Old 02-26-2012, 12:44 AM   #1
renhoek
Member#: 71339
1995 WRX STi RA
1995 WRX STi LS1
Default Zero oil pressure
Hi guys. Can anyone give me some insight as to why a jammed shut oil pressure relief valve would have resulted in zero oil pressure? I thought that an oil pressure relief valve jammed shut would cause high pressure, not low or zero...
renhoek is offline   Reply With Quote
Old 02-26-2012, 01:35 AM   #2
danetrainer
Member#: 101076
Agreed.
Are you saying you replaced the oil pump and the problem is fixed?
Or, if the source of the problem has not been resolved...have you checked the oil pick-up tube? They can break at the flange where its bolted to the block and not draw oil to the pump.
danetrainer is offline   Reply With Quote
Old 02-26-2012, 04:55 AM   #3
renhoek
Member#: 71339
1995 WRX STi RA
1995 WRX STi LS1
Originally Posted by danetrainer View Post
Agreed.
Cause of the no pressure is unresolved. Oil pick up tube is fine, no cracks.
Will install a new pump but just cannot figure out what has gone wrong.
Old 02-26-2012, 04:58 AM   #4
renhoek
Member#: 71339
1995 WRX STi RA
1995 WRX STi LS1
Anything I should do with the new pump before I install?
Old 02-26-2012, 09:53 AM   #5
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
blockage in the system somewhere????......if you had no oil pressure the engine would blow up real quick
Old 02-26-2012, 03:52 PM   #6
renhoek
Member#: 71339
1995 WRX STi RA
1995 WRX STi LS1
The zero pressure happened when starting the engine for the second track session. Engine was cool. No noises from engine (yet) but I guess we will see when I install the new pump.
Almost like the pump was cavitating ( which I know it does not do) but the jammed relief valve is all I can see that is wrong
Old 02-26-2012, 05:56 PM   #7
Uncle Scotty
Member#: 16200
OK buy Nates beans
pull the filter off and cut it open.....that may tell the tale
Old 02-27-2012, 01:18 AM   #8
renhoek
Member#: 71339
1995 WRX STi RA
1995 WRX STi LS1
Great idea Scotty. I will get onto it tonight.
Old 02-27-2012, 02:39 AM   #9
renhoek
Member#: 71339
1995 WRX STi RA
1995 WRX STi LS1
Well, I have cut it open and it just looks like a normal filter. Nothing obvious there and filter not blocked.
Old 02-27-2012, 10:24 AM   #10
Uncle Scotty
Member#: 16200
OK buy Nates beans
mmmmmm....that's a good one
Old 02-27-2012, 12:54 PM   #11
bako
Member#: 226211
2002 impreza WRX JDM
blue
remove stock oil pressure sender and rotate engine by hand. look, if you have oil coming. if there is empty, fill that channel with oil and try again
bako is offline   Reply With Quote
Old 02-27-2012, 05:48 PM   #12
renhoek
Member#: 71339
1995 WRX STi RA
1995 WRX STi LS1
I have the pump off the engine at the moment as I am awaiting delivery of a new pump. I really don't want to reinstall the old pump, reset the timing just to try this.
Call me lazy.......
This problem is very odd and I am hoping that for whatever reason, the new pump fixes the problem.
Old 02-27-2012, 06:26 PM   #13
Bacon117
Member#: 118500
02 Silver Wagon
"Stage 2"
Are you sure the oil pressure sender isn't bad?
When I was a kid, I replaced a fuel pump b/c I didn't realize the car was out of gas. Doh!
Bacon117 is offline   Reply With Quote
Old 02-28-2012, 05:43 AM   #14
renhoek
Member#: 71339
1995 WRX STi RA
1995 WRX STi LS1
2 separate sensors. Both report a problem.
Old 03-02-2012, 12:49 PM   #15
bako
Member#: 226211
blue
how can you not to open pump and look in it? strange laziness
Old 03-03-2012, 06:35 AM   #16
renhoek
Member#: 71339
1995 WRX STi RA
1995 WRX STi LS1
I have opened up the pump and again, it looks fine. No sign of wear or damage and 3 thou clearance between rotors and backing plate.
Old 03-03-2012, 06:37 AM   #17
renhoek
Member#: 71339
1995 WRX STi RA
1995 WRX STi LS1
I installed another pump today (after I checked it was all fine), started her up and pump is good. Will run the car tomorrow until it is warm, then drain the oil and see if I have any bearing damage.
Old 03-03-2012, 01:21 PM   #18
bako
Member#: 226211
blue
I bet that was priming issue. even shot oil pump is able to pump some amount of oil with some pressure
Old 03-04-2012, 05:51 AM   #19
renhoek
Member#: 71339
1995 WRX STi RA
1995 WRX STi LS1
Your guess is as good as any, but I just can't see how an oil pump would "unprimed" itself.
Anyway, all good now, and I installed an Accusump while I was at it!!!
Drop in oil pressure / low oil pressure magicstop Newbies & FAQs 3 07-24-2015 11:13 PM
Oil pressure reading zero biglongdong Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 02-19-2010 09:41 AM
Prosport Premium Gauges 52mm Oil Pressure and Temp Remote Oil Pressure Sender Kit skribblez32 Interior/Dressup/Audio & Security 4 07-01-2009 03:50 PM
Oil filter relief pressure / oil pressure spec mattwho Service & Maintenance 1 05-25-2009 11:11 PM
Fuel pressure, Oil pressure, and Oil temp gauges that fit in a single din? annointed Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 10-23-2002 11:40 AM
