hey! Beat it noob! Okay, that's out of the way . Welcome to the debate er ,uh thread.
Tenacious Bee is offline   Reply With Quote
Old 08-02-2012, 09:18 AM   #2809
SilverWagonRX
Member#: 76159
2006 Acura TL 6spd
Does anyone know anything about MG's? I am having thoughts about picking up an MGB GT and someday doing an engine swap of some type (LS1, F20, SR20).
SilverWagonRX is offline   Reply With Quote
Old 08-02-2012, 09:50 AM   #2810
MRF582
Member#: 48219
. Always drive
the race line .
Originally Posted by saabarupp View Post
This is hilarious!
Old 08-02-2012, 10:59 AM   #2811
MRF582
Member#: 48219
. Always drive
the race line .
https://forums.cobbtuning.com/forums...306#post661306
About the ID1000s
SOLVED!!!
Talked to Harvey @ The Boost Creep where I purchased the injectors and he wanted me to take them out and push on the pintle with a ball point pen. After that, he suggested I blow air through the injector at the pintle to ensure nothing is clogging it. He has had one other customer have the same issue I was describing. After pulling the injectors, doing this procedure on all of them, the car fired right up. Apparently, some Injector Dynamics injectors are having a stuck pintle issue. Harvey is contacting Injector Dynamics to relay the issues we are seeing, as this is causing much grief amongst his customers. I am the 3rd case in over 60 sets sold that have had this issue, so it is quite rare.
Gatdamit! Are there any injectors that always work?
Old 08-02-2012, 11:16 AM   #2812
slowgenius
Member#: 48350
04 Jackstands
Dirty PSM
Good find shek. After an injector is tested and shipped, maybe some form of corrosion is taking place before it actually gets used. Ill make sure i check mine (whenever i ever get them) first before installing them.
slowgenius is offline   Reply With Quote
Old 08-02-2012, 04:00 PM   #2813
DapRex
Member#: 53308
2004 Impreza Wrx
the bestest colour
thats no solution. worst case you pull the electronics from it, and stash it somewhere unseen, seeing it is his problem.
next step is full wire tuck:
VR6 baby! Miss my GTI some days.
DapRex is offline   Reply With Quote
Old 08-02-2012, 05:17 PM   #2814
isis
Member#: 73283
05 CTS-V
03 Z1000
Where can I dispose of a CRT television?
Old 08-02-2012, 06:01 PM   #2815
stealthx32
Member#: 30990
'93 FD3S
The city will take it under their "large item" provision. I put a couch out once and they just threw the whole thing into the compactor.
If you don't live in the city, well...put it out on some random curb in a residential area on trash day on that street.
Schedule: http://www.city.pittsburgh.pa.us/pw/...schedules.html
stealthx32 is offline   Reply With Quote
Old 08-02-2012, 09:26 PM   #2816
ForceFed2.5
Member#: 214246
05 STI OBP
14 Impreza
You can recycle tv's for free at construction junction in Point Breeze if that is anywhere near you. Just throw it in the car and drive up to one of their loading docks and tell them you have a tv to get rid of. They take it and another company picks them up later and recycles them.
http://www.constructionjunction.org/...ling-resources
I think best buy is supposed to recycle tv's for free also but i'm not sure of which size tv's they will take.
They will probably take it if you put it out for trash but i figured i would throw the recycling option out there since i try to recycle as much as possible.
ForceFed2.5 is offline   Reply With Quote
Old 08-02-2012, 10:45 PM   #2817
isis
Member#: 73283
05 CTS-V
03 Z1000
It's a non-functioning 13" CRT tv. Not reusable without effort. Not worth any effort. Thinking scrap electronics. Guess I'll call my trash company and see if they accept it. They take large stuff any trash day. I just thought TVs and electronics are a nono kind of like like old oil bottles.
Old 08-02-2012, 11:06 PM   #2818
dexterous
Member#: 23553
2005 STI - Insanity!
2014 WRX - Daily
dexterous is offline   Reply With Quote
Old 08-03-2012, 12:25 AM   #2819
The1SloR/T
Member#: 251879
2010 Wrx Sedan WRB
Do what everyone else does, take it out into a field and shoot at it. then leave it there...
I'd just dump it into a dumpster behind a walmart or something
Old 08-03-2012, 03:22 AM   #2820
yinzer_99
Member#: 124120
2006 Subaru WRX Sti
Do this. Don't worry at all about the lead and other hazardous materials in there.
yinzer_99 is offline   Reply With Quote
Old 08-03-2012, 05:57 AM   #2821
Tenacious Bee
Member#: 96452
So, what to play
with next ?
13". Just put it in the can or a garbage bag if you think they won't take it but I am certain they will. I have a 50" DLP I need to dispose of.
Old 08-03-2012, 07:55 AM   #2822
ForceFed2.5
Member#: 214246
05 STI OBP
14 Impreza
I figured it was broken. That's what they do with them. They scrap all of the parts possible out of them. They don't try to fix them. I have taken tv's, vcr's, stereo's, etc. to them.
Old 08-03-2012, 08:10 AM   #2823
Tenacious Bee
Member#: 96452
So, what to play
with next ?
My refuse company has taken every tv except the 50". My refuse company? Vieola waste services?
Old 08-03-2012, 08:18 AM   #2824
FXTSPORTS08
Member#: 232340
2008 F XT Sports
Dark Gray
+/- 1500 ft range for driving altitude will not be a viable option for me. I know a few places off of the top of my head that I drive that I am at over 3000 ft and I definitely will want to be able to drive at 0 ft.
I think my best option is to hack up one of the valves, remove the sensor and tuck it away somewhere.
FXTSPORTS08 is offline   Reply With Quote
Old 08-03-2012, 08:56 AM   #2825
Snowdog
Member#: 309541
I took a bunch of old PCs and other electronics to Westmoreland Mall. They have a company that comes in a couple times a year and recycles old electronics like that. Also Westmoreland Fairgrounds has electronic recycling a couple times a year. I'm not sure where in Pgh they have these. Try googling electronic recycling and you should get a link to local places.
Snowdog is offline   Reply With Quote
Official Pittsburgh Thread Build 4 WastingTime Mid Atlantic Impreza Club -- MAIC 8 04-26-2011 06:58 PM
Official Pittsburgh Thread v5 MRF582 Mid Atlantic Impreza Club -- MAIC 10302 10-07-2010 10:03 AM
Official Pittsburgh Thread V4 Kjott21 Mid Atlantic Impreza Club -- MAIC 10940 10-29-2009 03:16 PM
Official Pittsburgh thread V3.0 MikeCee Mid Atlantic Impreza Club -- MAIC 10519 01-11-2009 09:08 PM
Didn't there used to be an official Pittsburgh Thread? crystalhelix Mid Atlantic Impreza Club -- MAIC 0 01-08-2004 07:23 PM
