Welcome to the North American Subaru Impreza Owners Club Tuesday May 26, 2015
Mid Atlantic Impreza Club
Old 02-26-2013, 04:39 PM   #4526
isis
Member#: 73283
05 CTS-V
03 Z1000
Originally Posted by saabarupp View Post
Funny, that's the same impression i have about all your moms.
Shek has more than one Mom?
isis is offline   Reply With Quote
Old 02-26-2013, 04:43 PM   #4527
TimsLGT
Member#: 223739
2012 WRX
WR Blue Pearl
I'm subscribed...back in the land of turbo with my 3rd subie so I'm motivated again!
TimsLGT is offline   Reply With Quote
Old 02-26-2013, 04:44 PM   #4528
TimsLGT
Member#: 223739
2012 WRX
WR Blue Pearl
Btw...you guys are a bunch of ****
Old 02-26-2013, 09:11 PM   #4529
MRF582
Member#: 48219
. Always drive
the race line .
lolwut?
MRF582 is offline   Reply With Quote
Old 02-27-2013, 01:25 AM   #4530
glhs377
Member#: 125388
97 240hp NA GF6
giant Carbotron wing
yeah is mom is also his dad!
glhs377 is offline   Reply With Quote
Old 02-27-2013, 08:39 AM   #4531
TimsLGT
Member#: 223739
2012 WRX
WR Blue Pearl
are yinz meeting in robinson next weds?
Old 02-27-2013, 09:17 AM   #4532
MRF582
Member#: 48219
. Always drive
the race line .
yo dawg, what you got against assexual reproduction?
Timothy, yes a bunch of people will gather at the QSL there next week. Brush up on 'your mom' jokes by then!
Old 02-27-2013, 09:59 AM   #4533
MRF582
Member#: 48219
. Always drive
the race line .
Here's some more technical mumbojumbo.
These are two graphs comparing AFR at steady state on Modified (decapped) Topfeed injectors @ effective pulsewidths of 0.9ms and 1.4ms. Injector latency is about 1.0ms so actual pulsewidths are about 1.9 and 2.4ms.
X axis is in deciseconds.
Jesse, did you ever notice anything like this when you had these in your Saabaru?
Old 02-27-2013, 12:48 PM   #4534
MRF582
Member#: 48219
. Always drive
the race line .
Old 02-27-2013, 01:53 PM   #4535
isis
Member#: 73283
05 CTS-V
03 Z1000
Notice what? I'm really not sure what the graphs are supposed to be showing me. Is there something abnormal that I'm missing?
Old 02-27-2013, 02:19 PM   #4536
MRF582
Member#: 48219
. Always drive
the race line .
Yeah, the AFR scatter! Less than 0.5AFR scatter vs. almost a full 1.0AFR scatter!
Can you guess which graph feels smoother to drive?
Old 02-27-2013, 02:32 PM   #4537
bubba2533
Member#: 175483
13 WRX 5-Door
What did you change between the two?
It just seems like you had the throttle open more on the second one, which I would think would be easier to hold AFR on a higher load.
bubba2533 is offline   Reply With Quote
Old 02-27-2013, 02:43 PM   #4538
MRF582
Member#: 48219
. Always drive
the race line .
Both graphs were taken within a minute of each other changing nothing in the tune. I was trying to plot the injector response/behavior at the two different pulsewidths as indicated.
Why is that?
Old 02-27-2013, 04:21 PM   #4539
glhs377
Member#: 125388
97 240hp NA GF6
shek you're logging direct V as well? in deciseconds? would not be surprised if that was noise, or just more combustion events happening per second to "smooth" your graph over the time axis. none of that looks out of line with what i'd expect.
i also wouldn't expect a wideband to output a super smooth 5v signal either, it's probably PWM output. and the smoothing would depend on the smoothign cap and signal.
try doing high speed crank angle logging, and log combustion chamber pressure vs crank angle, and tune for that. resultant timing, AFR and EGT, hell even HP and tq are whatever they fall at.
Old 02-27-2013, 04:34 PM   #4540
isis
Member#: 73283
05 CTS-V
03 Z1000
At that low throttle angle I'd wonder if your exhaust isn't swirling around some intake valve overlap as well. You have cams and a fat, open exhaust. At super low airflow I'd guess you may see that. What's idle look like?
I haven't messed with tuning for probably two years and haven't even logged for around one so I couldn't tell you if I've ever seen that, but it's most likely because I never looked.
Old 02-27-2013, 04:38 PM   #4541
TimsLGT
Member#: 223739
2012 WRX
WR Blue Pearl
this is giving me a headache...i'm not sure why i was even trying to follow along there, thats wayyy over my head
Old 02-27-2013, 04:39 PM   #4542
TimsLGT
Member#: 223739
2012 WRX
WR Blue Pearl
...kind of like when your mom is giving me a helicopter
Old 02-27-2013, 04:40 PM   #4543
isis
Member#: 73283
05 CTS-V
03 Z1000
I'm not sure it's just data either. You wouldn't feel a capacitor smoothing a voltage signal and that's some crazy placebo effect if that were the case.
Like Kid Rock said once, if its real, you'll feel it.
Old 02-27-2013, 04:48 PM   #4544
isis
Member#: 73283
05 CTS-V
03 Z1000
One more thing to think about, is if its not smooth that's what the AFR is gonna look like. Log during clutch shudder, or dog it below 2k up a hill and plot your AFR. It may be the effect of the 'non-smoothness' and not the cause.
Old 02-27-2013, 06:57 PM   #4545
bubba2533
Member#: 175483
13 WRX 5-Door
Why is that?
Cause you could be nearing the non-linear region of the injector flow vs. pulse width curve.
Old 02-27-2013, 09:47 PM   #4546
MRF582
Member#: 48219
. Always drive
the race line .
Time scale is in deciseconds because the sample rate was about 10Hz and the x-axis is actually cell row number.
That was at ~3000RPM. That's what ~100 combustions per 10 deciseconds? If it was individual combustion peaks, you'd see that in both graphs. Also, that's the factory sensor in the factory location. Again, compare the two graphs. If both looked jagged, then I would be on board with the other theories.
Idle looks about the same, maybe slightly worse.
Winn4r! The theory is that stock injectors were never meant to be driven below 1.2ms worst case.
Old 02-27-2013, 09:50 PM   #4547
averagewhiteboy
Member#: 345877
2013 Impreza Sport
Ice Silver
Anyone selling some 11-13 WRX wheels by chance? I know no one has any 04 STI 5x100 BBS's.. lol Any other 5x100's out there?
averagewhiteboy is offline   Reply With Quote
Old 02-27-2013, 10:31 PM   #4548
bubba2533
Member#: 175483
13 WRX 5-Door
Yay, what do I win?
Old 02-27-2013, 10:57 PM   #4549
MRF582
Member#: 48219
. Always drive
the race line .
Yay, what do I win?
Old 02-27-2013, 11:04 PM   #4550
averagewhiteboy
Member#: 345877
2013 Impreza Sport
Ice Silver
Y u no share
Official Pittsburgh Thread Build 4 WastingTime Mid Atlantic Impreza Club -- MAIC 8 04-26-2011 06:58 PM
Official Pittsburgh Thread v5 MRF582 Mid Atlantic Impreza Club -- MAIC 10302 10-07-2010 10:03 AM
Official Pittsburgh Thread V4 Kjott21 Mid Atlantic Impreza Club -- MAIC 10940 10-29-2009 03:16 PM
Official Pittsburgh thread V3.0 MikeCee Mid Atlantic Impreza Club -- MAIC 10519 01-11-2009 09:08 PM
Didn't there used to be an official Pittsburgh Thread? crystalhelix Mid Atlantic Impreza Club -- MAIC 0 01-08-2004 07:23 PM
