Alaskan Impreza Club
Old 02-24-2012, 07:45 PM   #1
cosseywrx
Member#: 276443
2005 2.1 stroker WRX
Default All CYCl misfiring
how do you get all cycl misfiring on pre-gapped NGK plugs?
i need help!
cosseywrx is offline   Reply With Quote
Old 02-24-2012, 07:48 PM   #2
cosseywrx
Member#: 276443
Powertrain Diagnostic Trouble Code Information
MIL DTC
P0303 Cylinder 3 Misfire Detected
Stored Codes
P0301 Cylinder 1 Misfire Detected
P0302 Cylinder 2 Misfire Detected
P0304 Cylinder 4 Misfire Detected
Pending Codes
P0171 System To Lean Bank 1
Freeze Frame Infomation
Parameter Description Results
DTC for which Freeze Frame was Stored P0303
Fuel System 1 Status Closed Loop
Fuel System 2 Status Not Supported
Calculated LOAD Value 3.14 %
Engine Coolant Temp 156.20 F
Short Term Fuel Trim - Bank 1 25.00 %
Long Term Fuel Trim - Bank 1 0.78 %
Intake Manifold Absolute Pressure 17.17 inHg
Engine RPM 1,078.00 rpm
Vehicle Speed Sensor 0.00 mph
Ignition Timing Advance #1 Cylinder 16.00
Intake Air Temperature 42.80 F
Air Flow Rate Mass Air Flow Sensor 0.81 lb/min
Absolute Throttle Position 10.98 %
Oxygen Sensor Output Voltage (B1-S2) 0.00 V
Short Term Fuel Trim (B1-S2) -0.78 %
Old 02-24-2012, 07:53 PM   #3
AK SloPok
Member#: 56464
12 Ram
crank sensor?
AK SloPok is offline   Reply With Quote
Old 02-24-2012, 07:55 PM   #4
coldfiremx
Member#: 285848
Check your MAF sensor.
coldfiremx is offline   Reply With Quote
Old 02-24-2012, 07:58 PM   #5
cosseywrx
Member#: 276443
both plugged in. gonna pull plugs and check gaps...start there i guess.....030 or 045? cant remember..
Old 02-24-2012, 08:00 PM   #6
cosseywrx
Member#: 276443
.030 it is
Old 02-24-2012, 08:24 PM   #7
Marlons101
Member#: 137569
WRX Twinscroll
Dez in yo mouth!
So what exactly is new on this engine.
What was wrong with it before.
Marlons101 is offline   Reply With Quote
Old 02-24-2012, 08:25 PM   #8
Alaskan EJ20
Member#: 160040
2002 Bugi / 1993 L
Symmetry Tuning
coil pack plugs: white plugs go toward the front black in the back on both sides
Alaskan EJ20 is offline   Reply With Quote
Old 02-24-2012, 08:26 PM   #9
Alaskan EJ20
Member#: 160040
2002 Bugi / 1993 L
Symmetry Tuning
id gap to .028 also just to be safe
Old 02-24-2012, 08:31 PM   #10
wuuusaa
Member#: 92894
2015 Wrx
I say maf as well, I know running your car with no maf isn't good at all.
Old 02-24-2012, 08:39 PM   #11
cosseywrx
Member#: 276443
everything is on the car that needs to be on for it to run correctly. Do yall just use the generic round gapper or a feeler gauge
Old 02-24-2012, 08:47 PM   #12
Marlons101
Member#: 137569
WRX Twinscroll
Dez in yo mouth!
Are your rings good?
These plugs are new I take it Also.
Old 02-24-2012, 08:53 PM   #13
Alaskan EJ20
Member#: 160040
2002 Bugi / 1993 L
Symmetry Tuning
check your wire harness, cam sensor and crank sensor,
Old 02-24-2012, 08:53 PM   #14
Marlons101
Member#: 137569
WRX Twinscroll
Dez in yo mouth!
Are those new injectors in there sealed properly? Orings crap out a lot of times when not lubed properly...
Old 02-24-2012, 09:27 PM   #15
cosseywrx
Member#: 276443
Orings are new and plenty lubed. New plugs. Gaps were perfect on them no leaks. All wire harness **** is good. Will double check in a bit. Idk lost
Old 02-24-2012, 09:27 PM   #16
cosseywrx
Member#: 276443
What do u mean by rings? o rings i assumed
Old 02-24-2012, 09:34 PM   #17
cosseywrx
Member#: 276443
Do u need gaskets with phenolic spacers?
Old 02-24-2012, 09:35 PM   #18
Alaskan EJ20
Member#: 160040
2002 Bugi / 1993 L
Symmetry Tuning
try reseting battery, try trading maf with a buddy, starter ground, battery terminals,
Old 02-24-2012, 09:39 PM   #19
retrac
Member#: 217208
2001 Porsche 911
LSx Twin Turbo
I've never gotten it to seal without gaskets on both sides of the spacer. Grimmspeed recommends this as well.
retrac is offline   Reply With Quote
Old 02-24-2012, 09:39 PM   #20
Alaskan EJ20
Member#: 160040
2002 Bugi / 1993 L
Symmetry Tuning
or use rtv, but yes you could have a major boost leak, will the car idle?? If so let it idle and spray carb cleaner around the intake manifold or anywhere you think it may be leaking. the car will shutter and almost die if it inhales the carb cleaner.
Old 02-24-2012, 09:48 PM   #21
cosseywrx
Member#: 276443
Idles rough as ****. Bounces around in rpm aroun 200-300 rpms. I will spray and if it leaks i will order gaskets. 2 for both i assume.
Old 02-24-2012, 09:51 PM   #22
Alaskan EJ20
Member#: 160040
2002 Bugi / 1993 L
Symmetry Tuning
if it idles better with out maf plugged in do it that way
Old 02-24-2012, 10:28 PM   #23
kayetealynn
Member#: 253304
2001 Impreza 2.5RS
Plus MOAR
Check the intake manifold gaskets. I've seen a lot of Subarus this winter having misfire issues and ALL of them were due to leaking intake manifold gaskets.
kayetealynn is offline   Reply With Quote
Old 02-24-2012, 10:53 PM   #24
cosseywrx
Member#: 276443
Old 02-24-2012, 11:25 PM   #25
P3Auto
Member#: 241881
2014 P3 Import Auto
AWD Dyno, Mods, etc
Gap won't do that. How does it actually run? Is it bad running right at startup or after its warm? Does it run proper with the Maf disconnected.
P3Auto is offline   Reply With Quote
Key in run position: radiator fan; fuel pump, several relays all cycle n4soccer06 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 9 12-28-2011 10:47 PM
all cylinders misfire after ~5k rpms FuelCutOff Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 11 08-25-2009 05:12 PM
All cylinder misfire codes!! rex_n_z Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 04-25-2009 10:57 PM
all 4 all cylinder misfirer squirelieRS Service & Maintenance 2 10-07-2006 09:24 AM
All 4 misfire codes at once! silvercharged Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 22 12-16-2003 04:44 PM
