Welcome to the North American Subaru Impreza Owners Club Saturday May 30, 2015
Old 02-26-2012, 06:28 AM   #1
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
Default I might be doing my first rebuild ever and I have a question
I've got a late G short block I'll be buying. Now it needs new bearings.
I've been told that I will have to get a crank grind and oversized bearings. Is a grind actually required or is that only if the crank got chewed up when the bearings let go?
i_c_the_light is offline   Reply With Quote
Old 02-26-2012, 01:07 PM   #2
eg33GC
Member#: 206851
56 Belair
Pro Street
there is only a tiny amount of hardened surface on the crank. grinding it will render the crank useless.
you can find more info in the built section
eg33GC is offline   Reply With Quote
Old 02-26-2012, 03:13 PM   #3
69subaru360
Member#: 159682
1995 WRX
2015 F150 (ordered)
Yes you need to have the crank ground undersized. The chances of it surving spun bearings undamaged is slim.
I would just grab a used crank. It's the same as the non-turbo 1.8/2.0/2.2 You have those over there right? They are dime a dozen here and you can get one dirt cheap.
Old 02-26-2012, 11:06 PM   #4
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
The block fell through anyway so I won't be doing it anytime soon. Yeah they are pretty much all over the place and I did think about dropping a 2nd hand crank in I just wanted to know if the grind was REALLY needed.
Old 02-27-2012, 09:50 AM   #5
Marnix
Member#: 51480
1984 AM5, 1994 BC4,
2010 BR5
A grind is only needed when the journals are damaged due to a spun bearing. If the journals are OK just use some new (ACL) bearings and your crank. Don't bother grinding get a good used crank as said above.
Marnix is offline   Reply With Quote
Just got my used 04 sti and I have a question... tp290 Newbies & FAQs 17 07-08-2010 10:05 AM
Might be picking up a 93 Legacy Sedan...I have questions CrAzi_EyEs Newbies & FAQs 1 03-09-2010 02:07 AM
I just watched HEAT for the first time ever, and I have to say... brucelee Off-Topic 23 12-16-2007 10:07 PM
Got my first ticket ever. Reckless and going to court :( mrjenkins Mid Atlantic Impreza Club -- MAIC 31 11-14-2006 11:36 PM
Might Be Selling My 98 Wagon L With STI Short Block And More monstergremlin16 Private Vehicle 'For Sale' Classifieds 11 03-31-2006 02:50 PM
