Old 02-27-2012, 02:20 AM   #1
Scubaru23
Member#: 255582
Default Broken Valve Cover Gasket Bolt
So I was replacing my valve cover gasket and I swear it's just my luck that I broke a bolt. I need suggestions on how to get it out or what I'm going to have to do to fix it. It's the bottom right bolt. #4 on the picture. I can't get a drill down the far because of the car's frame. Basically no part of the threads are showing and the bolt broke pretty much where the threads begin. I'm at a loss of what to do. Thanks!
http://i1018.photobucket.com/albums/...Cover056-1.jpg
Scubaru23 is offline   Reply With Quote
Old 02-27-2012, 11:02 AM   #2
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
wow, that really sucks. how the hell did you break this bolt?
you may be pulling an engine. time for a clutch, timing belt, flywheel, etc!
is there ANY way to grab the rest of the bolt? take off the cover. can you clamp on a pair of vice grips?
can a nut be welded onto the stub?
Old 02-27-2012, 11:09 AM   #3
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
take the cover off and unscrew it...common issue....when they are over torqued.....
torque is very little---i dont have my fsm available now....but IIRC it is 6.6ft-lbs...which isnt much
no gorilla torque is needed or wanted on these
Old 02-27-2012, 02:18 PM   #4
rextech255
Member#: 247116
2007 Impreza WRX STi
I did this exact same thing. I've definitely learned my lesson since, but I ended up taking my head off and sending it to a machine shop. After trying to use an extractor bit first, the bit broke off in the head.. so I had no other option.
rextech255 is offline   Reply With Quote
Old 02-27-2012, 08:06 PM   #5
Scubaru23
Member#: 255582
So I took the valve cover off and there isn't any part of the bolt that's sticking out. Basically, I'm at a loss of what to do. I definitely want this fix to be as cheap as possible.
Old 02-27-2012, 08:27 PM   #6
rextech255
Member#: 247116
What I would do, is get a right angle pick and try to get the broken bolt loose. Go around the outside of the broke bolt in counterclockwise circles. You may be able to catch something and get the bolt to turn out.
Old 02-27-2012, 10:56 PM   #7
Uncle Scotty
Member#: 16200
OK buy Nates beans
and/or find a reversable right angle drill and some stubby left hand bits
I know they exist...I have used them
or pull the motor
Old 02-28-2012, 02:11 PM   #8
classicaddict
Member#: 220619
04 wrx wagon
Scott's right. Reverse drive bits will work. It broke past the shoulder correct? If so there should be no tension holding it in. The reverse bit will spin it out once it finds a spot to grab. If you mess the threads on the head up just helicoil some new threads in. Your biggest issue will be space.
Either pull the engine or use a jack and lower the cradle a tad with everything attached. Just pull any lines that may over extend like fuel lines.
classicaddict is offline   Reply With Quote
Old 02-28-2012, 04:12 PM   #9
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
I agree with the previous posts but also you could remove motor mount nuts and move the engine over for more room.
Old 02-28-2012, 11:57 PM   #10
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
pulling the motor would be the absolute best bet for visibility to center the bit
fastnoypi is offline   Reply With Quote
Broken Valve Cover Bolt future_subaru_owner Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 11-09-2011 12:04 PM
brand new valve cover gaskets/valve cover bolt grommets ('92 legacy L) shoodoggy Legacy Specific Parts 1 01-19-2010 02:13 AM
where to find 94 wrx valve cover gaskets!?!? czo79 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 05-28-2003 11:25 PM
2 things here. cooling fans/ valve cover gaskets solarsvx South East Region Forum 1 01-21-2003 03:27 PM
valve cover gasket replacment biggreen96 Service & Maintenance 0 02-11-2002 09:50 PM
