Mid Atlantic Impreza Club
Old 05-11-2012, 09:31 PM   #1551
rjp4419
Member#: 292796
2014 STI
Originally Posted by FXTSPORTS08 View Post
Just get the toe close with some string and you will definitely be ok to drive the 15 miles. That's where my car is going and I will probably drive a lot further. I would much prefer to put a little wear on my tires for 15 miles over bad wear for the next 20k.
Very true I'm probably going to suck it up and go there
rjp4419 is offline   Reply With Quote
Old 05-11-2012, 09:39 PM   #1552
Tenacious Bee
Member#: 96452
So, what to play
with next ?
Originally Posted by yinzer_99 View Post
speaking of smoked meat... these guys were at CostCo last weekend. Yum.
http://www.traegergrills.com/
Their stuff is...okay but the Yoder stuff is way better.
Tenacious Bee is offline   Reply With Quote
Old 05-11-2012, 10:34 PM   #1553
papa_lanks
Member#: 309903
2012 STi
Every single friday night, never fails. I always pull out onto Washington road and pull to get up to speed. Granted it's still in intelligent mode so no real "racing of the engine" and not too much boost, shifting at 4k. Only done it twice but I seriously feel like I just got drunk and abused my wife. 405 miles on it, 595 to go til I won't have this problem....
Someone tell me I worry too much
papa_lanks is offline   Reply With Quote
Old 05-11-2012, 11:55 PM   #1554
The1SloR/T
Member#: 251879
1998 Neon R/T 178whp
2010 Wrx Sedan WRB
Bought the crap to make a cupcaketini for my girlfriend. Need to know how to make it! I actually called QSL and the bartender wasn't much help lol.. she just said she wings it. I can't get it to the pink thicker consistency as if we got it there.
The1SloR/T is offline   Reply With Quote
Old 05-12-2012, 12:11 AM   #1555
FXTSPORTS08
Member#: 232340
2008 F XT Sports
Dark Gray
I gave your mom something thicker.....
FXTSPORTS08 is offline   Reply With Quote
Old 05-12-2012, 02:03 AM   #1556
glhs377
Member#: 125388
97 240hp NA GF6
giant Carbotron wing
are you trying to break in the engine? the load and/at RPM are needed to get a good ring seal. miles is a great indicator for wheel bearing breakin, but i've always thought ridiculous measure for engine wear. the only thing that really "breaks in" on engines are rings and seals. seals you can give a **** about, they either leak or they don't, and as long as they're lubricated they wont really know what's spinning in them at what speed, and dont' know how much torque is being applied to the crank.
so rings then.
rings don't have an easy life, and they certainly don't just sit in their grooves and slide smoothly in the bore in perfect step with the piston. they are always spinning, have their own harmonics, and take time to settle as the compression rings are only really flat all the way around against any ring land when combustion pressure is applied. they are very dynamic, although constrained pretty well, the face is never fully supported, so:
when you put a certain combustion pressure(lets be simple and say power) on a ring at a certain acceleration(rpm), it deforms a certain amount in a certain way, and the sealing face presented to the bore is distorted a corresponding amount. yes it's microscopic. it still matters. so if you wear it to the cylinder wall (break it in) under light load conditions, then it's somewhat set in it's ways for the range of conditions the ringpack saw. now if you increase the loads or RPM, you'll just be wearing it in, in a new way, a different part of the ring face, except that will not have the rougher microstructure of the fresh cylinder wall to actually wear the ringpack in it's newer, now more deformed facial state, so it'll take a long time to do so, if it does. the difference is really only a few percent of seal, and you can't really measure it at low piston speeds like a compression or leakdown test, it only shows up in the power curve and crankcase as blowby.
a bore once smoothed, is basically a bore, mated to nothing. but a ring once broken in is ready to seal to a certain load, bore size and ring groove geometry. when they come out with high temp surface sealing coatings for rings, you'll start seeing million mile blocks with hard as hell unobtanium bores. but i doubt that'll ever be cost effective.
papa your engine is probably already broken in, so i wouldn't worry about it. rings get their seal in thousands of cycles, regardless what gears you put at that back of them.
so yeah, break it in hard. but only after the engine and oil is up to temp. i'm sure the lot attendants see to that though.
glhs377 is offline   Reply With Quote
Old 05-12-2012, 07:19 AM   #1557
papa_lanks
Member#: 309903
2012 STi
Science!
Old 05-12-2012, 07:33 AM   #1558
Tenacious Bee
Member#: 96452
So, what to play
with next ?
Science!
Old 05-12-2012, 07:59 AM   #1559
The1SloR/T
Member#: 251879
2010 Wrx Sedan WRB
knew that was coming
Old 05-12-2012, 08:05 AM   #1560
bettner12
Member#: 56179
05 LGT 407hp/372tq
Tuned by [email protected]
shake it with ice after you've put everything together, then strain that out into your glass. it should thicken it up a bit because of the lower temp.
bettner12 is offline   Reply With Quote
Old 05-12-2012, 09:04 AM   #1561
BoozeRS05
Member#: 137797
'05 LegacyGT
wagon, 5mt
^ that, shake it reeal good.
BoozeRS05 is offline   Reply With Quote
Old 05-12-2012, 11:03 AM   #1562
rjp4419
Member#: 292796
2014 STI
anyone looking for a real 07 limited lip in great condition?
Old 05-12-2012, 11:47 AM   #1563
slowgenius
Member#: 48350
WRX 03/04/07 hybrid
Originally Posted by DILLIGAF Racing View Post
Come support Subaru and Autism Society of Pittsburgh and Allegheny Valley School. To register for the event, click Here
More info on the PVGP can be found here.
Pittsburgh Vintage Grand Prix
Registered!
slowgenius is offline   Reply With Quote
Old 05-12-2012, 01:31 PM   #1564
papa_lanks
Member#: 309903
2012 STi
So who's the dude with the WRB STi hatchback that I just waved to in front of the waterworks in fox chapel? Gold rims and exhaust finishers haha
Old 05-12-2012, 03:49 PM   #1565
MRF582
Member#: 48219
. Always drive
the race line .
Originally Posted by Tenacious Bee View Post
Is it still ecu swap/hydra as the only options to run avcs ?
Well, yes, kind of. You can run AVCS with an 02/03 ECU but I think you'd have to make some electrical modifications to the ECU. Or just overnight a JDM ECU.
MRF582 is offline   Reply With Quote
Old 05-12-2012, 03:50 PM   #1566
MRF582
Member#: 48219
. Always drive
the race line .
There is an entirely separate thread dedicated to such inquiries.
Old 05-12-2012, 04:00 PM   #1567
Tenacious Bee
Member#: 96452
So, what to play
with next ?
Old 05-12-2012, 04:29 PM   #1568
papa_lanks
Member#: 309903
2012 STi
I know that. But said thread gets drowned out as it covers 3 states. Oh well. Just wondering. Newbie mistake good sir.
Old 05-12-2012, 04:39 PM   #1569
Tenacious Bee
Member#: 96452
So, what to play
with next ?
Nope, don't apologize. People post in here all the time with that. Gold exhaust tips in fox chapel. Go figure LOL.
Old 05-12-2012, 06:50 PM   #1570
papa_lanks
Member#: 309903
2012 STi
haha gold RIMS
On another note, I just noticed how incredibly poor the english on my nav system is. Turned Bluetooth off on my phone and I get a pop up saying:
"Connection to mobile phone was disconnect"
All of your grammarz are belong to me
Old 05-12-2012, 06:53 PM   #1571
stealthx32
Member#: 30990
'93 FD3S
I saw Paul on 19.
stealthx32 is offline   Reply With Quote
Old 05-12-2012, 08:56 PM   #1572
PDLTURBO
Member#: 73129
2004 WRX #50ESP
San Remo Red
Originally Posted by stealthx32
I saw Paul on 19.
You'll see me at PIRC tomorrow for the steel cities scca opener!
PDLTURBO is offline   Reply With Quote
Old 05-12-2012, 09:25 PM   #1573
MRF582
Member#: 48219
. Always drive
the race line .
I know, just wanted to see you you'd react.
Old 05-12-2012, 09:40 PM   #1574
isis
Member#: 73283
05 CTS-V
03 Z1000
Please don't react.
isis is offline   Reply With Quote
Old 05-13-2012, 06:52 AM   #1575
Tenacious Bee
Member#: 96452
So, what to play
with next ?
Damn, you have the gottaberightbouteverythings so bad that you called out your own trollness
Official Pittsburgh Thread Build 4 WastingTime Mid Atlantic Impreza Club -- MAIC 8 04-26-2011 06:58 PM
Official Pittsburgh Thread v5 MRF582 Mid Atlantic Impreza Club -- MAIC 10302 10-07-2010 10:03 AM
Official Pittsburgh Thread V4 Kjott21 Mid Atlantic Impreza Club -- MAIC 10940 10-29-2009 03:16 PM
Official Pittsburgh thread V3.0 MikeCee Mid Atlantic Impreza Club -- MAIC 10519 01-11-2009 09:08 PM
Didn't there used to be an official Pittsburgh Thread? crystalhelix Mid Atlantic Impreza Club -- MAIC 0 01-08-2004 07:23 PM
