Mid Atlantic Impreza Club
Old 06-30-2012, 07:06 PM   #2276
slowgenius
Member#: 48350
04 Jackstands
Dirty PSM
For a whole house id look at 11 to 14 kw. Thats big for portable, around 100 bucks per kw. Would run the furnace etc. The transfer switch ads a few hundred to the price.
You can go old school and make a male to male extension cord for a smaller 6-7kw but it will only do one side of your panel unless you wire in a 220 socket. There are some pretty slick setups out now, you would have to know your approximate current load to calculate what size you need.
(Some good mom material there)
slowgenius is offline   Reply With Quote
Old 06-30-2012, 07:09 PM   #2277
slowgenius
Member#: 48350
04 Jackstands
Dirty PSM
The northern tools catalog has some decent home size portable generators on up to industrial/commercial size to give you some ideas.
www.northerntool.com
Old 07-01-2012, 07:56 AM   #2278
slowgenius
Member#: 48350
04 Jackstands
Dirty PSM
Spending the afternoon with the Governor
Old 07-01-2012, 08:42 AM   #2279
explicithero
Member#: 15893
2004 STi
The color of the burgh
I haven't been shooting for a year. I think my guns are getting rusty... Maybe I will get some time in the next few weeks to get out.... but that won't happen, need to get the car running first
explicithero is offline   Reply With Quote
Old 07-01-2012, 09:01 AM   #2280
dexterous
Member#: 23553
2005 STI - Insanity!
2014 WRX - Daily
dexterous is offline   Reply With Quote
Old 07-01-2012, 09:06 AM   #2281
dexterous
Member#: 23553
2014 WRX - Daily
Originally Posted by isis View Post
Although I would have to say this is the first time I've ever seen Tom put effort into making something LESS complicated.
Old 07-01-2012, 09:23 AM   #2282
dexterous
Member#: 23553
2014 WRX - Daily
Originally Posted by MRF582 View Post
He's not going to run E85 yet you keep telling us how ID1000s won't be enough for his power goals on E85.
Truth be told, I WILL eventually run E85 IF the car actually begins to work. E85 is not in my immediate future BUT I truly hope to start using it before the end of summer. The plan is to start it on 93oct, resolve whatever issues may be present, develop a good map for the car running on commodity 93oct fuel, finish my break-in period and validate that the car functions well as a system. Once "phase 1" has been accomplished I plan on moving to phase 2 which includes running E85. I dont intend to put the Hydra back into the car or run meth until at least next spring (if ever).
I know you have a lot more first hand experience at this BUT I do research things pretty thoroughly. While I can not cite empirical evidence, I can tell you that the following shops tell me that ID1000s will NOT support the motor/turbo combo in my car while running an acceptably safe base fuel pressure using 93oct street fuel:
Pure Tuning
Innovative Tuning
Cobb Tuning
Element Tuning
I also went so far as to call Injector Dynamics and ask them what they thought of the situation. They also feel that the ID1000s will be either to small or to close to call at high RPM/Boost on 93oct without running 75psi of base pressure. I feel that 75psi is just to much for both safety and longevity of the pumps.
Old 07-01-2012, 11:22 AM   #2283
Tenacious Bee
Member#: 96452
So, what to play
with next ?
Thanks for the info. I am hoping to get this and the wood burner sorted out by winter. Taking down a bigass tree next weekend so I will be off to a good start there.
Tenacious Bee is offline   Reply With Quote
Old 07-01-2012, 04:38 PM   #2284
MRF582
Member#: 48219
. Always drive
the race line .
Pure Tuning
Innovative Tuning
Cobb Tuning
Element Tuning
You plan to eventually put the Hydra back in the car? WTF? Haven't you learned anything in the past few years of repeated automotive failure?
I don't think 65psi base fuel pressure is 'unsafe'. Find out what injectors Mross ran to get 400whp on pure 93octane. I think they were in the 800cc range at stock fuel pressure? With enough octane, he could've easily gone north of 450whp. And you could have even bigger injectors with another 20psi of fuel pressure. How much boost do you plan to run? 30psi at the most? 95psi of fuel pressure really isn't that much. Go look at your hose and see what it's rated for. Then keep in mind there is a lot of engineering factor of safety built in.
http://www.napabeltshose.com/images/...ning_Final.pdf
Looks like the basic MPI hose you can get at Napa is rated to 180psi. 95psi of fuel pressure at 30psi of boost really isn't unsafe.
Read your build thread. Looks like you are serious about wanting to run a Hydra again. And you really don't want to run ID1000s. Consider this my resignation from any involvement in your build. Sorry, but I don't want anymore headaches than I already have. I wish you the best of luck because I really want to see your car at a track someday.
MRF582 is offline   Reply With Quote
Old 07-01-2012, 10:16 PM   #2285
dexterous
Member#: 23553
2014 WRX - Daily
Its not about the hose, I am well aware of how much pressure it can hold (many hundreds of PSI). I am concerned about the two screw-on hose ends leaking. I am also concerned about the longevity of the fuel pumps at that pressure. Granted, its unlikely to ever be an issue but its concerning none the less.
We will see how well the AccessPort works with my setup. If its all good then maybe I will just stick with it. The only real reason I went to the Hydra was to run their meth setup because E85 wasn't an option at the time.
Well, my loss I guess...
Old 07-01-2012, 10:20 PM   #2286
explicithero
Member#: 15893
2004 STi
^ I guess... Key words .
Old 07-01-2012, 11:22 PM   #2287
IDRVSLO
Member#: 194375
2015 MB GLA45
Mountain Grey
Selling my LGT if anyone knows someone who is looking.
05 LGT, 5EAT, 85k
Idles a bit low, I believe vacuum leak to be the cause. Need to sell fast.
PM me for questions
IDRVSLO is offline   Reply With Quote
Old 07-02-2012, 12:28 AM   #2288
The1SloR/T
Member#: 251879
1998 Neon R/T 178whp
2010 Wrx Sedan WRB
05 LGT, 5EAT, 85k
PM me for questions
Price?
The1SloR/T is offline   Reply With Quote
Old 07-02-2012, 09:35 AM   #2289
MRF582
Member#: 48219
. Always drive
the race line .
Oh snap, NASIOC's shutting down at 10AM EST. Get yer flames in now before it's too late!
Old 07-02-2012, 03:19 PM   #2290
stealthx32
Member#: 30990
'93 FD3S
05 LGT, 5EAT, 85k
PM me for questions
A vacuum leak should make it idle high...
stealthx32 is offline   Reply With Quote
Old 07-02-2012, 06:30 PM   #2291
isis
Member#: 73283
05 CTS-V
03 Z1000
Or just crappy. Oscillating and whatnot. It will eventually through a CEL.
isis is offline   Reply With Quote
Old 07-02-2012, 07:25 PM   #2292
IDRVSLO
Member#: 194375
2015 MB GLA45
Mountain Grey
Thanks and thanks....of course any help from local guru types is always welcome.
Old 07-02-2012, 08:33 PM   #2293
MRF582
Member#: 48219
. Always drive
the race line .
Tom, I highly recommend you let Kieth of Pure Tuning tune your car via OS or AP. Never met the guy but I really like his approach and it is very different (and correct) from 90% of the people that 'tune'.
Old 07-02-2012, 08:52 PM   #2294
ruby-ru
Member#: 44535
2003 PSM WRX
Twinscroll Goodness!
I would have to agree. He did a great job for me. I don't know if he does OS though. I had to buy an AP for my tune.
ruby-ru is offline   Reply With Quote
Old 07-02-2012, 10:06 PM   #2295
MRF582
Member#: 48219
. Always drive
the race line .
Oh yeah, he probably cheats and uses the Live Tuning option to tune each load cell on the dyno. Bastard. I have to rely on the Excel code I wrote to do the same thing on the road.
Old 07-03-2012, 09:51 AM   #2296
Moore Performance
Member#: 231489
Tom the guys are Pure are very professional, they take a lot of time during their tune and the peak power, low end torque production and driveability of the cars that we've taken there are fantastic. They also own Subaru's and they do A LOT of back to back parts testing on their cars from turbos, headers, intake manifolds, etc. Their name is also worn on many national level (winning) SCCA solo and SCCA/NASA road race cars. They have serious track experience and can tune all types from serious street cars to drag setups and they tune COBB AP, Haltec, AEM, etc. Just a bit of info, but wherever you decide to take your car, Pure or Innovative, I'm sure you will get a fantastic tune!
Moore Performance is offline   Reply With Quote
Old 07-03-2012, 09:52 AM   #2297
Moore Performance
Member#: 231489
Here one turbo test they did comparing a PTE 6262 and a BW s256. Good read.
http://pure-tuning.com/blog/?p=157
Old 07-03-2012, 05:22 PM   #2298
stealthx32
Member#: 30990
'93 FD3S
Ryan, it looks like they just picked a smaller turbo...
Definitely better suited for the application, but any joe schmo could've come to that conclusion.
Old 07-03-2012, 09:43 PM   #2299
soji
Member#: 87178
2003 Japanese Spec
Impreza STi
Been awhile since I posted in this thread. But I got pulled over tonite for an expired inspection that I have been neglecting because no cat in my exhaust and my normal inspection guy no longer can help me out(I live in south butler county so only need a visual pass). I was wondering if any one here has some one that can help me out? Or has a 2.5 in midpipe with cat that I could use temporarily this weekend?
Thanks
soji is offline   Reply With Quote
Old 07-03-2012, 09:54 PM   #2300
Kentmx25
Member#: 224544
2013 Impreza WRX
Thanks
are you looking for the stock piece because i have it all if you want to borrow it this weekend i live just a couple min north of butler but i know a guy that does inspections in sarver that doesnt care because he owns a catless legacy turbo that he inspected himself
Kentmx25 is offline   Reply With Quote
Official Pittsburgh Thread Build 4 WastingTime Mid Atlantic Impreza Club -- MAIC 8 04-26-2011 06:58 PM
Official Pittsburgh Thread v5 MRF582 Mid Atlantic Impreza Club -- MAIC 10302 10-07-2010 10:03 AM
Official Pittsburgh Thread V4 Kjott21 Mid Atlantic Impreza Club -- MAIC 10940 10-29-2009 03:16 PM
Official Pittsburgh thread V3.0 MikeCee Mid Atlantic Impreza Club -- MAIC 10519 01-11-2009 09:08 PM
Didn't there used to be an official Pittsburgh Thread? crystalhelix Mid Atlantic Impreza Club -- MAIC 0 01-08-2004 07:23 PM
