Old 07-12-2012, 08:09 PM   #301
vuskeedoo
Member#: 312613
2012 WRX Prem. Stg 2
time to bring this thread back.
if i were to add an amp and aftermarket speakers, which harness would i have to buy to work with everything? i would also have to buy the parking bypass and ASWC?
vuskeedoo is offline   Reply With Quote
Old 07-12-2012, 09:34 PM   #302
BWX
Member#: 236305
2009 2.5i 4dr 5spd
Newport Blue Pearl
Amp plugs in directly to HU. Speakers plug into amp. So no difference.
BWX is offline   Reply With Quote
Old 07-17-2012, 04:09 PM   #303
Jmhm17
Member#: 224097
2012 WRX Hatch - DGM
Stage 1 - Tuned by Bren
^^ no difference in the harness, the amp gets its audio signal from the back of the HU like stated above from the RCA cables. but you will need to run a remote turn on from the harness (blue wire). but any harness you get should have it.
or you can gheto it and bridge the batt cable with a smaller guage wire and kill your battery every 8 hours lol.
Jmhm17 is offline   Reply With Quote
Old 07-17-2012, 10:37 PM   #304
pinkrobe
Member#: 55447
2002 WRX wgn/'10 STI
WRB/grey
Just did this install based on the OP's instructions. So easy! Thanks!
I haven't had a chance to drive around, but in the confines of my garage it kicks ass. I even called my wife from the car using the built-in Bluetooth. This is easily one of the easiest installs of anything I have ever done.
pinkrobe is offline   Reply With Quote
Old 07-22-2012, 07:32 PM   #305
Krieger88
Member#: 277043
2007 2.5i
Obsidian Black
God dammit I got rid of my iphone and got the new samsung galaxy s3 and its not compatible via usb but only through blue tooth. Horse poop I say, anyone know if theres a way around this?
Krieger88 is offline   Reply With Quote
Old 07-22-2012, 08:28 PM   #306
StackSmasher
Member#: 316928
2012 STI limited
I have a sgs2 skyrocket and have never used it via usb with my 4400bh.
However I am pretty familiar with most things android.
Make sure USB debugging is enabled in the phone settings.
Also on my skyrocket I have to turn USB storage on manually when the phone detects a USB connection. Make sure you try both of those.
Also grats on trading up from the iPhone.
StackSmasher is offline   Reply With Quote
Old 07-22-2012, 10:49 PM   #307
Krieger88
Member#: 277043
2007 2.5i
Obsidian Black
I finally got sick of the iphone and ATT being a mediocre combo, when the dock port broke on my original iphone 4s I went to Apple and they just handed me a new one, so I decided then was a better chance than any to have a sellable phone and try out an Android. So far it's a million times better. Faster, bigger screen, more freedom. Just have to figure out a solution to this usb to the 4400bh and I'll be golden
Old 07-22-2012, 10:59 PM   #308
badz
Member#: 297312
2011 WRX Hatch
Dark Gray Metallic
What's wrong with bt?
Grats on your new phone.
badz is offline   Reply With Quote
Old 07-23-2012, 03:54 AM   #309
Krieger88
Member#: 277043
2007 2.5i
Obsidian Black
Idk I feel like there's a quality and a volume difference. And also i want the screen to be used as it is intended to..
Old 07-23-2012, 07:01 AM   #310
badz
Member#: 297312
2011 WRX Hatch
Dark Gray Metallic
Check out this article about the different connection options.
As for the numbers, Bluetooth transmissions are full-bandwidth, having a frequency response of 20-20k Hz... As a high-quality, short-range, digital transmission, the Bluetooth process itself should have little or no impact on the sound quality.
As far as getting the meta data to show on the screen I totally understand. I'm not sure what kind of support the GS3 has for that out of the box, but I would keep an eye on the big named custom roms out there like CM and AOKP. My Galaxy Nexus didn't support meta data over the BT when I bought it, but these guys developing the custom roms are awesome and actually coded in support. Now I get full details on my screen when streaming BT when I play the music app.
Just some food for thought. Fulfilling your personal preference is the name of the game
Old 07-23-2012, 11:53 AM   #311
badz
Member#: 297312
2011 WRX Hatch
Dark Gray Metallic
I know you're leaning towards the USB route, but since this is related to what I posted early this morning I figured I'd link it here for you.
http://www.droid-life.com/2012/07/23...ons-galaxy-s3/
It looks like both CM and AOKP are definitely making their way to your new Galaxy S3.
Old 07-23-2012, 11:52 PM   #312
Krieger88
Member#: 277043
2007 2.5i
Obsidian Black
Very informative, thank you. You'd think there would be a solution where you can upgrade your head units firmware to where it supports androids fully. :[
Old 07-24-2012, 12:00 AM   #313
Krieger88
Member#: 277043
2007 2.5i
Obsidian Black
I think the worst thing of all of this is that I had bought the special plug for the head unit too,not even opened yet.
Old 08-15-2012, 11:10 AM   #314
Ying
Member#: 166490
2011 WRX
This is probably a dumb question guys, but is there any possible way to play phone navigation via Bluetooth from any mode except the Bluetooth Audio mode? I'm guessing no since they probably want you to either upgrade to a Nav unit or spend tons of money on the AVIC-U220 Nav adapter. Just figured I'd ask.
Ying is offline   Reply With Quote
Old 08-15-2012, 11:15 AM   #315
slowhat
Member#: 304175
2012 WRX Limited
PBP
do you mean have it play via bluetooth while you use another source?
slowhat is offline   Reply With Quote
Old 08-15-2012, 11:57 AM   #316
Ying
Member#: 166490
2011 WRX
Yes, correct. Radio, CD, or Ipod for example.
Old 08-15-2012, 12:04 PM   #317
slowhat
Member#: 304175
2012 WRX Limited
PBP
unfortunately not. however from a phone....google music works while nav is running. doesn't show info on h/u screen, but it's something.
Old 08-15-2012, 01:48 PM   #318
Ying
Member#: 166490
2011 WRX
Yeah that's what I figured. I do have some music on my phone but I'd have to keep changing it out. Maybe I'll actually sign up for Spotify or something. Thanks slowhat. I figured you'd know the answer.
Old 08-15-2012, 01:55 PM   #319
slowhat
Member#: 304175
2012 WRX Limited
PBP
upload everything to Google Music. I've got all 18000 of my songs following me around in the cloud at all times.
Old 08-15-2012, 02:03 PM   #320
Ying
Member#: 166490
2011 WRX
Interesting. I'll have to look into that. Not sure why I wasn't aware of Google Music...I mean...they do everything else.
Old 08-15-2012, 06:41 PM   #321
badz
Member#: 297312
2011 WRX Hatch
Dark Gray Metallic
Yes, google music "all the things"!
You can then access your music without it being locally stored (I'm assuming you have an android device?).
Also if you you have a phone that is supported by either AOKP or CyanogenMod, they have actually enabled metadata over bluetooth, so when listening to your google music songs all the info gets properly sent to your Pioneer's display
Old 08-16-2012, 08:55 AM   #322
Ying
Member#: 166490
2011 WRX
I have a Droid Bionic and the other stuff you said is over my head.
Old 09-12-2012, 02:57 PM   #323
bagofpucks19
Member#: 330096
Thats one clean install. Well done.
bagofpucks19 is offline   Reply With Quote
Old 09-29-2012, 12:21 PM   #324
OldPilot
Member#: 332894
I recently put an AVH-P4400BH in my 2012 Impreza Limited. It was a painless install. Get in touch with David Carter for the correct 20-pin harness and ASWC. The hardest part of the install was fishing the remote mic cable. If anyone wants to know which flash drive to use with the Pioneer, I had to try many. The OCZ Diesel and the PNY Attache (the oldest version your can find) work flawlessly.
OldPilot is offline   Reply With Quote
Old 10-02-2012, 10:14 PM   #325
CosmicLiability
Member#: 302939
2008 Outback XT
VF52'd
16.2 mpg.. lol
Thanks for the writeup!
CosmicLiability is offline   Reply With Quote
Clutch "clicking" in 2012 wrx STIDAWG Transmission (AT/MT) & Driveline 7 03-16-2013 11:22 PM
Where to ground in 2012 wrx hatch? slowhat Car Audio, Video & Security 3 02-24-2012 11:35 PM
pioneer avh-p4000 install in 06sti nation1979 Car Audio, Video & Security 25 02-26-2009 01:47 AM
Pictures of Hid's installed in '02 WRX :) paultg New England Impreza Club Forum -- NESIC 7 12-16-2001 04:22 PM
Found out a short throw shifter wasn't installed in my WRX.. cout Bay Area Impreza Club Forum -- BAIC 5 05-03-2001 05:59 PM
