Old 04-06-2012, 09:00 PM   #176
iAmjudge
Member#: 300236
2011 WRX
I installed an AVH-p3400bt unit today and I can't seem to get it to dim with the gauges when headlights are on...
Does anyone have an idea how to do this? I have a 2011 wrx.
iAmjudge is offline   Reply With Quote
Old 04-06-2012, 09:07 PM   #177
slowhat
Member#: 304175
2012 WRX Limited
PBP
Dimmer wire connected?
slowhat is offline   Reply With Quote
Old 04-06-2012, 10:36 PM   #178
BWX
Member#: 236305
2009 2.5i 4dr 5spd
Newport Blue Pearl
It just dims with headlights on, doesn't gradually adjust down like factory radio AFAIK. I just installed the 3300BT and there was no wire to hook up that would allow that.
-unless I totally missed something.
http://ae64.com/Subaru-20-pin-harness-install.htm
Illumination Control Wire
Most HUs have a wire to control the brightness of their illumination. The dimming is two-stage: The HU will be at full brightness during the day, and slightly dimmed when you turn on your car's headlights.
If your HU has a wire for "Dimmer" or "Illumination Control," connect that to the Orange wire (pin 1, Illumination +) on the 20-pin harness.
I hope I'm wrong though.
EDIT-
If it isn't dimming AT ALL, you need to hook up the dimmer wire, then read manual to adjust brightness for the ''dim mode''. Mine was too dim in dimmer mode by default.
BWX is offline   Reply With Quote
Old 04-06-2012, 10:42 PM   #179
iAmjudge
Member#: 300236
2011 WRX
Mine just stays the same brightness.., the screen I can lower manually but the buttons on the side stay the same brightness...
I'll have to check on it tomorrow but I hooked up all the wires as they are supposed to be.
Old 04-06-2012, 10:48 PM   #180
BWX
Member#: 236305
2009 2.5i 4dr 5spd
Newport Blue Pearl
I don't think the buttons dim, just the screen, but the screen should dim. Check link in my post above.
Old 04-06-2012, 10:50 PM   #181
BWX
Member#: 236305
2009 2.5i 4dr 5spd
Newport Blue Pearl
The HU's wire may be Orange or Orange/White. However, some HUs have no dimmer wire at all some have no dimming capability, and other recent models use an ambient light sensor or GPS time and location. A few HUs even have an Orange/White wire that is not for illumination. Check your HU's installation instructions!
http://ae64.com/20-pin-pinout.htm
There ya go......
I'm going to re-check my 3300BT manual, but I don't think there's a gradual dimmer that hooks up to pin 2.
Old 04-08-2012, 04:34 PM   #182
iAmjudge
Member#: 300236
2011 WRX
Got it now, thanks..
Also noticed the hu has a hiss as soon as you mess with the eq.. Keep it in flat and it's not terrible, radio isn't bad it seems just on my iPod the hiss is present.. Tried grounding the hu to chassis but that didnt work.. I have no subwoofer so the rca's aren't the problem..
Anyone else have this issue?
Old 04-08-2012, 05:00 PM   #183
jnumata
Member#: 266755
2011 STi
Plasma Blue Pearl
I'm an audio amateur but try turning the volume down on the iPod and the volume up on the headunit.
jnumata is offline   Reply With Quote
Old 04-08-2012, 05:01 PM   #184
jnumata
Member#: 266755
2011 STi
Plasma Blue Pearl
I have a 4400bh and jl audio amp, sub, and box going in next Monday! I'll keep you guys posted on how it sounds.
Old 04-08-2012, 05:24 PM   #185
BWX
Member#: 236305
2009 2.5i 4dr 5spd
Newport Blue Pearl
Yeah I notice a little hiss with the volume really loud on a CD, but I have an amp.. Also radio reception isn't the greatest, even though everything is hooked up right. Lots of static. 3300 and 3400 probably have a lot in common inside..
Old 04-08-2012, 05:28 PM   #186
WRX09MD
Member#: 222160
2014 Audi S4
Glacier White
I have tried everything under the sun to resolve the bad radio reception. If you find anything please let me know.
WRX09MD is offline   Reply With Quote
Old 04-08-2012, 05:39 PM   #187
BWX
Member#: 236305
2009 2.5i 4dr 5spd
Newport Blue Pearl
Yeah, I made it MUCH better by hooking subaru antenna amplifier right up directly to accessory power, but that's just because I run an amp amd a big fat relay for brake bypass.
It's 'ok' now, but still not as good as subaru POS stock deck which is a huge disappointment.
I should add that I'm trying to pull in relatively weak FM stations that are close by, but even the powerful stations have way more static than they should. I'd send it back to Crutchfield for a replacement if I thought it would help, but I bet it'd be the same on all of them. It sounds a lot better when car is stationary though. When car is moving is when I get stereo cutting out and excess static.
Old 04-08-2012, 11:21 PM   #188
WRX09MD
Member#: 222160
2014 Audi S4
Glacier White
I did the same thing with the power lead. I am running an Audio Control 3.2 EQ/line driver that is causing the interference i think I am getting. If I bypass the EQ and go straight to the amp my FM signal comes in pretty good. I can't seem to find the problem. I have tried everything I could think of and a lot of help from others but got nothing. Crutchfield tech and Audio Control engineers have no more answers for me. I don't listen to the radio much except in the morning so it doesn't bother to much but I can't even use my HD radio or regular radio for that matter. The EQ is nice for cd's and the iPod though.
Old 04-09-2012, 08:39 AM   #189
iAmjudge
Member#: 300236
2011 WRX
Mine isn't hissing with the radio.. I'll try a cd to see if it does the same thing.
I'm using the front USB for my iPod... If I turn the eq to flat there's little to no hiss.. I can live with it but it's annoying that the terrible oem unit is silent compared to this.
Old 04-09-2012, 12:01 PM   #190
iAmjudge
Member#: 300236
2011 WRX
Figured it out.. It's the eq setting that's all the way to the right, lower that to +2-+4 and a majority of the hiss goes awAy.
Old 04-09-2012, 12:38 PM   #191
BWX
Member#: 236305
2009 2.5i 4dr 5spd
Newport Blue Pearl
Yesterday I hooked up the ground wire that goes to the back of the stock HU to the 3300BT. Now it is grounded twice I guess as there's already a ground in the harness. I also changed back to the stock antenna lead with the 90 degree bend as the straight plug one I got at my local stereo shop didn't help at all and possibly made reception a little bit worse.
After doing that I think there is a very small improvement in FM reception.. Could be just the cloudy weather too.. Who knows.
Old 04-10-2012, 02:35 AM   #192
Krieger88
Member#: 277043
2007 2.5i
Obsidian Black
Where did everybody pick up theirs? If I have to wait for an shipment from buying online for $400 I will. It seems bestbuy doesn't have them yet (not on their site at least) and there's only 2 auto shops remotely close to my house. And one of them are hardcore ripoffs..
Krieger88 is offline   Reply With Quote
Old 04-10-2012, 08:13 AM   #193
iAmjudge
Member#: 300236
2011 WRX
I got my avh-p3400 from best buy. If you did order online there's sonixelectronics, woofersetc, crutchfield or the cheapest probably amazon.
I could have gotten the 4400 online for same price I paid at bestbuy but it was just one of those "want it now" moments.
Old 04-10-2012, 10:51 AM   #194
jetspeed
Member#: 123733
'07 UGM STI
& 06 OBP WRX Wagon
My 4400 is now installed. Banana. Just curious if anyone else has an iPhone to use the App Mode? If so, what apps can you use?
jetspeed is offline   Reply With Quote
Old 04-10-2012, 12:51 PM   #195
iAmjudge
Member#: 300236
2011 WRX
I think you need the pioneer adapter that goes in the back of the unit (if it's like the 3400) I think motion x gps works, maybe google maps
Old 04-10-2012, 04:20 PM   #196
Krieger88
Member#: 277043
2007 2.5i
Obsidian Black
I want to 4400, not the 3400
Edit: Just bought one online for $410 in total :3
Old 04-10-2012, 05:41 PM   #197
iAmjudge
Member#: 300236
2011 WRX
I do like the 7" screen on that and the buttons on the bottom as opposed to the side.
Old 04-10-2012, 06:39 PM   #198
BWX
Member#: 236305
2009 2.5i 4dr 5spd
Newport Blue Pearl
I like the 5v output of the 3300BT. Don't know why they went backwards.
Old 04-11-2012, 03:39 AM   #199
Krieger88
Member#: 277043
2007 2.5i
Obsidian Black
Question: Is there any security precaution that can be taken for these types of touchscreen headunits? As far as i'm aware they don't have detachable faceplates so you always have this fine ass touchscreen on display..
Old 04-11-2012, 04:16 AM   #200
BWX
Member#: 236305
2009 2.5i 4dr 5spd
Newport Blue Pearl
I was thinking about getting some kind of dummy plate to go over top of it.. just a flat piece of plastic to cover it up.
Clutch "clicking" in 2012 wrx STIDAWG Transmission (AT/MT) & Driveline 7 03-16-2013 11:22 PM
Where to ground in 2012 wrx hatch? slowhat Car Audio, Video & Security 3 02-24-2012 11:35 PM
pioneer avh-p4000 install in 06sti nation1979 Car Audio, Video & Security 25 02-26-2009 01:47 AM
Pictures of Hid's installed in '02 WRX :) paultg New England Impreza Club Forum -- NESIC 7 12-16-2001 04:22 PM
Found out a short throw shifter wasn't installed in my WRX.. cout Bay Area Impreza Club Forum -- BAIC 5 05-03-2001 05:59 PM
