Mid Atlantic Impreza Club
Old 06-29-2012, 01:22 PM   #2251
Icedtepe
Member#: 308055
1998 Impreza Outback
green
anyone here on pittspeed?
Icedtepe is offline   Reply With Quote
Old 06-29-2012, 02:11 PM   #2252
SilverWagonRX
Member#: 76159
2006 Acura TL 6spd
Pittspeed died a long time ago. I don't know where everyone from there went to instead though.
SilverWagonRX is online now   Reply With Quote
Old 06-29-2012, 02:14 PM   #2253
Tenacious Bee
Member#: 96452
So, what to play
with next ?
11th grade.
Tenacious Bee is offline   Reply With Quote
Old 06-29-2012, 02:19 PM   #2254
buddsautoparts.com
Member#: 263591
2004 being rebuilt
good question!
Originally Posted by glhs377 View Post
they only go to 30. you must be using them in a DSM!
My Target boost is 35psi. on an EJ.... OMG how dare someone use a GTX35r into it's efficiency range on a Subaru.... That is Just flucking NUTS!!!
buddsautoparts.com is offline   Reply With Quote
Old 06-29-2012, 02:32 PM   #2255
stealthx32
Member#: 30990
'93 FD3S
I agree.
Get a 4G63.
stealthx32 is offline   Reply With Quote
Old 06-29-2012, 02:34 PM   #2256
SilverWagonRX
Member#: 76159
2006 Acura TL 6spd
Originally Posted by Tenacious Bee View Post
11th grade.
Nice burn
Old 06-29-2012, 03:16 PM   #2257
MRF582
Member#: 48219
. Always drive
the race line .
Are you claiming that 35psi on a GTX35R is more efficient than 20psi? Because, you may want to learn how to read compressor maps before you do that. Of course, you can always post the compressor map and make me eat crow.
MRF582 is online now   Reply With Quote
Old 06-29-2012, 03:44 PM   #2258
MRF582
Member#: 48219
. Always drive
the race line .
Tom, I question your choice in fuel pumps. What is your power goal? A 300lpf (Supra fuel pump) should do 575hp. So if you're shooting for 500whp, why not go with the Walbro 400?
I remember we were having a conversation a while ago about 'over-building'. While I might have agreed with it at the time, I now think it's misguided. For example, let's say you want a 400whp Subaru. Should you build an 800whp and only tune it to 400? What kind of significantly different ring end gaps are you going to need for 800? How much more blow-by are you going to get at lower power levels? How much of that will 'dilute' the oil and cause you to spin bearings down the line?
Basically, in my current opinion, Just Right Engineering is better than Massive Overengineering.
You don't need an A1000 or ID2000s for 500whp. Also, too much emphasis is put on dyno numbers these days and not enough on lap times.
Old 06-29-2012, 03:50 PM   #2259
explicithero
Member#: 15893
2004 STi
white
Actually he is running E85 so he does need both, because they don't make something in the middle. Unless you think a 400lph pump and 1000cc injectors at stock fuel pressure can feed it which it you do you are dead wrong.
explicithero is online now   Reply With Quote
Old 06-29-2012, 03:55 PM   #2260
Tenacious Bee
Member#: 96452
So, what to play
with next ?
Not just wrong !!!! Dead wrong mu flukka !!!! I troll, I troll...
Old 06-29-2012, 04:00 PM   #2261
MRF582
Member#: 48219
. Always drive
the race line .
Last I spoke to him, he was not planning to use E85 but rather a combination of 93 and race gas which would lead to about 104 octane. Did you hear something different?
Also, explicithero, I bet your thought process was as follows: 'oooh, I get a chance to say something against mrf582. **** yeah, I'm pumped! I'm going to get him back for all the times in the past and really embellish my impending victory. oh man this is going to be great. he's not just wrong, he's DEAD wrong.'
Gawd, you are pathetic.
Old 06-29-2012, 04:12 PM   #2262
Tenacious Bee
Member#: 96452
So, what to play
with next ?
Why not just stick with the meth ? Is Tom of the opinion that meth is too risky without the hydra em ?
Old 06-29-2012, 04:17 PM   #2263
buddsautoparts.com
Member#: 263591
2004 being rebuilt
good question!
Who is this explicitness guy?
Old 06-29-2012, 04:18 PM   #2264
buddsautoparts.com
Member#: 263591
2004 being rebuilt
good question!
I believe he is trying to simplify the system for trouble shooting purposes.
Old 06-29-2012, 04:50 PM   #2265
isis
Member#: 73283
03 Z1000
www.subietune.com
Or just high maintenance with added potential points of failure. Even a non-daily driver can get tedious if you always have to mess with it or fix or replace things. Although I would have to say this is the first time I've ever seen Tom put effort into making something LESS complicated.
isis is offline   Reply With Quote
Old 06-29-2012, 05:30 PM   #2266
explicithero
Member#: 15893
2004 STi
white
I did notice the all caps and exclamation points emphasizing how wrong you are. Yes I did hear something different. Hence what I typed.
I guess you have me figured out, I watch and try to find ways to "get back" at you. For something you did to me at sometime in your life. I have nothing against you. I find the e-thug funny so...Get the fick over yourself.
I just know that 1000cc injectors won't supply enough E85 to support over 420whp the will barely get you to 400whp . And a 400lph pump will not supply 2250cc injectors.
Sent from phone while at stop lights... So excuse if not properly Formed diction.
Old 06-29-2012, 07:30 PM   #2267
MRF582
Member#: 48219
. Always drive
the race line .
LOL, why do you keep talking about irrelevant things? He's not going to run E85 yet you keep telling us how ID1000s won't be enough for his power goals on E85. Thank you Captain Obvious for the incredibly enlightening bit of info. Are you going to mention another painfully obvious part that isn't going to work for him?
Old 06-29-2012, 07:38 PM   #2268
buddsautoparts.com
Member#: 263591
2004 being rebuilt
good question!
Shek, You flipping idiot. You think I might know where he gets parts. So dense sometimes.
Old 06-29-2012, 11:44 PM   #2269
Tenacious Bee
Member#: 96452
So, what to play
with next ?
Power out since 7:30. Came on for like 5 minutes an hour ago then flickered back out. This sux.
Old 06-30-2012, 09:53 AM   #2270
glhs377
Member#: 125388
97 240hp NA GF6
giant Carbotron wing
probably some dude testing his huge e85 setup caused a surge.
glhs377 is online now   Reply With Quote
Old 06-30-2012, 11:29 AM   #2271
slowgenius
Member#: 48350
04 WRX
Adam, Lol at you and shek. I forget you have two identities!
Bee power back on yet? If you guys are still without and got stuff you dont want to spoil, i got a generator if your interested.
slowgenius is offline   Reply With Quote
Old 06-30-2012, 12:08 PM   #2272
slowgenius
Member#: 48350
04 WRX
Nevermind
Old 06-30-2012, 01:31 PM   #2273
Tenacious Bee
Member#: 96452
So, what to play
with next ?
Thanks slow !! Power came on about 2 am. Just discovered something about having window ac. The temp dropped to 68 degrees. I could not gt enough airflow into the house to take advantage as every bedroom and the living room has it's window plugged with an ac unit LOL!
Heat is annoying. What sux is when there is a downpour and no power for the sump pump. Fortunately it did not rain long enough to be an issue.
Old 06-30-2012, 04:07 PM   #2274
slowgenius
Member#: 48350
04 WRX
No problem. So you know i posted nevermind because a picture i was trying to post at work wasnt cooperating. I wasnt being rude.
Old 06-30-2012, 04:40 PM   #2275
Tenacious Bee
Member#: 96452
So, what to play
with next ?
Never thought that was directed to me. My plan is to get my attached to the furnace wood burner going and a generator by winter. If anyone has any generator knowledge please share. I want to run a decent portion of the house from one.
Official Pittsburgh Thread Build 4 WastingTime Mid Atlantic Impreza Club -- MAIC 8 04-26-2011 06:58 PM
Official Pittsburgh Thread v5 MRF582 Mid Atlantic Impreza Club -- MAIC 10302 10-07-2010 10:03 AM
Official Pittsburgh Thread V4 Kjott21 Mid Atlantic Impreza Club -- MAIC 10940 10-29-2009 03:16 PM
Official Pittsburgh thread V3.0 MikeCee Mid Atlantic Impreza Club -- MAIC 10519 01-11-2009 09:08 PM
Didn't there used to be an official Pittsburgh Thread? crystalhelix Mid Atlantic Impreza Club -- MAIC 0 01-08-2004 07:23 PM
Message Board Statistics All times are GMT -4. The time now is 02:48 PM.
