Welcome to the North American Subaru Impreza Owners Club Sunday January 25, 2015
Mid Atlantic Impreza Club
Old 03-03-2013, 10:02 PM   #4601
d3v0
Member#: 225692
2015 WRX
Originally Posted by isis View Post
I'm sure somebody knows more than me but I'd like to see what it looks like with the original map. It worked fine till you cobb'd it. I wouldn't dismiss that. What's the BCS solenoid look like?
d3v0 is offline   Reply With Quote
Old 03-03-2013, 10:04 PM   #4602
slowgenius
Member#: 48350
0304 0712 WRX/Sti
Originally Posted by sk84fun21 View Post
I have an oem ebcs you could see if it fixes the issue, also spare waste gate.
Can't get it fixed (assuming you mean tune) if a part is broken
No i meant quit messing around and take it to a shop to have it gone over.
slowgenius is offline   Reply With Quote
Old 03-03-2013, 10:06 PM   #4603
d3v0
Member#: 225692
2015 WRX
As if we dont all burn through enough money with subarus :P
Basically it just looks like the boost target vs actual is all wrong. theres no loose vac lines, its a stock BCS, WG seems fine. its gotta be a problem with the ****ty cobb tune rather than the hardware problem, but I might end up giving you a call this week Nick to try and swap em over and see if it helps. if it ends up just being a tune problem then that makes it easy. but why not do a little due diligence before taking it to a shop?
Old 03-03-2013, 10:11 PM   #4604
slowgenius
Member#: 48350
0304 0712 WRX/Sti
Basically it just looks like the boost is all friggin wrong. theres no loose vac lines, its a stock BCS, WG seems fine. its gotta be a problem with the ****ty cobb tune rather than the hardware problem, but I might end up giving you a call this week Nick to try and swap em over and see if it helps.
Ya man if recall you dumped your sti because of a list of problems.
Old 03-03-2013, 10:12 PM   #4605
d3v0
Member#: 225692
2015 WRX
Right. which is why I have a WRX which is stock except a turboback and cobb stage 2.. - and it has a boost creep/overboost issue. not exactly a list of problems
Old 03-03-2013, 10:17 PM   #4606
slowgenius
Member#: 48350
0304 0712 WRX/Sti
Right right. An overboost can make what seems like a small problem into a catastrophic engine failure. Ask me how i know.
Old 03-03-2013, 10:18 PM   #4607
MRF582
Member#: 48219
. Always drive
the race line .
d3vo, your logs show that cutout is really working well and making a significant difference in boost response! But, it looks like the tune isn't meant for it since you're exceeding your boost target. Also, it looks like the boost control solenoid is responding faster than what the tune is expecting; so the maps that control this behavior need to be adjusted. Besides that, there is nothing else wrong. You can even tighten the wastegate arm some more and tune for it. I'd tighten it as much as possible.
It's an easy fix but if you don't want to tackle this yourself, PM me.
MRF582 is offline   Reply With Quote
Old 03-03-2013, 10:27 PM   #4608
isis
Member#: 73283
05 CTS-V
03 Z1000
It's the map. Fix the one you're using or put the one back that works.
isis is offline   Reply With Quote
Old 03-03-2013, 11:04 PM   #4609
d3v0
Member#: 225692
2015 WRX
Im gonna have shek do it
(id have already put back the one that works if I had it!)
Old 03-04-2013, 03:25 AM   #4610
glhs377
Member#: 125388
97 240hp NA GF6
giant Carbotron wing
Here is one I did last week as soon as I got the AP. third gear pull. Stupid AP doesnt log Boost target with initial settings, so I will do another log tonight with a Boost Target.
i'm working a ton but this looks pretty good to me, WRT THE BOOST. i don't see much flutter, WG is working proper in this.
IGN looks low, bouncing around, and that's a lot of KC up top. but then it's been ~ 4 years since i looked at AVCS 2.5l logs.
oh and your MAF G/sec is crazy low to my memory. looks like logs of my NA engine! hahahaha!
glhs377 is offline   Reply With Quote
Old 03-04-2013, 07:31 AM   #4611
isis
Member#: 73283
05 CTS-V
03 Z1000
Makes sense
Old 03-04-2013, 08:58 AM   #4612
d3v0
Member#: 225692
2015 WRX
Thanks alot for looking at it. I posted a few more logs via google docs at the bottom of the last page.
Old 03-04-2013, 10:35 AM   #4613
MRF582
Member#: 48219
. Always drive
the race line .
If I do it, all I'm going to do is fix the boost oscillation while keeping existing boost targets. Nothing else will be touched.
Yeah, that TD04 doesn't have much more to give in terms of MAF g/s. But yeah, the timing curve doesn't look ideal. In the 1st log he posted, it knocked twice in the 5300RPM range. The ECU has learned almost 2 degrees of learned knock from there to redline by the 4th datalog. Thankfully the Subaru knock control system is really good and this turbo is really small.
Old 03-04-2013, 03:35 PM   #4614
stealthx32
Member#: 30990
'93 FD3S
stealthx32 is offline   Reply With Quote
Old 03-04-2013, 09:09 PM   #4615
slowgenius
Member#: 48350
0304 0712 WRX/Sti
^^^^Thats why dash cams should be required in all vehicles here. Great save!
Old 03-04-2013, 11:47 PM   #4616
MRF582
Member#: 48219
. Always drive
the race line .
Old 03-05-2013, 07:49 AM   #4617
TPG Tuning
Member#: 185725
Its conistently pulling alot of timing out the top as already mentioned and the DAM is knocked down a good bit, even with boost falling off fairly hard. The timing isan't that aggressive so it might be a little lean. I would get a wideband in the exhaust to verify AFR. The boost control is a very simple fix but you have some other tuning issues that need addressed!
When I tune a customer car with a cutout I typically make a map for open and closed as it has a large effect on boost control.
If you want, email me the COBB map you are currently running and I'll make the changes for you! :-)
Nate
TPG
TPG Tuning is offline   Reply With Quote
Old 03-05-2013, 07:48 PM   #4618
imrocksolid
Member#: 344254
2011 WRX STI
Pearl White
Anyone local fabricate skid plates? I want to get one for street use. The factory one is missing from mine.
imrocksolid is offline   Reply With Quote
Old 03-05-2013, 08:07 PM   #4619
isis
Member#: 73283
05 CTS-V
03 Z1000
You mean to replace the plastic under tray below the engine? I don't think anyone local would do that but anything is possible for the right price
Old 03-05-2013, 08:10 PM   #4620
imrocksolid
Member#: 344254
2011 WRX STI
Pearl White
Yes, my car doesn't have the plastic under tray so I might as well get something that offers a bit more protection
Old 03-05-2013, 08:45 PM   #4621
Moore Performance
Member#: 231489
There are a number of products currently on the market that will do exactly what you want, that would be cheaper than a custom skid plate. Shoot us an email and I'll send you back some options and pricing.
But, if you really want we can absolutely make you a one off skid plate specifically for your car.
Moore Performance is offline   Reply With Quote
Old 03-05-2013, 09:06 PM   #4622
glhs377
Member#: 125388
97 240hp NA GF6
i would find a freinds' bmw...
Old 03-05-2013, 09:15 PM   #4623
slowgenius
Member#: 48350
0304 0712 WRX/Sti
Make two, i need one. Keep the pattern so it's no longer a one off.
Old 03-05-2013, 09:24 PM   #4624
d3v0
Member#: 225692
2015 WRX
Aaaaand it's fixed. I drove the car out to TPG Tuning so nate could do a couple ride alongs to see the problem. Nate took a look at the map for me tonight and sorted out some problems. No more overboost; there was apparently a huge like 25% error with the MAF scaling causing it to basically drive like a piece of ****. Now it's sorted and so much better. - he even fixed the tune so it won't overboost with the cutout. Boom.
Old 03-05-2013, 09:30 PM   #4625
TPG Tuning
Member#: 185725
Thanks for the kind words Josh, and nice to see you too, it's been awhile!
Nate
TPG
Official Pittsburgh Thread Build 4 WastingTime Mid Atlantic Impreza Club -- MAIC 8 04-26-2011 07:58 PM
Official Pittsburgh Thread v5 MRF582 Mid Atlantic Impreza Club -- MAIC 10302 10-07-2010 11:03 AM
Official Pittsburgh Thread V4 Kjott21 Mid Atlantic Impreza Club -- MAIC 10940 10-29-2009 04:16 PM
Official Pittsburgh thread V3.0 MikeCee Mid Atlantic Impreza Club -- MAIC 10519 01-11-2009 10:08 PM
Didn't there used to be an official Pittsburgh Thread? crystalhelix Mid Atlantic Impreza Club -- MAIC 0 01-08-2004 08:23 PM
