Welcome to the North American Subaru Impreza Owners Club Tuesday May 5, 2015
Go Back   NASIOC > NASIOC Classifieds > Vendor 'General Sale' Forum
Closed Thread
Old 02-27-2012, 10:41 AM   #1
AJW Performance
Vendor Sales Rating: (38)
Member#: 219896
Default Our Biggest sale yet! GrimmSpeed,WBR,Mishimoto,Engine parts,coilovers and more
Hello! Thanks for shopping with AJW Performance Products! If you dont see what you're looking for in this thread chances are its sitting here in our shop so just ask and well be sure to hook you up with a great deal!
Not only do we offer parts; we also offer a full array of performance and maintenance services for your vehicle at our facility in Wareham, Massachusetts. Our location is only 40 minutes from Boston, 20 minutes from Cape Cod and 45 minutes from Rhode Island. You name it we can get the job done for you in a timely manner, at a great price with great quality. Call if you have any questions and well be happy to help you out!
Subaru 11mm Oil pump
This is the OEM 11mm oil pump for 2.5L engines; it is well made and priced right too. We strongly suggest replacing your oil pump when ever you need to replace the timing belt or if you are having any sort of engine internal work done to your Legacy. This is a must change item when building your motor.
ARP uses a premium grade 8740 alloy that is rated far superior to "aircraft" quality. Each stud is placed vertically in special racks and precisely heat-treated to 190,000 psi, ensuring complete heat penetration.Following heat-treat, each stud is centerless ground to make it as close to perfectly concentric as possible. This procedure involves about ten very slight cuts and results in an exceptionally straight part.
ARP studs are manufactured to such exacting tolerances, you will note that gaskets and cylinder heads literally glide into position and are perfectly aligned. ARP studs are thread rolled after heat-treat, which gives them about 1000% (that's ten times) better fatigue strength than those studs that are threaded prior to heat-treat (a very common industry practice). It costs a lot more to do it this way, because it's tough on tooling, but the results are well worth the extra effort. Premium quality parallel ground washers are also included with each kit. ARP head studs are a must for performance engines seeing increased boost, and they are truly the best on the market for your Subaru motor build
CP forged pistons feature superb ring seal, higher vacuum, lower blow-by, greater durability and increased horsepower and torque through the power band. Better yet, peak horsepower is retained through the life of the piston rings. This is achieved by lightweight forgings and CP's exclusive machining techniques and processes. CP's commitment to racing is reflected in every piston they produce.
CP is dedicated to superior engineering, utilizing the latest forging techniques and CNC machinery and backing it up with rigorous quality control makes for a top-notch product every time that emphasizes performance and reliability. CP has some of the highest quality control standards in the industry. CP is a division of Pankl Racing Systems, a high-technology racing group supplying engine and suspension components to numerous Formula One, F3000, IRL, CART, World Rally Racing teams and to such elite companies as Ferrari and Porsche. You will not find a finer piston for your EJ25.
CP offers optional coatings to enhance the effectiveness of your pistons. The top coating is designed to reflect heat into the combustion chamber, thereby increasing exhaust gas velocity and greatly improving scavenging potential. The skirt coating offers additional lubricant in times of extreme heat or heavy wear situations. The coating is designed to reduce friction on the skirt by providing a buffer to the cylinder. Coating options are applied to the entire set and add 4-6 weeks to the order time.
Eagle Rods- also available Manley rods, Carillio + more
Eagle's Subaru connecting rods are made from 4340 steel, x-rayed, magnafluxed, sonic tested, and shot-peened to ensure optimal quality and strength. They are packaged in weight-matched sets that are within +/- 1 gram end to end. The Eagle connecting rods undergo a 2-piece forging process in China and are then shipped to the US for final machining and testing; making for a cheaper rod that is durable and precise. Eagle's EJ25 rods include ARP 3/8" 2000 rod bolts for extensive ability to handle power and boost. 5.137" rod length.
Subaru OEM full engine gasket and seal kit
Whenever doing head or short block engine work, it is very important to replace old or worn engine gaskets. Nobody wants to have to pull an engine because they forgot to replace an old seal or gasket. You can save time and money with a genuine Subaru OEM full gasket and seal kit for your Subaru. These kits come complete with every gasket or seal that you could possibly need when doing any level of engine work including, head gaskets, valve cover gaskets, spark plug O-rings, intake manifold gaskets and more. The full kit contains over 160 individual gaskets and seals. We strongly suggest this kit for any engine swaps, rebuilds, or upgrades.
Gates Timing belt kits including water pump, tensioner and all 4 idlers-Best possible pricing at AJW Performance.
The Gates Replacement Timing Belt Component Kit for your Subaru is a complete set of components needed for replacing the timing belt, water pump and pulleys. Gates has assembled a kit including the pieces that are commonly replaced during routine maintenance or when doing an engine swap: Four pulleys (A, B & C), belt tensioner (D), water pump (E), and a timing belt (F). Gates manufacturers all of the included components to OEM quality standards, so you know they will perform for a long time. The Gates pulleys are also available individually, below, and the water pump can be purchased separately. If you are looking for even more performance, pick up a Gates Racing Timing Belt.
If you are looking for even more performance, go with a kit that includes the Gates Racing timing belt. 300% stronger than a stock belt and featuring three times the heat resistance over standard rubber belts under high-load conditions, the racing belt is optimum for high horsepower builds or those looking for maximum longevity.
The OEM Subaru crank pulley has been a cause for concern ever since its original design. It is extremely heavy, susceptible to catastrophic failure, and won't help you win any awards for appearance. Enjoy a free revving motor due to a reduction of 3.5lbs of rotational mass while not worrying about reliability. GrimmSpeed really pulled out all of the stops for this Lightweight Crank Pulley. CNC machined from 6061 T6 Aluminum and anodized in a finish of your choice, this pulley makes no compromise. A timing mark and a perfectly cut keyway makes installation a breeze. This pulley was designed with the optimum weight for performance while avoiding misfire CEL's and engine hesitation. Achieving balance between performance and design while not sacrificing either is what you can expect from GrimmSpeed!
GrimmSpeed has a unique design which allows you to keep your PCV valve while separating the oil out of the crankcase and head ventilation air. None of the other competitors on the market are able to vent both. The unit is very compact and efficient, it bolts directly on to the factory oil cap location. You will no longer have to keep tabs on your oil level and or empty the catch can like on most standard cans as this unit is self maintained which requires no maintenance at all. GrimmSpeed's AOS uses a baffling system that is unique to their unit only and does not allow oil back out of the can. You will only see clean air exit and never have to worry about oil blow by again! This unit prevents reduced fuel octane, engine knock, and worse emissions that are caused by oil in the system. This item is a winner in every aspect and is perfect for completely stock cars to full out race cars.
NGK Spark plugs available in stock heat or 1 step colder-Sets of 4
More Durability and a Higher Melting Point compared to Platinum, better center electrode anti-oxidation and anti-erosion, improved ignition, superior anti-fouling, lower required voltage, new metal shell plating process for better anti-corrosion. One Step Colder plugs are recommended for cars with heavy modifications. These NGK plugs will get your Turbo Subaru running smoother and free up some power through increased efficiency and increased heat resistance. These are available in stock heat or one step colder for cars running approximately 100 horsepower more than stock.
ISC Coilovers always in stock at AJW!
Available for every year and make Subaru, Mitsubishi, Honda, BMW, Nissan/Infiniti
Street sport or track race spring rates + custom spring rates/valving available at no additional cost.
__________________
Best Pricing and Customer Service in the Business!
Shop Line: 603-715-9076
Hours:
Monday- Friday Closed weekends
9:00 AM to 5:00 PM at shop
21 Meadowbrook Ln
Unit 10
Gilford, NH 03249
Open until midnight via website/email/internet
Your Forum Reps are Allen, and Jorel!
facebook us: "AJW Performance"
Follow some of our work-
AJW Performance is offline
Old 02-27-2012, 10:52 AM   #2
AJW Performance
Member#: 219896
WBR Products in stock!
PM for more details!
In stock, Headers, Intakes and a couple FMIC kits. These headers are good for 380-400 WHP. Twin Scroll setups available for 500 or better whp. Fits 2 bolt, 3 bolt and 4 bolt uppipes (WBR). Intakes are available in 2.75 and 3" options with a huge Green filter, reusable, two layers of woven cotton with a steel mesh over the top.
If you want to go fast with American made quality products, you have come to the right place! WBR Performance products available only at AJW
Mishimoto Radiators in stock. What a great cooling setup to have!
Lifetime warranty and crash replacement, show me another company with a policy like that!!
Add a Mishi Fan shroud for 1XX.xx
__________________
Hours:
21 Meadowbrook Ln
Unit 10
Gilford, NH 03249
Old 02-27-2012, 10:57 AM   #3
AJW Performance
Member#: 219896
Process West Intercoolers in stock for Legacy GT and 08+ WRX/STi
Brian Crower Cams, Spring and retainers in stock. Stage 1-4
Also GSC Power Division products in stock here!!
2011 STi short blocks in stock always! Ready to ship or ready for us to build onto, your choice.
__________________
Hours:
21 Meadowbrook Ln
Unit 10
Gilford, NH 03249
Old 02-27-2012, 11:14 AM   #4
AJW Performance
Member#: 219896
Were now direct with Killer B Motorsports and their high quality line up. Have questions? Just ask. Keep that motor lubricated with the best in the biz!
Ask any questions you have!
__________________
Hours:
21 Meadowbrook Ln
Unit 10
Gilford, NH 03249
Old 02-27-2012, 03:23 PM   #5
morphiusrt
Member#: 307707
1999 Impreza Outback
I'm getting the itch. I need to put my coilovers on soon!!
morphiusrt is offline
Old 02-27-2012, 04:02 PM   #6
ferrari slayer
Member Sales Rating: (1)
Member#: 295536
06 STi
PM Sent!!
ferrari slayer is offline
Old 02-27-2012, 04:37 PM   #7
AJW Performance
Member#: 219896
PM sent back Kevin! Bring the STi by sometime btw!
Killer B Motorsports products now being offered here at AJW Performance. Let me know if you have questions about their parts or would like to order something
__________________
Hours:
21 Meadowbrook Ln
Unit 10
Gilford, NH 03249
Old 02-28-2012, 10:41 AM   #8
AJW Performance
Member#: 219896
Just build a new motor? Dont use your old, possibly damaged oil system parts. Use brand new, tested and proven Killer B Motorsports products. We have these bad boys ready to rock!
The Pickup:
The windage:
The pan:
Available separately or as a package offering!! Let us know how we can help you!
__________________
Hours:
21 Meadowbrook Ln
Unit 10
Gilford, NH 03249
Old 02-29-2012, 10:38 AM   #9
AJW Performance
Member#: 219896
Here for the day! Lets get you going faster today!
Tell us what you need and well hook you up with a great price
__________________
Hours:
21 Meadowbrook Ln
Unit 10
Gilford, NH 03249
Old 03-01-2012, 10:58 AM   #10
AJW Performance
Member#: 219896
Big time sales. Let us know what you need and well be happy to help
__________________
Hours:
21 Meadowbrook Ln
Unit 10
Gilford, NH 03249
Old 03-02-2012, 09:02 AM   #11
AJW Performance
Member#: 219896
First person to claim first buyer in this new thread will get something for free! Let me know what you need.
__________________
Hours:
21 Meadowbrook Ln
Unit 10
Gilford, NH 03249
Old 03-05-2012, 11:02 AM   #12
AJW Performance
Member#: 219896
Here all day to help! Let us know if you have any questions
__________________
Hours:
21 Meadowbrook Ln
Unit 10
Gilford, NH 03249
Old 03-06-2012, 01:10 PM   #13
AJW Performance
Member#: 219896
Here all day! Coilover deals at AJW Performance
__________________
Hours:
21 Meadowbrook Ln
Unit 10
Gilford, NH 03249
Old 03-07-2012, 10:42 AM   #14
AJW Performance
Member#: 219896
Doing a sale today on GrimmSpeed External Wastegate tubes and Tial Wastegates! Let us know if you have any questions about it!
__________________
Hours:
21 Meadowbrook Ln
Unit 10
Gilford, NH 03249
Old 03-08-2012, 10:56 AM   #15
AJW Performance
Member#: 219896
Have questions about any of the parts you see here? Let us know. Have questions about the benefits of a part let us know. Were happy to help
__________________
Hours:
21 Meadowbrook Ln
Unit 10
Gilford, NH 03249
Old 03-09-2012, 03:32 PM   #16
AJW Performance
Member#: 219896
Here for the day
__________________
Hours:
21 Meadowbrook Ln
Unit 10
Gilford, NH 03249
Old 03-12-2012, 09:33 AM   #17
AJW Performance
Member#: 219896
Let us know if you have any questions. Starting this week off on the right foot with tons of sales!
__________________
Hours:
21 Meadowbrook Ln
Unit 10
Gilford, NH 03249
Old 03-13-2012, 07:56 AM   #18
AJW Performance
Member#: 219896
Good morning!! Here to get the deals going today. Call in and ask Andrew about his pink socks and get a better deal from me!
__________________
Hours:
21 Meadowbrook Ln
Unit 10
Gilford, NH 03249
Old 03-14-2012, 10:29 AM   #19
AJW Performance
Member#: 219896
Motor build parts available here! Lots of experience and advice so ask if you have questions
__________________
Hours:
21 Meadowbrook Ln
Unit 10
Gilford, NH 03249
Old 03-15-2012, 11:00 AM   #20
AJW Performance
Member#: 219896
Here to help customers that want or need to build a motor. From Hybrids to fully built race motors we know how to get it done!
__________________
Hours:
21 Meadowbrook Ln
Unit 10
Gilford, NH 03249
Old 03-16-2012, 04:37 PM   #21
AJW Performance
Member#: 219896
Get your SMY clusters here! Bunch in stock.
GrimmSpeed parts here in stock. Tial and TurboSmart Wastegate deals. Manual boost controllers in stock. Red, blue or black. EBCS in stock as too. All makes.
Thanks for a great week everyone!
__________________
Hours:
21 Meadowbrook Ln
Unit 10
Gilford, NH 03249
Old 03-19-2012, 09:56 AM   #22
AJW Performance
Member#: 219896
Here on Monday with the best deals possible. Fully built motors available here!
__________________
Hours:
21 Meadowbrook Ln
Unit 10
Gilford, NH 03249
Old 03-20-2012, 11:52 AM   #23
AJW Performance
Member#: 219896
here for the day with the best deals!
__________________
Hours:
21 Meadowbrook Ln
Unit 10
Gilford, NH 03249
Old 03-21-2012, 09:53 AM   #24
AJW Performance
Member#: 219896
Here for the day!
Doing a couple package deals on Killer B parts today!
Killer B pickup and windage tray
Killer B pickup, windage tray and Oil pan
Killer B Pickup, windage tray, oil pan and 11mm STi oil pump
__________________
Hours:
21 Meadowbrook Ln
Unit 10
Gilford, NH 03249
Old 03-22-2012, 09:56 AM   #25
AJW Performance
Member#: 219896
Got the parts you need to go fast! Have questions? Just ask! Were here to help.
__________________
Hours:
21 Meadowbrook Ln
Unit 10
Gilford, NH 03249
Closed Thread
FS : sti stuff exhaust parts coilovers and more flyers7732 MAIC Private Classifieds 9 09-16-2010 11:16 AM
Engine part out-FMIC-Inlet-Walbro and more brandonbeeb Engine/Power/Exhaust 25 02-11-2008 06:11 PM
STi version 7 engines parting out and more.... FLAT4motorsports Engine/Power/Exhaust 21 03-13-2005 06:41 PM
