Welcome to the North American Subaru Impreza Owners Club Tuesday May 5, 2015
Old 02-25-2012, 01:15 PM   #1
steveomiami
Member#: 309883
Default Coils?
Today I fixed an overheating issue on my car and since i had it apart I thought I would do a compression check. The car was running good before i did anything. i pulled the coils and plugs then did the tests. Everything was good. I did not disable my ignition system while doing this. After I reassembled everything the car is idling very slow and lopey and the motor is shaking pretty hard, it kind of sounds like a harley......When i touch the throttle it bogs and almost dies, if i hold the throttle for about 5-10 seconds it will eventually pick up engine speed. i pulled one of the coils with it running and there were no changes. I am assuming that means the coil is bad? If so where do i get coils for this car its a 1992 JDM ej20 wrx.
steveomiami is offline   Reply With Quote
Old 02-25-2012, 01:53 PM   #2
steveomiami
Member#: 309883
are these ok? http://cgi.ebay.com/ws/eBayISAPI.dll...ht_2556wt_1071 is there a good place for used ones?
Old 02-26-2012, 02:53 AM   #3
Marnix
Member#: 51480
1984 AM5, 1994 BC4,
2010 BR5
There's a good fix using USDM WRX coils. It's stickied.
Marnix is offline   Reply With Quote
Old 02-26-2012, 04:13 AM   #4
TommyAtomic
Member#: 257043
1993 JDM WRX Wagon
The coil swap is a good idea in general. Read the sticky.
However to make the car drive-able again you should probably check all of your coils for cracks and then use dielelectric grease when re-assembling. Make sure the coil is actually in contact with the plug.
Its a tight space and easy to jamm it in there without it being lined up correctly with the top of the plug when you rush.
TommyAtomic is offline   Reply With Quote
Old 02-26-2012, 05:48 AM   #5
pmugabi
Member#: 280926
Could you have swapped coils between cylinders? Something like swapping 1and 3? It's very easy to do and can cause similar symptoms.
pmugabi is offline   Reply With Quote
Old 02-26-2012, 06:54 AM   #6
steveomiami
Member#: 309883
I don't think I swapped them but I hope I did. Where's a good place to get the newer style plugs online?
Old 02-26-2012, 10:45 AM   #7
suberdave
Member#: 101865
88 GL-10 STi
if all was good before you did your compression test and the issue started right after, i bet you swaped two coils. the cracked coils normaly dont cause that big of a problem.
i have done a few swaps to new style coils. well worth it. but if yours are fine, and just swaped, worrie about the coil swap later.
best place to find coils is on ebay, or on any subaru forum.
or if you just need one old style coil. i have a few that are good. i could sale you one for a good price.
-=Suberdave=-
suberdave is offline   Reply With Quote
Ignition Coil my2000 rs, is the same year outback coil work? GregBolby Normally Aspirated Powertrain 5 03-31-2007 11:47 PM
sti ignition coils vs wrx coils wickedwrx2002 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 08-23-2006 07:23 PM
need help installing B+G coils or any coils ASAP sc00bywagon Brakes, Steering & Suspension 0 06-26-2005 07:58 PM
4 Wrx Coils, Ignition Coil Packs, navyissuesuby Private 'For Sale' Classifieds 16 03-05-2005 01:07 PM
Coil and coil pack brunetmj Electrical & Lighting 6 02-01-2003 09:38 AM
