Mid Atlantic Impreza Club
Old 04-08-2013, 02:39 PM   #4851
MRF582
Member#: 48219
. Always drive
the race line .
Best news of the day: http://www.androidpolice.com/2013/04...-and-atrix-hd/
My phone now has an unlocked bootloader!
MRF582 is offline   Reply With Quote
Old 04-08-2013, 03:03 PM   #4852
glhs377
Member#: 125388
97 240hp NA GF6
giant Carbotron wing
arright nerd!
can you hear me now?
glhs377 is offline   Reply With Quote
Old 04-08-2013, 03:51 PM   #4853
booSTin-scoobs
Member#: 340148
2004 wrx - 18g
305whp - 282wtq
Any of you guys play hockey? Selling a basically new reebok sickkickII stiff flex, same stick Crosby and datsyuk use. Let me know if anyone wants her
booSTin-scoobs is offline   Reply With Quote
Old 04-08-2013, 03:53 PM   #4854
Blinden
Member#: 122993
Ex's WRX
02, 04 Sti, 12 Hatch
I use a mylec airflo
Blinden is offline   Reply With Quote
Old 04-08-2013, 04:03 PM   #4855
booSTin-scoobs
Member#: 340148
2004 wrx - 18g
305whp - 282wtq
Well I got this stick in the mystery pack on hockeymonkey but it doesn't flex enough for me. It's a $250 stick tho
Old 04-08-2013, 04:55 PM   #4856
Tenacious Bee
Member#: 96452
So, what to play
with next ?
Originally Posted by stealthx32 View Post
Vern, you still reading here?
I need to get in touch w/ your paintless dent guy. Thanks!
Yep, still here. Just nit checking in as much. You still need a dent guy ? My main guy has changed his model a bit and dies mostly hail damage and dealer stuff. I can call him If you like. I haven't been posting as it reminds me I have no fun car. I get to drive some at work though. Been an ATS 3.6 L as of late. 321 chp and 3400 pounds . Like an Sti or Evo hp/wt. Handles almost as good and comfy to boot.
Tenacious Bee is offline   Reply With Quote
Old 04-08-2013, 09:13 PM   #4857
glhs377
Member#: 125388
97 240hp NA GF6
i really like those ats! and there's a coupe and a wagon coming out eh?
also my s14 left today! sad/happy.
yall know where that v8 is going already!
also... now i only own cars with hatches!!
Old 04-08-2013, 09:21 PM   #4858
Tenacious Bee
Member#: 96452
So, what to play
with next ?
Yes on the coupe and hatch. 420 chp twin turbo 3.6L coming too. So....Where is the LS1 going ?
Old 04-08-2013, 09:27 PM   #4859
glhs377
Member#: 125388
97 240hp NA GF6
Vern, Vern..
something something.. in here!
Old 04-08-2013, 09:32 PM   #4860
spoonracing13
Member#: 122035
2006 TR
All of a sudden yesterday I start hitting only 10 psi or so in 3rd/4th gear. 2006 WRX VF39 Cobb 93 octane map for now. Stock BCS. Was hitting boost targets (~16psi) for weeks beforehand (setup installed like 6 weeks ago).
No obvious leaks. Checked Learning View tonight and my IAM was 0.0000
I reset the ECU and went for a short drive to see what happened. When I got back IAM went back to 1.0.
1.) Am I safe to drive it if I stay out of boost?
2.) Other than boost leak, what should I be looking at? Heatshield causing unnatural knock events, bad BCS?
spoonracing13 is offline   Reply With Quote
Old 04-08-2013, 09:59 PM   #4861
MRF582
Member#: 48219
. Always drive
the race line .
Let's hope it's false knock. If this happens again (IAM drops) though, I'd do a compression test...
Old 04-08-2013, 10:38 PM   #4862
spoonracing13
Member#: 122035
2006 TR
Had new headgaskets installed about 6 weeks ago at the same time as the VF39, STI TMIC, walbro, new fuel filter, "adjusting" of the air pump system.
I had like 21 in the knock sum for a 5 minute drive tonight. I haven't logged a lot over time but I always recall that sum being in that range for a similar drive.
Driving to WV for work in the morning, guess I'll take the laptop and periodically check the Learning View and reset ECU if the IAM drops below 0.6.
Old 04-08-2013, 11:36 PM   #4863
stealthx32
Member#: 30990
'93 FD3S
Yeah, my lower door is wrinkled. It should be fairly easy, just pop off the door panel and roll the window up and it should be right there. I'll PM you my contact info, if you could forward, it would be much appreciated!
stealthx32 is offline   Reply With Quote
Old 04-09-2013, 05:42 AM   #4864
Tenacious Bee
Member#: 96452
So, what to play
with next ?
Vern, Vern..
I have no doubt that you can do the swap. When are you starting ? Jimmy. Glad to help you out. If he can't do it i have another. Hmmmmm. Looks like typed that sentence Yoda did.
Old 04-09-2013, 06:30 AM   #4865
isis
Member#: 73283
05 CTS-V
03 Z1000
You didn't happen to fuel up at GetGo did you?
isis is offline   Reply With Quote
Old 04-09-2013, 07:40 AM   #4866
Tenacious Bee
Member#: 96452
So, what to play
with next ?
Yeah cause that crap put my car in limp mode twice before I figured it out.
Old 04-09-2013, 10:17 AM   #4867
MRF582
Member#: 48219
. Always drive
the race line .
The IAM is dropping to save your engine from detonation. And you want to reset it so it goes through all that knocking again?
Also, you really think that a knock sum of 21 is normal for a 5 minute drive?
Why the headgasket install on an 06? Seems a bit premature doesn't it?
Old 04-09-2013, 10:37 AM   #4868
explicithero
Member#: 15893
2004 STi
The color of the burgh
How can you use years as the time to do headgaskets? Maybe he has drives a lot and has put over 100k on the car. Maybe one was leaking. Why not ask these questions before assuming there wasn't a solid reason for doing it.
explicithero is offline   Reply With Quote
Old 04-09-2013, 10:52 AM   #4869
MRF582
Member#: 48219
. Always drive
the race line .
I'm not doubting there wasn't a solid reason for doing it. I suspect the engine blew its headgaskets prematurely... Subaru headgaskets (after the debacle in the late 90s) are really REALLY good.
But, fair point. So how many miles did you have on the engine when the headgaskets were replaced? Why did you get them replaced?
Also, about the knock sum, if most of it is during very low load stuff, then it's probably not an issue.
Old 04-09-2013, 11:16 AM   #4870
spoonracing13
Member#: 122035
2006 TR
125k on it. Starting overflowing the expansion tank in high boost situations. The gaskets were leaking internally. New headgaskets + ARP studs were put in.
I did fill up at GetGo in Glenshaw the other day.
I only reset the ECU last night once. Made it down 30 to Chester WV this morning with no issues. Due to the reset I think I may have hit 5psi once or twice, but generally I was trying to drive like somebody's mom.
That knock sum was right after I reset, so it was low load driving.
Planning on checking IAM when I get offsite, won't reset it until I get my hands dirty at home.
Thanks for all advice....
Old 04-09-2013, 11:32 AM   #4871
MRF582
Member#: 48219
. Always drive
the race line .
dayum Jesse and Vern, you guys called it!
Class action lawsuit? 93 octane not as advertised?
http://www.cantonrep.com/news/x14337...ffects-drivers
Looks like Giant Eagle is no stranger to fuel **** ups.
http://www.wpxi.com/news/news/local/...asoline/nPCmN/
But if the engine is tuned so much on the ragged edge that less than 1 octane point causes it to go into limp mode, then I feel that is not right for a street car.
Old 04-09-2013, 11:42 AM   #4872
isis
Member#: 73283
05 CTS-V
03 Z1000
Honestly that's the first question I ask when someone local has crap mileage, or low boost, or misfire codes. Getgo is brutal. Don't ever use them in a turbo car.
They are beyond poor quality. Poor quality will still hang your IAM in the midrange. It takes a special level of crap to get all the way to zero. I'd bet there's water or some other crap in it. I doubt it's just a single octane point.
I recommend a bottle of Heet and run it down to halfway without getting into boost. Top off at BP.
Old 04-09-2013, 12:27 PM   #4873
averagewhiteboy
Member#: 345877
2013 Impreza Sport
Ice Silver
I have never gotten gas at GetGo, and only use Sheetz gas in dire emergency. I try to stick to "real" stations.
averagewhiteboy is offline   Reply With Quote
Old 04-09-2013, 12:34 PM   #4874
isis
Member#: 73283
05 CTS-V
03 Z1000
With my car and all the data logging I did across several years, I found that BP was the most reliable around me. Sunoco was ok but not quite as good. Getgo is total crap, and sheetz was ok in the winter.
Kind of subjective, I know, but getgo was the only one that dropped my IAM consistently, Sunoco and sheetz would get the occaisional knock event that just didn't happen with BP. So I tuned it on the Sunoco, and ran BP as much as possible.
My car now will adjust itself for 89 and even 87 octane at the expense of mileage and power. I still run 93, but did try getgo once and it dropped my mileage from around 17.5 to 15.5. It's reliably crap. Avoid it.
Old 04-09-2013, 01:02 PM   #4875
MRF582
Member#: 48219
. Always drive
the race line .
I primarily use Sheetz gasoline. Sometime Sunoco cuz I like NASCAR so much.
Official Pittsburgh Thread Build 4 WastingTime Mid Atlantic Impreza Club -- MAIC 8 04-26-2011 06:58 PM
Official Pittsburgh Thread v5 MRF582 Mid Atlantic Impreza Club -- MAIC 10302 10-07-2010 10:03 AM
Official Pittsburgh Thread V4 Kjott21 Mid Atlantic Impreza Club -- MAIC 10940 10-29-2009 03:16 PM
Official Pittsburgh thread V3.0 MikeCee Mid Atlantic Impreza Club -- MAIC 10519 01-11-2009 09:08 PM
Didn't there used to be an official Pittsburgh Thread? crystalhelix Mid Atlantic Impreza Club -- MAIC 0 01-08-2004 07:23 PM
