Old 05-22-2012, 09:25 PM   #276
CamaroSS
Member#: 30626
2015 BRZ Limited
1999 Miata Track Car
Cool thanks. What about the grey wire that was screwed onto the side of the oem head unit? Does that go somewhere?
CamaroSS is offline   Reply With Quote
Old 05-22-2012, 09:43 PM   #277
CamaroSS
Member#: 30626
2015 BRZ Limited
Oh, and my LAST question: the pioneer harness has a yellow wire with a black stripe that is labeled mute. Was I supposed to connect that to anything?
Thanks
Old 05-22-2012, 10:01 PM   #278
slowhat
Member#: 304175
2012 WRX Limited
PBP
nope, no need to mess with that.
Thanks
you will not use the mute wire. tape it up.
slowhat is offline   Reply With Quote
Old 05-22-2012, 10:07 PM   #279
CamaroSS
Member#: 30626
2015 BRZ Limited
Thanks
Old 05-22-2012, 10:08 PM   #280
slowhat
Member#: 304175
2012 WRX Limited
PBP
no worries!
Old 05-22-2012, 10:51 PM   #281
CamaroSS
Member#: 30626
2015 BRZ Limited
And it works! Thanks again!
Old 05-23-2012, 10:09 AM   #282
CamaroSS
Member#: 30626
2015 BRZ Limited
Initial Review:
Initial impressions are that the stereo plays both louder and cleaner. Much easier to listen to music on the highway with the windows down than on the stock head unit.
The more advanced EQ over the stock head unit is a welcomed addition. The stock unit with the underseat subwoofer had WAY too much bass. I had to turn it down to -5 bass on the OEM unit. Now, it's a much more neutral sound at 0's across the pioneer EQ. I also thought the OEM unit was very harsh sounding in the mids and highs. The pioneer is much better in that respect as well.
HD radio, to my ears, is WAY better than the OEM non-HD radio.
I have had an issue with plugging my iphone 4S in through the fancy cable. When I got back in the car this morning, the head unit seemed to think the audio was playing through Pandora (I can see time elapse), but there is no audio. If I switch to BT streaming, the audio plays fine? I'm not sure what's going on there?
I tried to play a video podcast from my phone, and the image from the video appeared on screen, but it was paused. I couldn't figure out how to make the podcast play? This is not important, but I just wanted to see it work.
Overall, I think I'm going to enjoy this sucker. The only slight knock on this unit is the low resolution screen. It's perfectly fine for displaying song information etc. in a car, but it just seems that in 2012 the bar for a 7" screen would have been set a little bit higher... I knew this going into it. I picked this unit over the Kenwood 719 (4x more res) because I wanted the HD radio.
Old 05-26-2012, 11:55 PM   #283
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
Newb question: the stock radio has four harness connections. What do I do with all them on the pioneer unit, leave them disconnected?
See this thread:
2011 WRX: Picture-back of NON-NAV radio
I identify the various sockets in post #3 there.
Also, there was a grey wire screwed on to the side of the stock head unit. Is this a ground? Does it need to be attached to the new harnesses ground wire?
That is an extra ground lead from the OEM subwoofer's T-harness. The harness taps into the ground lead from the 20-pin radio harness, but they also attach that ring terminal to one of the mounting screws on the side of the radio. I recommend you still do that with your aftermarket HU.
The Pioneer's yellow/black mute wire is for older-style phone car kits (to mute the HU when you answer or place a call). As slowhat said, no need to use it -- make sure it's well insulated.
SVXdc is offline   Reply With Quote
Old 06-12-2012, 10:07 AM   #284
wassim87
Member#: 320557
2012 Subaru WRX STI
Satin White Pearl
Has anyone been getting replies from SVXdc??
I emailed him last week and still waiting.
Is there anywhere else i would be able to get the 20pin harness and the Axxess ASWC from?
wassim87 is offline   Reply With Quote
Old 06-12-2012, 10:12 AM   #285
slowhat
Member#: 304175
2012 WRX Limited
PBP
you can always add your own wires to a harness and an ASWC can be had from Amazon.
Old 06-13-2012, 09:35 PM   #286
WRX09MD
Member#: 222160
2014 Audi S4
Glacier White
He probably wont respond to emails. He gets a million questions about this stuff.
WRX09MD is offline   Reply With Quote
Old 06-13-2012, 09:52 PM   #287
dorkbert
Member#: 309901
2012 Impreza 2.0i 5D
hack your own? Nissan harness can be had for about five or six bucks shipped from fleaBay. Buy a couple and move the wires (but colour code won't be right.)
dorkbert is offline   Reply With Quote
Old 06-15-2012, 12:21 AM   #288
henrypp
Member#: 205903
. 05 LGT 12 OBK
BSM and GGM
Has anyone experienced app mode not working? I used to be able to play youtube videos and netflix but all of a sudden I can't get it to work.
henrypp is offline   Reply With Quote
Old 06-15-2012, 09:51 AM   #289
wassim87
Member#: 320557
2012 Subaru WRX STI
Satin White Pearl
Order placed. Trying to keep same color code to match.
Old 06-18-2012, 12:46 PM   #290
fzel07wrx
Member#: 150710
2012 SWP WRX Hatch
2005 Lotus Elise
I have started to solder my harnesses and ASWC together but I have not taken anything apart in my car yet.
So does anyone know how the OEM Kicker Sub in the trunk/hatch for the newer model year cars will work with a different headunit? (I have an AVH3400)
Just wondering if it will be easy and straightforward or if I need to cut into some other wires.
fzel07wrx is offline   Reply With Quote
Old 06-18-2012, 06:18 PM   #291
Krieger88
Member#: 277043
2007 2.5i
Obsidian Black
For some reason there's a song quality difference between cd's and when my iphone 4s is hooked up. The mp3's aren't **** quality but the volumes lower and the cds just sound so much better. Do I need that rip off of a iphone usb wire to get more quality rather than use the one that came with the deck itself?
Krieger88 is offline   Reply With Quote
Old 06-18-2012, 08:34 PM   #292
slowhat
Member#: 304175
2012 WRX Limited
PBP
I can't speak to the poor quality, but you can increase the source volume level. A different cable probably won't help.
Old 06-18-2012, 10:13 PM   #293
BoboTheMonkey
Member#: 224615
2004 WRX
San Remo Red
I just put in an avh1400 and the wiring harness I had came with a wire to connect up an oem sub. I guess I don't recall for sure, but I was pretty positive it listed one in the manual... This is a very broad assumption though because its a different (but similar) head unit and different (but similar) car...
BoboTheMonkey is offline   Reply With Quote
Old 06-19-2012, 12:52 AM   #294
Krieger88
Member#: 277043
2007 2.5i
Obsidian Black
And before anyone states the obvious that cd's will always have better quality than mp3's I just want to state an example of my problem. I'll put a song on and it'll sound low, so I'll hit previous to whatever song is on before it and then hit forward back to the low sounding song and it'll sound loud. And also I noticed that sometimes the headunit will skip the first 3 seconds of a song.. Could this be bad firmware? It's not a huge problem but is kind of annoying.
Old 06-19-2012, 05:57 PM   #295
VdoManZ
Member#: 195481
2011 Impreza WRX 5dr
blue
yeah, get the harness from SVXdc. saves time.
either way with this unit, you will lose the push to talk function.
good to know. i tried manually programming the ASWC last night, and it would see the push to talk by itself, but not when i programed the on and off hook at the same time. I'd rather have on/off hook and no push to talk/ ATT functionality.
BTW great write up. I followed your guide and http://ae64.com/aswc-install.htm to a T, everything worked perfect.
The audio quality on the 4400bh is so much better than the stock Subaru one (it sounded like you were inside a tin can). With Loudness on low and powerful EQ settings there is a night and day difference between the two units. I wish the bluetooth streaming option on my android phone would send the track/tag info to the screen. But I mainly use my old ipod and use that interface for music.
VdoManZ is offline   Reply With Quote
Old 06-26-2012, 03:20 AM   #296
Krieger88
Member#: 277043
2007 2.5i
Obsidian Black
Disregard this post, I think my iphone 4s's songs are deteriorating somehow, going to try some stuff to see if it fixes my dilemma. The headunit seems to be fine.
Old 06-26-2012, 09:03 AM   #297
fzel07wrx
Member#: 150710
2012 SWP WRX Hatch
2005 Lotus Elise
Can anyone else comment on this? I don't think I have an extra wire from SVXdc's harness labeled specifically for the subwoofer.
Old 07-02-2012, 12:13 AM   #298
gunkadoodah
Member#: 250879
2012 STI
Just installed this, could someone explain to me how to save radio stations and go to the second HD radio station? Must be getting very late....
gunkadoodah is offline   Reply With Quote
Old 07-02-2012, 01:51 AM   #299
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
[moved this portion of my reply to the Kicker sub thread, here]
I think BoboTheMonkey is talking about the Pioneer's harnesses. They include the amp remote turn-on lead and RCA jacks for an aftermarket (not OEM) subwoofer.
There aren't any leads on the Impreza's factory radio harness (and thus none on my 20-pin install harness) related to subwoofers.
There are some Foresters with an OEM underseat sub that connects via pins on the factory aux harness. I do make adapter harnesses to retain that kind of sub with an aftermarket HU.
Old 07-02-2012, 02:30 PM   #300
slowhat
Member#: 304175
2012 WRX Limited
PBP
go here:
pg 39
http://www.pioneerelectronics.com/St...nual051712.pdf
Looks like there's either BSM or a more manual method if BSM is turned off.
Clutch "clicking" in 2012 wrx STIDAWG Transmission (AT/MT) & Driveline 7 03-16-2013 11:22 PM
Where to ground in 2012 wrx hatch? slowhat Car Audio, Video & Security 3 02-24-2012 11:35 PM
pioneer avh-p4000 install in 06sti nation1979 Car Audio, Video & Security 25 02-26-2009 01:47 AM
Pictures of Hid's installed in '02 WRX :) paultg New England Impreza Club Forum -- NESIC 7 12-16-2001 04:22 PM
Found out a short throw shifter wasn't installed in my WRX.. cout Bay Area Impreza Club Forum -- BAIC 5 05-03-2001 05:59 PM
