Old 02-26-2012, 09:14 PM   #1
WRB19
Member#: 302898
2008 Evo X
Graphite Grey
Default 2011 WRX COBB stage 2 + sf overboosting on severe LWG map
https://docs.google.com/spreadsheet/...y1aRjZISmNqWkE
As I was doing this pull I overboosted and the car like shut down for a sec and threw a CEL and made my cruise control light flash
At one point when I wasent logging I hit 20.1 psi. Im on the normal map. Mods are COBB SF intake and COBB catted DP
I ran the severe LWG map and got 21.1 psi....Then I logged...and here it is
https://docs.google.com/spreadsheet/...LZnZRUHc#gid=0
WRB19 is offline   Reply With Quote
Old 02-26-2012, 10:09 PM   #2
WRB19
Member#: 302898
2008 Evo X
Graphite Grey
https://docs.google.com/spreadsheet/...XhsU19LZnZRUHc
Old 02-26-2012, 10:25 PM   #3
PROcede
Member#: 293500
2015 FXT Stage 2
CWP
Are you catless?
PROcede is offline   Reply With Quote
Old 02-26-2012, 10:27 PM   #4
WRB19
Member#: 302898
2008 Evo X
Graphite Grey
Originally Posted by PROcede View Post
Are you catless?
No, COBB catted downpipe.
Old 02-26-2012, 11:13 PM   #5
AWDPWR12
Member#: 303314
Damn! thats crazy! i would take it easy till you talk to Cobb....
AWDPWR12 is offline   Reply With Quote
Old 02-27-2012, 01:11 AM   #6
Airboy
Member#: 72829
2006 WRX
2015 WRX
How was the air temp like when you did the pull(s)? In the 20s?
Airboy is offline   Reply With Quote
Old 02-27-2012, 07:36 AM   #7
WRB19
Member#: 302898
2008 Evo X
Graphite Grey
It was about 30 degrees. When I was stage 1 + sf everything worked fine in cold weather.
Old 02-27-2012, 06:13 PM   #8
Airboy
Member#: 72829
2006 WRX
2015 WRX
send me a pm with your email address and I will send you something.
Old 02-27-2012, 07:40 PM   #9
WRB19
Member#: 302898
2008 Evo X
Graphite Grey
https://docs.google.com/spreadsheet/...WdW15RXc#gid=0
heres the car on economy mode, hit 17 psi...
Old 02-27-2012, 08:10 PM   #10
Airboy
Member#: 72829
2006 WRX
2015 WRX
Sent you a map to try. hitting 17psi with 0wgdc...you may need to remove one of the pills in the boost "Tee", the one closest to the actuator canister.
Old 02-28-2012, 01:19 PM   #11
WRB19
Member#: 302898
2008 Evo X
Graphite Grey
Haven't had a chance to run that map yet but i'll let you know how it is. I haven't heard back from COBB on this yet either.
Old 02-28-2012, 08:07 PM   #12
snoopy_sti
Member#: 164942
2015 Porsche Cayman
I would log your injector duty cycle because you are pushing more boost then you are supposed to and I am betting you are maxing the heck out of the stock injectors.
snoopy_sti is offline   Reply With Quote
Old 02-28-2012, 08:38 PM   #13
WRB19
Member#: 302898
2008 Evo X
Graphite Grey
Im trying not to get into boost at all untill the car is fixed. Im having a shop look at it on Thursday but im not sure if they will find the issue...
Old 03-01-2012, 10:14 PM   #14
WRB19
Member#: 302898
2008 Evo X
Graphite Grey
Well I found the problem...COBB sent me a defective heat shield that wasn't letting my wastegate arm move. It also didnt clear the lines coming from the turbo.
hopefully COBB will send me a new heat shield...
Old 03-01-2012, 11:53 PM   #15
Xtreme.
Member#: 292380
^This is somewhat of a common problem with aftermarket heatshields... I had the same experience (although I didn't overboost since I noticed the physical problem and fixed it by bending the heatshield before I even tuned my car). How is the car doing now? acting normal?
Xtreme. is offline   Reply With Quote
Old 03-02-2012, 12:01 AM   #16
WRB19
Member#: 302898
2008 Evo X
Graphite Grey
Its working great now without a heat shield.
Old 03-02-2012, 12:09 AM   #17
Airboy
Member#: 72829
2006 WRX
2015 WRX
Looks like they may have sent one for a different model year. Did you bend it during installation?
Old 03-02-2012, 07:35 AM   #18
WRB19
Member#: 302898
2008 Evo X
Graphite Grey
Yeah I bend it around to fit one of the lines.
Old 03-05-2012, 12:00 PM   #19
Cobb Tuning
Member#: 4803
Let us know where you got it from and if you have a copy of the original invoice so we can make sure to get you the proper heat shield part number for you car!
Ian
2011 WRX - Stage 2 + E85 Tune - Dyno Results xluben Proven Power Bragging 71 04-07-2015 03:52 PM
2011 WRX Cobb Stage 1 datalog Jaker Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 13 02-04-2011 05:35 PM
2011 WRX E-SPEC Stage 2 DYNO GRAPH danrheller Proven Power Bragging 35 01-21-2011 11:31 AM
2011 WRX - Stage 2 - COBB Downpipe and SPT Exhaust (VIDEO) xluben General Community 47 01-19-2011 01:32 AM
2004 WRX Cobb Stage 2 dnyo chart, Stage 4+++ to come... aps2fast4u Proven Power Bragging 13 04-02-2006 12:35 PM
