Welcome to the North American Subaru Impreza Owners Club Sunday February 1, 2015
Old 02-26-2012, 01:12 PM   #1
cnlor
Member#: 233120
03 wrx
yellow
So I go get my car tuned, everything is working well. The ecu is letting us flash it and read it. All of a sudden the ecu stops letting us write to it or read. It wouldn't matter if he flashed it with a stock sti rom right? So now I have to take the ecu out to tactrix so they can do their bench work on the ecu. Any thoughts????
The ecu also was not reading 12 volts but clearly there was 12 volts.
cnlor is offline   Reply With Quote
Old 02-26-2012, 01:28 PM   #2
Nuke209
Member#: 108089
2003 WRX
NF Performance
Health of battery?
Nuke209 is online now   Reply With Quote
Old 02-26-2012, 02:06 PM   #3
cnlor
Member#: 233120
03 wrx
yellow
Originally Posted by Nuke209
Health of battery?
There was absolutely no readings at all.
Old 02-26-2012, 03:35 PM   #4
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
kiddie hack wiring job somewhere??
Uncle Scotty is online now   Reply With Quote
Old 02-26-2012, 05:40 PM   #5
cnlor
Member#: 233120
03 wrx
yellow
Well I bought the car two months ago. When I lock the key automatically from the switches inside and try opening it with the keys outside, the alarm comes on. Then I have to turn the car on and off 3 times to set it off. As far as I know, its not stolen or had been. It is however a repo car.
There is some wiring beneath the car, just looks like it use to have a system in it.
But its just awkward how we could read/write to the ecu and all of a sudden it couldn't. He checked the throttle response, intake temp, etc. And there was no sign of any voltage from the battery.
Old 02-26-2012, 06:09 PM   #6
Patrick P931
Member#: 264035
2007 Forester EDMSTI
Urban grey
For the EDM's the wrx/fxt ecu's are quite different to the STI.
The STI has more or less the same maps defined but usually several more columns and/or rows with cells.
I.e. (at least for me) you can use the values from STI in your own ROM but flashing a STI rom will be asking for trouble.
What exactly did you attempt before the situation you are in now?
Cheers,
Patrick
Patrick P931 is offline   Reply With Quote
Old 02-26-2012, 07:21 PM   #7
cnlor
Member#: 233120
03 wrx
yellow
Hrm... well my tuner flashed a base stage 2 sti map into mine.... you think that could of been the issue?
Cause he flashed his base map once and the car wouldnt start. It would crank over but just didnt start. Then the air/vaccum blower thingy by the battery kept coming on even when i turned the car off. The only way to shut it was to disconnect the battery.
Old 02-26-2012, 07:58 PM   #8
wrxBRAH
Member#: 256841
2004 FXT
You were stuck in diagnostic mode. Likely bricked PCM same thing happened to me when my flash blue screened and like an idiot I turned the key off.
wrxBRAH is offline   Reply With Quote
Old 02-26-2012, 08:13 PM   #9
quazimoto
Member#: 70395
And his reason for not just using a base stag2 06 WRX map?
quazimoto is offline   Reply With Quote
Old 02-26-2012, 08:18 PM   #10
cnlor
Member#: 233120
03 wrx
yellow
I dont know if he just forgot that its just a base wrx or not. Do you think that could be the reason why it caused the ECU to lock up, where it couldnt be reflashed? Thanks alot.
Old 02-27-2012, 04:00 PM   #11
cnlor
Member#: 233120
03 wrx
yellow
What do you mean by "PCM"? And I noticed that a pop-up screen came up telling us not to turn the car off. Then we waited and then he just told me to turn it off. How did you resolve your issue? Thanks
Old 02-27-2012, 05:40 PM   #12
cnlor
Member#: 233120
03 wrx
yellow
Update:
So doing more and more research through forum after forum I have given in that my 2006 WRX ecu is bricked.
Why? When the pop up screen comes up and say "Do not turn the car/ignition off" Please don't turn it off! Save yourself time and a headache.
Now I am in the proccess of finding someone in the Phx, AZ area who can unbrick my ecu.
Old 02-27-2012, 05:47 PM   #13
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
Powertrain Control Module. Basically the computer, ecm, ecu... Whatever else you want to call it.
Black94Snake is offline   Reply With Quote
Old 02-27-2012, 05:52 PM   #14
cnlor
Member#: 233120
03 wrx
yellow
I see, I'm guessing you got it unbricked or got a new ecu?
Old 02-27-2012, 06:17 PM   #15
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
I have not bricked my ecu. I came damn close... But I have yet to do it. I was just answering the question.
Old 02-27-2012, 06:22 PM   #16
cnlor
Member#: 233120
03 wrx
yellow
I am wondering, will i need a new ecu or if I get it fixed by someone or tractrix, will that help?
Old 02-27-2012, 06:23 PM   #17
cnlor
Member#: 233120
03 wrx
yellow
Ok thanks. Hope it will never happen to you
Old 02-27-2012, 06:31 PM   #18
cnlor
Member#: 233120
03 wrx
yellow
This is how I knew my ecu was bricked
http://www.romraider.com/forum/viewt...hp?f=15&t=7477
I have no experience with tuning what so ever. So do not flash a sti rom into your wrx ecu. Even if its 32bits.
Old 02-28-2012, 03:50 PM   #19
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
even though both ecu are 32 bit.
you should have not flashed a sti map onto
a wrx ecu.
but i guess you learned your lesson.
i would also find a new tuner..
Old 02-28-2012, 06:48 PM   #20
cnlor
Member#: 233120
03 wrx
yellow
a wrx ecu.
He is a very good tuner and I have respect for him. Might of just been a bump in the road. I just thought he'd know my car was a wrx and not a sti.
So he sent the ecu to tactrix so they could do their bench work on it.
My car will be done thursday with a tune finally. Hopefully i will be making more than 350whp.
Old 02-28-2012, 08:47 PM   #21
quazimoto
Member#: 70395
If he can't tell the difference then he can't be that great tuner.........it's pretty obvious the difference by looks and is probably an important detail to know if tuning the car. Just saying...........
Old 02-28-2012, 08:52 PM   #22
quazimoto
Member#: 70395
That doesn't prove anything. Especially since I can easily flash an 02 JDM STI ROM to my 02 USDM WRX if I wanted too. The issue in that post was flashing a 32bit ROM to a 16 bit ROM.
Old 02-29-2012, 12:26 AM   #23
cnlor
Member#: 233120
03 wrx
yellow
True..
Old 02-29-2012, 12:27 AM   #24
cnlor
Member#: 233120
03 wrx
yellow
I see, I see. Makes sense
Old 04-27-2013, 11:16 AM   #25
simon021
Member#: 157532
2002 MY03 EJ207 E85
Dom 1.5XTR Twinscroll!
Is your tuner paying to unlock the ecu that he screwed up? Did you get this revolved?
simon021 is offline   Reply With Quote
Need Stock STi ROM -- 04 ArSoN9 Open Source Reflashes 2 10-19-2011 11:28 PM
2006 wrx TR with vf39 sti topmount cobb stg.2 knighter Proven Power Bragging 12 04-09-2009 12:17 AM
Replace WRX exhaust with stock STi exhaust? pro's and con's? Redboss Newbies & FAQs 28 07-10-2007 11:01 PM
2006 WRX EWG with stock turbo? deblas66 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 76 12-15-2006 10:05 AM
2006 WRX. Stage 2 + stock exhaust. Anything wrong with my reasoning? dak125 Newbies & FAQs 31 08-16-2006 01:56 AM
