Mid Atlantic Impreza Club
Old 06-19-2012, 12:32 PM   #2126
isis
Member#: 73283
05 OBXT & CTS-V
03 Z1000
Originally Posted by MRF582
How much does Subaru charge to do a rear wheel bearing on a GD? Or does someone local want to take on this job for some bucks? Ryan, you think Johnny 50cal would want to get into this?
I was quoted 400/side for fronts by baierl back when they were suburban Subaru. Had it done at a local shop for 300/side. Haven't killed a rear one yet.
isis is offline   Reply With Quote
Old 06-19-2012, 01:03 PM   #2127
buddsautoparts.com
Member#: 263591
2004 being rebuilt
good question!
We would charge 310.50 a side plus parts. I have done them myself, a few times... It sucks.
buddsautoparts.com is offline   Reply With Quote
Old 06-19-2012, 01:56 PM   #2128
glhs377
Member#: 125388
97 240hp NA GF6
giant Carbotron wing
oh hey, don't you still have those 5x114.3 rear hubs and knuckles?!
glhs377 is offline   Reply With Quote
Old 06-19-2012, 02:24 PM   #2129
FXTSPORTS08
Member#: 232340
2008 F XT Sports
Dark Gray
Why aren't you doing this? If you need a hand I can press in and out the bearing for you.
FXTSPORTS08 is offline   Reply With Quote
Old 06-19-2012, 02:45 PM   #2130
stealthx32
Member#: 30990
'93 FD3S
I'll lend a hammer. That's a legitimate pressing method, right?
I even have retaining compound in case you **** up the bore and need to do some creative sanding.
stealthx32 is offline   Reply With Quote
Old 06-19-2012, 02:49 PM   #2131
MRF582
Member#: 48219
. Always drive
the race line .
I do still have those 5x114 rear hubs but to make them fit I need to buy an R180 + CV shafts + rear Brembos.
I wouldn't mind doing them myself but the knuckles are unbelievably hard to remove because the long bolt that goes through it and the lateral links is seized. I broke the head off on the left side this past winter and the damn thing is so seized up, the bolt still hasn't budged even after thousands of miles of driving. I was kind of hoping it would fall off while driving.
I hate salt corrosion.
But $300 just for labor is steep. I guess I'll attempt it myself in July. might be easier to drop the entire subframe off the car so I can bang away with a 5lb sledge. Thanks for the offer to help. Hopefully I can take you up on that if I can get the knuckle separated.
LOL, thanks Jimmy.
MRF582 is offline   Reply With Quote
Old 06-19-2012, 03:15 PM   #2132
bettner12
Member#: 56179
05 LGT 407hp/372tq
Tuned by [email protected]
I wish you luck. We had to replace the whole front knuckle on matt Coles car. The splines of the axle were super seized into the hub. 8lb sledge did nothing. 32 tons on a hydraulic press did nothing. Coat the splines with some good copper or nickle based anti-skeeze on re-assembly
bettner12 is offline   Reply With Quote
Old 06-19-2012, 03:19 PM   #2133
MRF582
Member#: 48219
. Always drive
the race line .
Luckily I've had the CV shafts in and out plenty of times so those are not an issue. It's that long ass lateral link bolt. The nut side has been loosened successfully just a few months ago and put back on with anti-seize. So that'll come out again easily. i wonder if I'll have enough room to swing a hammer if I disconnect the rear struts at the bottom, remove the rear diff/axles and let the knuckle hang low like your mom's tits.
Old 06-19-2012, 03:25 PM   #2134
glhs377
Member#: 125388
97 240hp NA GF6
drop the whole subframe, that's what i had to do. you could also sawzall the bolts and drop some poly bushings in those lateral links too. torch to soften the rubber works something
amazing. chemical wrench.
Old 06-19-2012, 04:32 PM   #2135
buddsautoparts.com
Member#: 263591
2004 being rebuilt
good question!
When this happens here we use a torch and cut the bolt in half then pound the bastard out. I just did a 5x114.3 conversion on my car, used the 6gun spacer in the front and in the rear i belive you just need to press the new bearing in. and it accepts a 5x114.3 hub.
Old 06-19-2012, 04:43 PM   #2136
bubba2533
Member#: 175483
13 WRX - 03 S10
I need to do my rear wheel bearings also. Do you have a press or would you take the hub into your work?
I can bring my hub to do my own wheel bearing at my work. But it's my DD so I'd have to toss it in my book bag and ride my bike. On top of that I have never pressed a wheel bearing in and I really don't want to screw it up. All the seals and crap make me feel like I'll do something in the wrong order.
bubba2533 is offline   Reply With Quote
Old 06-19-2012, 10:29 PM   #2137
The1SloR/T
Member#: 251879
1998 Neon R/T 178whp
2010 Wrx Sedan WRB
How'd I do for it being my first time on the track and car? The other drivers were slow as balls
The1SloR/T is offline   Reply With Quote
Old 06-20-2012, 10:41 AM   #2138
FXTSPORTS08
Member#: 232340
2008 F XT Sports
Dark Gray
I just take stuff like that into work. I can go in anytime day or night and my friend/coworker that I work on cars with lives only a mile or so from the office.
Old 06-20-2012, 02:18 PM   #2139
saabarupp
Member#: 189032
2015 STI CWP
'12 Impreza Sport Ltd DGM
I haven't logged in for a while, so sorry this is so late but: CONGRATS VERN!
Also this: http://www.autoblog.com/2012/06/20/a...-review-video/
saabarupp is offline   Reply With Quote
Old 06-20-2012, 02:54 PM   #2140
glhs377
Member#: 125388
97 240hp NA GF6
adams, please tell them to stop it with the goddamned pearl white? pure white.
Old 06-20-2012, 05:14 PM   #2141
PDLTURBO
Member#: 73129
2004 WRX #50ESP
San Remo Red
It's becoming more clear that I will have to sell my wrx. I'm not sure if I should sell as is or put almost back to stock. Only parts I dont have are wheels and brakes. What do you guys think?
PDLTURBO is offline   Reply With Quote
Old 06-20-2012, 05:23 PM   #2142
glhs377
Member#: 125388
97 240hp NA GF6
i think i have brakes for you. i think that sucks, but if you don't want to sell it, try and get it appraised for as little as possible, and then buy out her half with other stuff.
edit: i got 04 wheels too. beat snows on em tho.
Old 06-20-2012, 06:00 PM   #2143
MRF582
Member#: 48219
. Always drive
the race line .
Originally Posted by The1SloR/T View Post
I Race A Scandia F2000 Racecar ( 1st Session ) - YouTube
lol, did you clutch kick it at 7:59? nice save though! and yeah the other drivers were slow as BALLS! wow.
Paul, gatdam dude! That blows! **** bitches!
Old 06-20-2012, 07:07 PM   #2144
mecpgh
Member#: 193014
02 WRX WRB, 05 STI
FPGreen E85 400+whp
You guys need a hub Shark i use to do them on the vehicle front and rears, money well spent, freeze the new bearing , heat the knuckle and life is easier.
Now i dont work on cars or live in pittsburgh
mecpgh is offline   Reply With Quote
Old 06-20-2012, 07:21 PM   #2145
FXTSPORTS08
Member#: 232340
2008 F XT Sports
Dark Gray
I'll buy it for $100 then sell it back to you for the same price when everything clears up....
Old 06-20-2012, 07:25 PM   #2146
PDLTURBO
Member#: 73129
2004 WRX #50ESP
San Remo Red
I wish that was possible.
Kbb has it as 10k to 12k with 104k for the mileage. My car has 64k on it. I'd be happy to get that.
Old 06-20-2012, 07:38 PM   #2147
glhs377
Member#: 125388
97 240hp NA GF6
time for a different car, that's a lot of time/miles to be with one chassis. time for new memories! tell me about the brake setup you have on there and how much you want to sell it for with trade for OEM WRX brakes and wheels...
what are you doing with the rollcage?
Old 06-20-2012, 09:40 PM   #2148
Blinden
Member#: 122993
Ex's WRX
02, 04 Sti, 12 Hatch
Paul: Covert late night engine swap with someone's busted engine, suddenly, car broke, and has a lot less value. Best part, easy to find busto engines in the Pittsburgh thread.
Blinden is offline   Reply With Quote
Old 06-20-2012, 10:02 PM   #2149
glhs377
Member#: 125388
97 240hp NA GF6
or just take the springs out of the coilpacks, done, runs like **** randomly. probably blown up.
Old 06-20-2012, 10:58 PM   #2150
dexterous
Member#: 23553
2005 STI - Insanity!
2014 WRX - Daily
Hey, just trade cars with me. My $hit is always busted...
dexterous is offline   Reply With Quote
Official Pittsburgh Thread Build 4 WastingTime Mid Atlantic Impreza Club -- MAIC 8 04-26-2011 06:58 PM
Official Pittsburgh Thread v5 MRF582 Mid Atlantic Impreza Club -- MAIC 10302 10-07-2010 10:03 AM
Official Pittsburgh Thread V4 Kjott21 Mid Atlantic Impreza Club -- MAIC 10940 10-29-2009 03:16 PM
Official Pittsburgh thread V3.0 MikeCee Mid Atlantic Impreza Club -- MAIC 10519 01-11-2009 09:08 PM
Didn't there used to be an official Pittsburgh Thread? crystalhelix Mid Atlantic Impreza Club -- MAIC 0 01-08-2004 07:23 PM
