Old 02-26-2012, 06:56 AM   #1
kyran013
Member#: 311390
Unhappy Someone Help Please!!!!!
I really need help!!!!
ok so i have a 1995 gx 1.8L impreza in which i blew th motor so i have done an 1995 jdm wrx sti ej20g conversion engine,engine harness and z4 ecu only.... now i have swapped all of that over the body lume matche's up to the engine lume my problem is that i seem to be lacking spark and fuel and i CANNOT find out why does anyone have any idea's????????????????? if you could help i would be so greatfull thanx.
kyran013 is offline   Reply With Quote
Old 02-26-2012, 12:24 PM   #2
tom bauer
Member#: 310141
you need wiring diag of the ecu to see that it is getting power where required. also to check that all the wiring really does match up correctly.
tom bauer is offline   Reply With Quote
Old 02-27-2012, 03:55 AM   #3
DHRDAN
Member#: 204358
01 2.5RS W/ EJ257
Who did the wiring???? for the conversion????
If you have no spark... check your coils/spark plugs...
if you have no power check your fuses/ignition.
If you don't have that... check you ECU is getting power.
If you don't have that... if your fuel priming...do you hear the pump???
If you don't have that.... check..... well..... check you wiring.
DHRDAN is offline   Reply With Quote
Got some problems.. someone help please boxerFTW Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 09-11-2006 03:38 PM
Someone Help Please!!!!!!! subiee sTi Newbies & FAQs 2 06-07-2006 05:05 AM
Someone help please.. MidnightBlack02WRX Tri-State Area Forum 7 11-14-2005 05:51 PM
Short throw shifter buzzing / 5th gear drops out by itself. Can someone help please? powerlabs Transmission (AT/MT) & Driveline 8 04-15-2004 11:39 PM
Can someone HELP..PLEASE.. WRX-U Mid Atlantic Impreza Club -- MAIC 11 02-10-2003 05:51 PM
