Old 02-24-2012, 02:17 PM   #1
SubieCrack
Member#: 225426
2007 Subaru WRX
Metallic Silver
Default HEP>>Blown Seal
Since I didn't get any replys I am posting again, PLEASE HELP!
My 07' Subaru WRX has 65,000 miles on it. I have been known to do a tad bit more spirited driving then most others. While I was gone the oil got so low that you could hear the ticking noise. Recently I had your every day oil change performed and a diagnosics check done. It was found that my oil pan and oil cooler were leaking due to bad seals. The car was backed into a ditch by my father and it partially (not bad at all) kinked the exhaust in the back end right behind the silencer. My question is what could have been the cause for the bad seals? The exhaust or the low oil? Just wondering if I should replace the exhaust or not. Any POSITIVE feedback would be appreciated.
SubieCrack is offline   Reply With Quote
Old 02-26-2012, 10:27 AM   #2
tom bauer
Member#: 310141
does it really matter why? if it leaks, fix it so it does not get low on oil again. heat and age are the main causes of seals failing so yours may not be abnormal.
tom
tom bauer is offline   Reply With Quote
Old 02-28-2012, 12:41 PM   #3
ojala
Member#: 255441
05 Saabaru
I guess I can address these in order for what it is worth (not much)
1. bad seals are cause by heat, age, and well...the seals being bad
2. its possible low oil exacerbated the problem, but see #1 for likely causes
3. replace exhaust if you want, but you will need some other excuse to justify the purchase because it has nothing to do with the leaks or seals
4. I am positive
ojala is offline   Reply With Quote
Question about a wheel bearing seal / axle seal anon_az Transmission (AT/MT) & Driveline 0 03-17-2010 05:59 PM
using seal puller on cam seals 98tredsvt Service & Maintenance 4 11-11-2009 03:52 PM
Any difference between STi valve stem seals and 2.0L WRX valve stem seals? CoolRex Built Motor Discussion 3 10-02-2009 10:57 AM
VF39 BAD SEALS? What are the reccuring effects of bad seals in a turbo? Drewbaru04 North West Impreza Club Forum -- NWIC 2 05-16-2009 11:50 PM
FS: ej25 water pump/cam seals/oil pump seals/timing belt cover gaskets sti charles Engine/Power/Exhaust 24 11-02-2008 02:10 PM
