Mid Atlantic Impreza Club
Old 12-19-2012, 09:42 PM   #4026
isis
Member#: 73283
05 OBXT & CTS-V
03 Z1000
**** engineering is the most solid agreement I've had with you in a while. I cherish these moments.
isis is offline   Reply With Quote
Old 12-20-2012, 11:00 AM   #4027
Moore Performance
Member#: 231489
Originally Posted by MRF582 View Post
^LOL nice! **** engineering. I should've gotten into mergers and acquisitions... Which reminds me, I have some videotapes to return.
I agree. thats why i just acquired a dual boost domain name
Moore Performance is offline   Reply With Quote
Old 12-20-2012, 01:58 PM   #4028
glhs377
Member#: 125388
97 240hp NA GF6
giant Carbotron wing
finally some goddamned justice!
http://www.cnn.com/2012/12/18/world/...ist/index.html
inspector gadget level crooks!
glhs377 is offline   Reply With Quote
Old 12-20-2012, 04:09 PM   #4029
MRF582
Member#: 48219
. Always drive
the race line .
Jesse, question about a 4 wire MAF with pins for:
12v+
Ground
5v Signal
5v Signal Return
WTH is '5v signal return'? Is that the same thing as 'signal ground' or 'sensor ground'? If so, then why is it a separate pin from the other the ground?
MRF582 is offline   Reply With Quote
Old 12-20-2012, 04:45 PM   #4030
stealthx32
Member#: 30990
'93 FD3S
Sensor grounds are pretty common to isolate from the noise your mom kept making last night.
stealthx32 is offline   Reply With Quote
Old 12-20-2012, 04:50 PM   #4031
isis
Member#: 73283
05 OBXT & CTS-V
03 Z1000
12v+
Ground
5v Signal
5v Signal Return
Signal ground, yes. It's probably not tied to actual ground until it hits the ECU. Keeps noise off the line from the computer's perspective, and is easier to filter since its isolated from the power grounds. You can prob verify that they are connected on the ECU connector. The ground at the sensor is for the +5v supply. If you tied them at the sensor, you would probably see voltage offsets depending on signal voltage and wire temperatures and whatnot.
There's also a chance that its a differential signal and not tied to ground at all. Voltage can be measured between two nodes anywhere in a circuit and not just referenced to ground. Think of it like relative pressure vs absolute pressure.
Old 12-20-2012, 08:33 PM   #4032
MRF582
Member#: 48219
. Always drive
the race line .
Thank you! Glad to know I wasn't crazy in thinking that. So then can anyone explain this?
http://forums.bimmerforums.com/forum....php?t=1331628
Cuz the BMW folks can't...
And yeah, I fully understand that measured voltage is really just a difference in voltage between two nodes.
Old 12-21-2012, 09:35 AM   #4033
MRF582
Member#: 48219
. Always drive
the race line .
Don't let nature down, go out and punch someone!
http://news.discovery.com/human/huma...ng-121219.html
Old 12-21-2012, 10:40 AM   #4034
isis
Member#: 73283
05 OBXT & CTS-V
03 Z1000
Not sure what's left to explain?
Old 12-21-2012, 03:21 PM   #4035
MRF582
Member#: 48219
. Always drive
the race line .
Did you read that link? They're saying, the car doesn't run right until you bridge those two together in the harness... It's my understanding that it's better to keep signal ground separate from regular ground till the ECU has a chance to reference against it to keep the noise away. So grounding the two in the harness is counter-productive isn't it?
Old 12-21-2012, 04:33 PM   #4036
isis
Member#: 73283
05 OBXT & CTS-V
03 Z1000
Not always. There are 3 ways to hook up a 4-wire sensor. Ground them together at the ecu, ground them together at the sensor or don't ground them together at all. Each method has an impact on the sensor design and ecu design. Unless I'm misunderstanding the problem, you take part a from car a and replace part b on car b so you need to modify the wiring which connects part a to car b. unless part a is identical to part b or car a is identical to car b, it should be expected.
Maybe you're under the impression that one of the methods of hookup is clearly superior? I'm not sure that's the case though.
The BMW is expecting those pins to be connected at the sensor because that's how it was stock. So when you use a sensor that doesn't have them connected, you have to do it in the wiring harness. If you're asking why Porsche and BMW use different sensors, I think you'd need to ask each engineering group. I don't thing there's a good reason either way. It's probably determined by the ecu they pick.
Old 12-21-2012, 04:41 PM   #4037
glhs377
Member#: 125388
97 240hp NA GF6
MAF is in the greater scheme of sensors, a really low frequency and low precision device, and has a a pretty lame DAC step anyway you look at it, so advanced or optimal signal path techniques are wasting your time. I'm glad Jesse answered you thoroughly cause i wasn't gonna be polite with my condescension..
DACSTEP, WAIT FOR THE DROP!
Old 12-21-2012, 05:48 PM   #4038
glhs377
Member#: 125388
97 240hp NA GF6
also, MAF is for bustas!
Old 12-22-2012, 12:15 AM   #4039
MRF582
Member#: 48219
. Always drive
the race line .
Yeah, I was under that impression because of your comment about the noise being easier to filter out etc. So then follow up question, if one's going to connect power ground and sensor ground at the sensor, why bother with two separate pins, why not just have one ground pin coming out and make it a 3 wire?
What I really need to do is measure the resistance between the two grounds in the harness. If they are shorted, then it doesn't matter.
That ECU can read the MAF in increments of 0.0048828125 volts... I wouldn't call that a lame DAC step. In fact, the MAF scaling is 256 cells long. So there's a lookup table datapoint every 0.019volts or so. If you're wondering how I got to these numbers, it's a 10bit DAC. 1024 steps.
Old 12-22-2012, 12:39 AM   #4040
isis
Member#: 73283
05 OBXT & CTS-V
03 Z1000
1 Yeah, I was under that impression because of your comment about the noise being easier to filter out etc. 2 So then follow up question, if one's going to connect power ground and sensor ground at the sensor, why bother with two separate pins, why not just have one ground pin coming out and make it a 3 wire?
3 What I really need to do is measure the resistance between the two grounds in the harness. If they are shorted, then it doesn't matter.
1 I only really explained one hookup I guess. All 3 have different ways of dealing with the problems. Some hardware, some firmware. The reasons I gave were why it would be that one way. There are other reasons to do it another way. I just didn't understand which part you were unclear about.
2 Don't know why. Unless a 4 pin is just standard or more common or something.
3 Probably be all u need. Measure the harness, the ecu and the sensor to get the whole story I guess.
Old 12-22-2012, 08:17 AM   #4041
Blinden
Member#: 122993
Ex's WRX
02, 04 Sti, 12 Hatch
anyone have a set of cheap wheels, I need some winter wheels for the forester, but not really looking to spend a great deal of money.
just looking for somethign 16", 5x100. Not really interested in anything 17 inch unless it's dirt cheap.
Blinden is offline   Reply With Quote
Old 12-22-2012, 10:40 AM   #4042
isis
Member#: 73283
05 OBXT & CTS-V
03 Z1000
Your mom's dirt cheap.
Old 12-23-2012, 01:17 AM   #4043
glhs377
Member#: 125388
97 240hp NA GF6
shek, 10bit dac aint too bad. i mean.. like it matters. engines will run with.. pretty much anything thrown at them. reference rochester injection, CIS and pretty much anything pre-obd2. i just wanted to say DACSTEP! and maybe bust dan out of hiding.
Old 12-23-2012, 01:37 PM   #4044
MRF582
Member#: 48219
. Always drive
the race line .
Old 12-25-2012, 09:31 AM   #4045
ruby-ru
Member#: 44535
2003 PSM WRX
Twinscroll Goodness!
Merry Christmas!
ruby-ru is offline   Reply With Quote
Old 12-25-2012, 12:33 PM   #4046
MRF582
Member#: 48219
. Always drive
the race line .
Originally Posted by ruby-ru View Post
Merry Christmas!
Like!
Old 12-26-2012, 09:33 PM   #4047
slowgenius
Member#: 48350
WRX 03/04/07 hybrid
Whos been out in the snow?
slowgenius is offline   Reply With Quote
Old 12-26-2012, 09:35 PM   #4048
Tentonted
Member#: 303864
2008 Impreza 2.5i 5d
Been out this afternoon, first real snow in my subie, pretty impressed even with summer z rated tires, which are off as of tomorrow, lol.
Tentonted is offline   Reply With Quote
Old 12-27-2012, 12:19 AM   #4049
glhs377
Member#: 125388
97 240hp NA GF6
i got the CRV to do donuts infront of my shop?
took a few tries though.
Old 12-27-2012, 09:03 AM   #4050
isis
Member#: 73283
05 OBXT & CTS-V
03 Z1000
I've been parked. I'm fairly certain it can do donuts tho.
Official Pittsburgh Thread Build 4 WastingTime Mid Atlantic Impreza Club -- MAIC 8 04-26-2011 06:58 PM
Official Pittsburgh Thread v5 MRF582 Mid Atlantic Impreza Club -- MAIC 10302 10-07-2010 10:03 AM
Official Pittsburgh Thread V4 Kjott21 Mid Atlantic Impreza Club -- MAIC 10940 10-29-2009 03:16 PM
Official Pittsburgh thread V3.0 MikeCee Mid Atlantic Impreza Club -- MAIC 10519 01-11-2009 09:08 PM
Didn't there used to be an official Pittsburgh Thread? crystalhelix Mid Atlantic Impreza Club -- MAIC 0 01-08-2004 07:23 PM
