Old 02-27-2012, 07:43 AM   #1
MDRSK
Member#: 226510
2001 Legacy GT
Default Brake pedal grounding issue?
Have a little problem. I thought I posted it here before and received good advice that it was a bad alternator so I replaced with new (rebuilt) one from AutoZone. I just cannot find that post. Maybe someone else posted it and I just read it, but I still cannot find it.
Problem went away but has since returned. Checked volt reading at off (~12.3) and then charging (~13.5) so all seems good with battery and alternator.
The problem is that when I press the brake pedal, the interior dash lights (including radio) go off.. actually they are very dim. I release the brake pedal and the lights are fine again. If the headlight switch is turned on (i.e. not just DRL), the issue is non-existent.
I suspect it has something to do with a bad ground connected to the brake pedal but wanted to ask you guys if you ever experienced this before. If so, is there a simple fix?
BTW, my 2001 went over 200K miles last week. Actually that momentous event occurred when I was completing the 60 hours of practice driving required in Maryland for new drivers for my 17 year old son. Hard to imagine that he was only 7 when I bought the car from the dealer, and here he is driving it for the past year. Car runs great, but for minor issues such as: this lighting one, a rear speaker that does not work, and the rear differential thud I posted about previously.
I really like my Legacy.
Thanks!
MDRSK is offline   Reply With Quote
Old 09-20-2012, 10:28 PM   #2
Onewordman
Member#: 332827
I have the same problem now. Did you find out what is wrong? I've been searching online for weeks now. Car is dead on the driveway. I've had it towed 3 times in 2 weeks. Whatever it is killed my starter and battery, but alternator is ok.
Onewordman is offline   Reply With Quote
Old 12-11-2012, 10:04 PM   #3
MDRSK
Member#: 226510
2001 Legacy GT
In case you are still interested I sent you a PM. For the rest who may read this, problem ended up being a bad connection located in the trunk area where the rear lights are. Shop I took it to figured it out.
Also had the thud issue fixed as well with rear differential mount. Also ended up getting H&R lowering springs and KYB struts and shocks for my son so he would not be embarrassed driving it. Kids are so silly.
FS:STi complete gas pedal & clutch/brake pedal covers. joe r Interior/Dressup/Audio & Security 11 12-27-2009 08:08 PM
04 manual shift boot piece. Gas pedal, auto brake pedal and auto shifter assembly scOOtNsOOby Interior/Dressup/Audio & Security 0 10-12-2009 10:05 AM
Clicking Sound When Turning and Brake Pedal Pressure Issue WebMasterP Brakes, Steering & Suspension 14 10-11-2008 05:38 AM
Brake Pedal Issue Bearkat Brakes, Steering & Suspension 7 04-03-2006 04:56 PM
Pedal to the floor! Brake pedal that is. elcorazon01 Subaru Conversions 5 06-21-2005 01:48 PM
