Closed Thread
Old 02-24-2012, 03:34 PM   #1
zosozoso
Member#: 283924
2007 Impreza 2.5I
cgm
Default 61k this is what im doing *list* plz add to it
So i am about to hit 61,000 miles and i need to do the so called 60,000 service maintenance This is what ill be working on... Plz let me know if this is a good start or if i should do more!
- Change oil and oil filter(synthetic and k&N oil filter)
-Change fuel filter(??)
-Change air filter(k&N)
-Change brake pads and rotors(Brembo blanks and pads???)
-Change Tranny Fluid(???)
-Change Differential fluid(???)
-Change Spark Plugs(???)
-Change Brake fluid(???)
-Change Engine Coolant(???)
-???DRIVE BELT??????
Plz help me fill in the question marks with brands you guys think i should use or are reliable. The ones lables in red are the ones i am going to have to take the car somewhere to have done. Let me know if you think any of the red ones are easy to do? Also i am not sure if i need to change the drive belt, let me know what you guys think and thanks for all the help. I hope this is a pretty good start on basic maintenance.
zosozoso is offline
Old 02-24-2012, 05:31 PM   #2
Big-E
Member#: 123843
2006 SGM WRX S2
Let LED's light your way!
Synthetic engine oil: 5w30 weight; Pennzoil
Oil filter: OEM
Air filter: OEM
Brake rotors: Brembo blanks are fine
Brake pads: OEM or OEM equivalent from NAPA, CarQuest, etc.
Automatic transmission fluid: Subaru
Automatic transmission filter: Subaru or Wix or CarQuest or NAPA
Front differential (if you have an automatic transmission) 80w90 weight - you don't need synthetic
Front differential (if you have a manual transmission) 75w90 weight - you don't need synthetic. If however it is shifting heavy or notchy shifting, then consider Motul Gear300 synthetic 75w90 gear oil
Rear differential: 75w90 weight - you don't need synthetic
Spark plugs: NGK; you don't need to go to the dealer; you can get them from NAPA, CarQuest, Auto Zone, etc.; you don't need double platinum
Brake fluid: DOT-4; any brand
Clutch fluid (if you have a manual transmission) DOT-4; any brand
Engine coolant: Subaru (non-premix) and distilled or deionized water (not tap water) - one gallon each
Coolant additive: if recommended in Owner's Manual: Subaru - one bottle
Belts (2): Alternator & Power steering; Air Conditioner: OEM or Gates
Power steering fluid: Dexron VI
Fuel filter: may be in tank; if so, it's not a readily servicable item and is supposed to be a 'lifetime' item (I say 100k miles)
Big-E is offline
Old 02-24-2012, 07:27 PM   #3
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
Unabomber is offline
Closed Thread
WTB/WTT : This Is What Im Looking For thatsoobguy Private 'Wanted' Classifieds 7 07-06-2011 11:21 PM
This is what i hear..........listen Dr. octagon Factory 2.0L Turbo Powertrain 19 12-06-2010 10:10 PM
The Im bored and this is what im watching thread vapore0n Off-Topic 6 01-18-2007 10:56 PM
This is what you're doing Sunday, Sept. 24th. Yes it is. mav1c Mid Atlantic Impreza Club -- MAIC 18 09-11-2006 11:10 AM
this is what you do when you cant sleep and your car is broke Donnie Mid West Subaru Owners Club Forum -- MWSOC 4 01-20-2002 08:11 AM
Message Board Statistics All times are GMT -4. The time now is 02:06 AM.
