Old 02-24-2012, 07:34 PM   #1
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Default EQ - Stage 2 06 STI before/after Tomei EL Headers/UP
I had the opportunity for a good back to back test with the Tomei EL Headers/UP. This is an 06 STI with basic stage 2 mods and is even catted. The results are what I generally expect, but its nice to see it on the same car with nothing else changed. What did surprise me was absolutely no loss in spool .
Event: Custom Tune/Dyno
Ambient Temp: 70 degrees Fahrenheit
Elevation: ~100ft above sea level
Car: 2006 Subaru STI
Tuner: ED @ Equilibrium Tuning
Peak HP at RPM: 295whp @ 5450RPM
Peak Torque at RPM: 341ft-lbs @ 3750RPM
Target Boost: 19.5psi peak
Fuel: Cali 91 Octane
Engine/Power Modifications:
Cobb Catted TBE
Cobb SRI with box
DW850cc Injectors
Walbro
Hallman MBC
Custom Tune
Tomei EL Headers + UP Wrapped
Blue is all mods with stock headers/UP, red is with headers/UP
*** Standard Dyno Chart Disclaimer ***
This dyno reads low and should be compared to the lower reading mustang dynos. Here are some proven numbers and trap speeds for reference:
Stock 02-05 WRX - 155-165whp
Stock 04-07 STI - 210-220whp
Stock 08-11 STI - 195-205whp
265-275whp - 107-108mph traps
300-310whp - 112-113mph traps
325-335whp - 115-116mph traps
Thanks
-- Ed
Equilibrium Tuning is offline   Reply With Quote
Old 02-24-2012, 07:42 PM   #2
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
exactly what i saw. headers are great on 91oct.
Old 02-24-2012, 08:36 PM   #3
ArSoN9
Member#: 285777
2004 STi-
that is a really nice gain for the stock turbo..Id figure these headers only showed much gain when you were on a larger turbo that increased the flow demanded.
I would like to see a side by side with E85 and Stage 2 mods with the Tomei EL headers
ArSoN9 is offline   Reply With Quote
Old 02-25-2012, 10:31 AM   #4
424wrx
Member#: 171948
08 wrx stg3 vf52
14 legacy, 11 fozzy
nice. i have ,tomei el headers and uppipe staring at me in my living room. i have to wrap them this weekend.
424wrx is offline   Reply With Quote
Old 02-27-2012, 06:36 PM   #5
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
I'd love to see that too but I haven't had the chance to do this comparison yet.
-- Ed
Old 02-27-2012, 06:37 PM   #6
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
I'd imagine we would see similar gains on 93 octane. Have you seen otherwise?
-- Ed
Old 10-25-2013, 11:31 PM   #7
ShinjiML
Member#: 257231
2011 STI
I know this is an old thread, but I'm thinking about getting the Tomei EL headers and was just wondering if you have the boost curves? I've been reading about how it'll cause a slightly slower spool.
ShinjiML is offline   Reply With Quote
Old 10-26-2013, 03:48 AM   #8
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
Still wondering about the spool?
Originally Posted by Equilibrium Tuning View Post
I had the opportunity for a good back to back test with the Tomei EL Headers/UP. This is an 06 STI with basic stage 2 mods and is even catted. The results are what I generally expect, but its nice to see it on the same car with nothing else changed. What did surprise me was absolutely no loss in spool .Event: Custom Tune/Dyno
Cobb Catted TBE
Cobb SRI with box
DW850cc Injectors
Walbro
Hallman MBC
Custom Tune
Thanks
-- Ed
Old 10-26-2013, 09:55 AM   #9
ShinjiML
Member#: 257231
2011 STI
Yeah, I saw that the first time, but that was hard to believe, so I had to ask if he had the boost curve to prove it Even after looking at it a few times now, I still find that pretty amazing.
Old 10-26-2013, 11:03 AM   #10
bilt2run
Member#: 134211
I recently removed my ported gs manifolds and installed a invidia race elh on my 07 sti "1.5xtr 10cm-e85, and lost 250rpm of spool and the car actually feels slower but picked up power on the dyno from about 5k on up.
No matter what we tried it wasnt getting it back at the bottom end..
bilt2run is offline   Reply With Quote
Old 10-26-2013, 06:47 PM   #11
ShinjiML
Member#: 257231
2011 STI
EQ's dyno plot shows gains over the whole powerband, hopefully I can see that on my car!
Old 10-27-2013, 11:24 AM   #12
STi Mikey
Member#: 114631
2009 GTR, 735whp
13' Benz, 15' WRX
-- Ed
On 91 octane I am able to add some timing to cars. Lowering the EGTs with the EL header really helps utilizing 91 octane. Cars using a quality EL header on 93 do pick up a little power, but more so massive amounts of torque. I typically keep ignition the same on 93 (header / no header) or even take a half degree out in some cases to add some safety.
-Mikey
STi Mikey is offline   Reply With Quote
Old 10-27-2013, 05:38 PM   #13
BroBroBroBroBro
Member#: 338211
2011 wrx
not to thread jack but that graph looks similar to my stage 2 when i added a frontmount and ewg. tapers to around the same but midrange meat is better.
im about to add equal header and see the further gains. hoping to get back the 300rpm spool i lost from the frontmount piping.
BroBroBroBroBro is offline   Reply With Quote
Old 10-30-2013, 11:49 AM   #14
Illusive
Member#: 90436
2005 STI
Obsidian black pearl
Thanks
-- Ed
Before and after were at the same boost level?
Illusive is offline   Reply With Quote
Old 11-03-2013, 07:26 PM   #15
jhayesvw
Member#: 326502
2003 WRX Wagon
hmm. I need some header work on my 03. I would LOVE to pick up some low end torque.
jhayesvw is offline   Reply With Quote
Old 11-20-2013, 10:34 AM   #16
ShinjiML
Member#: 257231
2011 STI
Quick update, I've installed the EL header on my 11 STI and even before adjusting the tune, I can confirm that there was no loss of spool and the car felt a bit torquier in the lower mid range. Now I'm in the process of having Mikey retune my car and after just 2 revisions, the car pulls so much harder with full boost around 3200 rpm, at which point the car just lunges forward.
Sound-wise, the car is probably 30% quieter. I have a Perrin catted TBE, which I felt was a bit on the loud side and also droned a bit, but the EL header has decreased the noise to a much more comfortable level and improved the droning considerably as well. The boxer rumble is 70% gone and I have to listen hard to hear the remaining rumble, but IMO, the overall performance gains are worth it. The car feels good!
Old 11-29-2013, 08:51 AM   #17
tekfoc
Member#: 21392
2014 45 AMG MB
WHITE /MB C300 4MATIC
Just purchased the tomei equal length headers .
I'm glad to see boost was not compromised with the tomei header .
Looking forward to getting massive torq increase with the tomei .
tekfoc is offline   Reply With Quote
Old 11-30-2013, 04:43 PM   #18
nevin95 LSi
Member#: 219571
'02 wrx wagon 288k+
'95 SVX ebony mica
I have a gtspec el header, not a tomei, but I also love my el header. I recommend them to everyone.
I honestly don't know why anyone would ever even consider an uel header.
nevin95 LSi is offline   Reply With Quote
Old 12-01-2013, 01:54 AM   #19
LTlink
Member#: 347312
2007 STI
I chose to do the UEL header, has a nice rumber and got great results.
Had tuned at PRE racing in Portland, OR.
309.7 AWHP
355 Torque
Mods:
Tomioko UEL header- wrapped
Tomioko up pipe
Turbo XS TBE
Injen CAI
Tune
Car feels and sounds great, I really doubt an EL header would have given me much better results and love the rumble
LTlink is offline   Reply With Quote
Old 01-01-2014, 02:41 PM   #20
ShinjiML
Member#: 257231
2011 STI
309.7 AWHP
355 Torque
Mods:
Tomioko up pipe
Turbo XS TBE
Injen CAI
Tune
Yeah, well designed UEL headers seem to produce similar gains to EL headers. My reason for going EL was for engine efficiency, although I do miss the rumble.
Old 01-01-2014, 03:49 PM   #21
tekfoc
Member#: 21392
2014 45 AMG MB
I don't miss it .
I absolutely love how it sounds now . when you open it up all the way it sounds like a very high end car .
Old 04-07-2015, 04:37 AM   #22
Slamfan4life
Member#: 371774
back from the dead!
has anyone done tomei elh+up pipe on 91/93 then compare to e85?
would be awesome if anyone did side by side! 91/93 vs E85, both w/ stock turbo, stock block, stage 2
Slamfan4life is offline   Reply With Quote
2.0L VF22: before/after Gt Spec Header Subian Proven Power Bragging 42 02-10-2011 01:57 PM
2011 Subaru STI stage 2 plus intake. Before/After intake test. Innovative Tuning Proven Power Bragging 25 01-08-2011 09:13 PM
Stage 2 06 STi - 294WHP / 320WTQ tuned by Harman Motive Marcus K Proven Power Bragging 41 09-08-2007 05:11 PM
comparison, stock buggy 07 Sti vs Stage 2 06 Sti Xeno AccessPort 2 03-24-2007 06:28 PM
First Stage 2 06 STI ev4R? RainMaker North West Impreza Club Forum -- NWIC 7 10-04-2005 11:15 AM
