Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 04-27-2001, 10:15 AM   #1
wop
Member#: 1931
2000 00 impreza 2.2l
wagon
Post what is the maxium speed you...
you can take a turn (left and right) at an intersection?*
what is your suspension set-up?
what technique are you using?
*intersection being a standard square with 90 degree angles.
I realize this is illegal but not everyone drive the speed limit all the time
-wop
EDIT: SP for SanjuNana . thanks.
[This message has been edited by wop (edited April 27, 2001).]
wop is offline   Reply With Quote
Old 04-27-2001, 10:17 AM   #2
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
Wink
off road???
j.
Old 04-27-2001, 10:18 AM   #3
bratmantlz
Member#: 3231
88 626 Turbo
white
Post
not sure i havent been able to take a turn fast since i put my two tens in the trunk. but i do get my rear strut bar next week and i am using it to brace the speaker boxx and hold it stil so i will be able to speed more again!!
bratmantlz is offline   Reply With Quote
Old 04-27-2001, 10:19 AM   #4
SanjuNana
Member#: 3314
2001 Impreza 2.5 RS
BRP
Post
Speed lint?
SanjuNana is offline   Reply With Quote
Old 04-27-2001, 10:20 AM   #5
eastbaysubaru
Member#: 4110
04 FXT
Post
Good question, I think I'll have to do some data gathering later tonight. I'll get back to ya.
-Brian
eastbaysubaru is offline   Reply With Quote
Old 04-27-2001, 10:21 AM   #6
remarcable
Member#: 2362
1999 Legacy Outback
Blue w/ Paint Chips & Mud
Post
You need to restate your question with more variables filled in.
Road Surface?
Weather conditions?
Traffic conditions?
Type of tires on the car?
Green light?
Yellow light?
Red Light?
Speed limit?
etc etc etc
remarcable is offline   Reply With Quote
Old 04-27-2001, 10:32 AM   #7
Jeff 2.5RS
Member#: 1590
2004 Rx8
Post
I usually just go around corners bouncing off the rev limiter in 5th Ok seriously at the last auto-x there were these two very tight 90 degree rights that I was going through probably about 40 (didn't get a chance to look down at the speedo) on SO-2's.
Jeff 2.5RS is offline   Reply With Quote
Old 04-27-2001, 10:34 AM   #8
wop
Member#: 1931
wagon
Post
ok.
Road Surface? street (asphalt).
Weather conditions? dry.
Traffic conditions? none.
Type of tires on the car? that would be apart of "what is your suspension set-up?"
Green light? yes.
Yellow light? no.
Red Light? no.
Speed limit? none.
that should clear it up .
-wop
Old 04-27-2001, 10:51 AM   #9
garface
Member#: 1581
MY00 RS/STi7
MY01 RS Both Silverthorne
Post
Damn Jeff, I'm stock and a 40mph right isn't much. I've done that without too much worrying. Does sliding count? I'll have to go try again, but I'm pretty sure I've done somewhere around that. Be safe.
garface is offline   Reply With Quote
Old 04-27-2001, 11:09 AM   #10
Kachukaa
Member#: 2527
1997 Legacy 2.5GT
Quicksilver Metallic
Post
On a road with 0 traffic, with my pirelli's and swaybar set high, I've been known to keep the car high in second and try a four wheel powerslide, just for fun. Hell on your tires, but fun nonetheless.
Pete
Kachukaa is offline   Reply With Quote
Old 04-27-2001, 11:49 AM   #11
smacksube
Member#: 4067
01 2.5 rs
Post
my car is all stock and the fastest I've done a 90 degree turn with dry conditions on asphalt is 50 miles an hour. I use the brake swing technique...I made up that name, no ok...whenever I do this I'll be in 3rd going around 60, clutch in, drop to 2nd...at the beginning of the turn I turn the wheels slightly, when they're gripping I hit the brake sharply and the back swings around..it's nigfty, kinda difficult on re-92's because you can go into an understeer situation super easy...under or over...whatever the situation is when your front wheels are turned and you're going straight...
[This message has been edited by smacksube (edited April 27, 2001).]
smacksube is offline   Reply With Quote
Old 04-27-2001, 11:51 AM   #12
wop
Member#: 1931
wagon
Post
smacksube-
left or right?
-wop
Old 04-27-2001, 11:54 AM   #13
bryanw
Member#: 807
2002 WRX Wagon
Post
In perfect conditions, the fast I've taken a right hand-turn (not crossing lanes), is about 50 mph, sliding towards the outside the entire time of course.
But there's so many different types of left-hand turns. It depends on how many lanes there are, the size of the intersection, all kinds of stuff. But the fastest I've taken a 90-degree left-hander on a 2-lane road is about 75. On a 4-lane road, about 90. It depends on whether you really have to stay between the lines too. If you can cut the corner, then we're talking 100+.
bryanw is offline   Reply With Quote
Old 04-27-2001, 01:40 PM   #14
remarcable
Member#: 2362
1999 Legacy Outback
Post
Probably 45MPH when nobody was looking.
Stock Outback Suspension and Michelin Rainforce MX4 tires.
I thought the damn thing was gonna flip until the tires broke free!
Driving in the rain is much more fun.
Old 04-27-2001, 01:41 PM   #15
Danny5
The Emperor Protects
Member#: 13
2014 Chevy Cruze
Diesel
Post
The fastest I have taken a right hand turn and made the closest right hand lane is 40mph. The fastest I have made a right hand turn and made the middle lane or 2nd lane is right near redline in 2nd (50mph).
My car is faster on the track than on the street. So you can probably bump those numbers up by 5 to 10mph. (I have adjustable pillowball mounts)
My suspension setup consists of a 20mm rear bar, Tein HA adjustable coilovers with 7kg/m front springs and 6kg/m rear springs, set at 12 front, 15 rear. I have whiteline solid endlinks on both the front and rear, front and rear strut tower bars, and a whiteline ALK. Tires are Dunlop SP9000 set to 40lbs front and rear on 17" rims in the 215/40 variety.
This is on a MY99.
-Dan
Danny5 is offline   Reply With Quote
Old 04-27-2001, 07:40 PM   #16
hayscoob
Member#: 4544
2004 STi Aspen White
Bone Stock for now
Post
I would love to see a guy try to make a right angle turn @ 50+ in an intersection. A very sharp road curve yes but a right hand turn from the right hand lane in a city or rural road intersection, I don't think so. Even with the very best suspension and tires money can buy can't get a car to do that. On a country road with sharp semi banked corners you could get away with awsome amounts of speed, but a city right angled intersection @ 50+ mph speeds not likely. You will most likely loose it with too much understeer and plow into the other lane or if you brake too much entering into the turn you will ovesteer and the back end of the car will end up in the other lane. Just take the car to a parking lot chalk out a phony intersection and try it. The plus side of this try-out is to find the limitations of the car. Try it wet and try it dry. It may save your life knowing what the car can realy do.
hayscoob is offline   Reply With Quote
Old 04-28-2001, 08:09 AM   #17
bryanw
Member#: 807
2002 WRX Wagon
Post
That's not even worth arguing about. I've come to learn on this board that no matter what you say you've done with your car, somebody will call you a liar. Because some people think they know exactly how everybody else's car will drive.
What is the 1st thing you ever got pulled over for, once you got your WRX/STI ? 99ways2die Off-Topic 69 11-04-2005 12:30 PM
What is the most that you have heard a HKS turbo kit(gt2540r) make at the wheels?? eightballrj Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 07-28-2004 10:52 AM
What is the grinding noise you hear when a synchro is shot? PaulRex Transmission (AT/MT) & Driveline 1 08-01-2003 01:01 PM
What is the longest distance you drive without stopping the engine? Dealer Xing General Community 42 05-30-2002 11:18 AM
What is the Maxium Spring Rate the AGX or V5 Struts can take? H5N1 Brakes, Steering & Suspension 4 07-01-2001 08:05 PM
