Old 11-14-2012, 01:50 PM   #76
wondras
Member#: 337076
2013 XV Crosstrek
Default Through Mode is flat!
Excellent news -- Through Mode is indeed flat in both the front and rear channels!
I did some initial testing with a CZ624U1, using a makeshift line-out converter. Here is a frequency response comparison between the Sedan and Through Mode settings:
With loudness turned off, the response stays the same regardless of volume level.
Through Mode is flat to within 1 dB from 40 Hz to 20 KHz. The actual low-end response is slightly better than what's shown here; the capacitor in my LOC was on the small side, which caused some extra rolloff.
Looks like Sedan gives the fronts a +3 dB boost at 80 Hz, and a -7 dB cut at 250 Hz. The rears have a -9 dB slope from 1 KHz down to 125 Hz, then a quick rolloff below that.
Results for Wagon mode were identical to Sedan, so they are not shown here. (I'm guessing that both settings are there to be consistent with what they've done for other models, even though there are no differences in this case. The DSP chip in this unit can actually be programmed to do time alignment, dynamics compression, etc., but it seems highly unlikely they'd use them.)
Note that you will have quite a bit more bass going to the rears in Through Mode, so you may want to make sure you're not overdriving them, and fade more to the front if necessary.
As for the loudness function, here's what happens at various volume levels when it is enabled:
With the volume set to 12, there is an 11 dB boost to the low bass, and an 8 dB boost to the high treble. The boost decreases as you turn it up, until it is flat by a volume setting of 35. The decrease is slow until you turn it pretty far up, where it falls off more rapidly. This explains why at medium volumes it has so much "boom and sizzle."
The loudness and fixed EQ are both rather heavy-handed, but it's really the combination of the two that makes it so awful. Hopefully these results will be helpful when deciding what adjustments to make.
wondras is offline   Reply With Quote
Old 11-14-2012, 02:43 PM   #77
RM_2
Member#: 163058
'16 BRZ Limited WRB
'06 Saab 9-2X 2.5i NGM
Never in my life would I have thought there would be a frequency response graph on a car forum. This brings me great happiness as an electrical engineering graduate and as an audiophile
RM_2 is offline   Reply With Quote
Old 11-14-2012, 02:51 PM   #78
erik11876
Member#: 275888
2011 WRX Limited
It almost appears as though this should be set at the factory or at the dealership and it never gets done. Weird nonetheless. Thanks to all that figured this out!
erik11876 is offline   Reply With Quote
Old 11-14-2012, 03:16 PM   #79
dsn112
Member#: 332561
2016 WRX LTD
So through mode and loudness off is the way to go
dsn112 is offline   Reply With Quote
Old 11-14-2012, 03:20 PM   #80
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
I like loudness on, if I had different speakers with better mids, I would go loudness off.
Through mode for sure
Old 11-14-2012, 05:46 PM   #81
dsn112
Member#: 332561
2016 WRX LTD
With everything off the way I have my Lc2i and jL XD amp set it really does sound great on CD and BT audio. Fm still sucks, but I don't care. Aux in which is use most for Sirius sounds ok, can't tell if that's the Sirius quality or the aux in itself.
Old 11-14-2012, 05:48 PM   #82
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
i would blame Sirius. i have never tried CD, but BT/AUX sound the same on mine, and SAT(i have a forester radio transplanted) depends a lot on the selected station.
Old 11-15-2012, 01:20 AM   #83
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
Great job! :beer:
Originally Posted by erik11876 View Post
It almost appears as though this [turning off the nasty EQ] should be set at the factory or at the dealership and it never gets done.
Actually, I think the HUs were specifically designed with this feature to A) prevent the rear speakers from rattling the rear doors, and B) protect the rear speakers from getting blown. Subaru models have had this "feature" for several years now. I suspect it's why the OEM under-seat sub's harness was changed so that it taps the front speakers many years ago.
SVXdc is offline   Reply With Quote
Old 11-15-2012, 12:02 PM   #84
DarkProphet
Member#: 299707
2011 Wrx 5-Door
Holy crap guys!!! I'm the OP, and haven't checked this thread in awhile and am so excited to see this. You made my day!!!!!
DarkProphet is offline   Reply With Quote
Old 11-16-2012, 02:45 PM   #85
mejifair
Member#: 11356
2012 WRX STi Hatch
So totally awesome. I have upgraded everything but the HU in hopes that there were menu settings. Cannot wait to try this after work!
THANK YOU
mejifair is offline   Reply With Quote
Old 11-16-2012, 11:55 PM   #86
Scoob_Noob
Member#: 308149
2012 WRX 5-door
WR Blue Pearl
So before we messed with this, the default settings were Loudness ON and EQ Sedan (or Wagon) correct? It appears that Sedan and Wagon are essentially the same, so one of those was the default value before i changed anything, right?
Scoob_Noob is offline   Reply With Quote
Old 11-17-2012, 10:45 AM   #87
redline23
Member#: 285799
2012 WRX 5-Door
Yes, Loudness On and Sedan or Wagon depending on the car you have are the default settings.
redline23 is offline   Reply With Quote
Old 11-18-2012, 01:34 PM   #88
dsn112
Member#: 332561
2016 WRX LTD
So after much tuning with my JL xd400/4 and my audiocontrol lc2i, I am finally happy with what I am getting out of my stock headunit. I have loudness off and through mode set. Even FM mode is dramatically better.
My speakers are basic Kicker KS-60s in all four doors, pioneer tweets and an reaudio 10" in the trunk. I am amping the fronts and the sub, the rears are off the stock deck but I put bass blockers in so they don't distort at all. I tapped the fronts for the lc2i and run the focus towards the fronts +4
Old 11-18-2012, 04:11 PM   #89
randysubie
Member#: 301788
2012 wrx
lr
Default codes?
Thanks guys this thing sounds better and keeps a flat curve no matter the volume, but while trying to get the modes i hit a sequence of 6 & text i think and these numbers came up
does anyone know what these are
M 272510v073,
E TEST VER
0,
E MAP TYPE
3,
EEP VER
014001V002,
S FROM VER
C310,
HF PARM
023501V002,
BT FW
BC310 AC310,
BDAD
000704AF64DE,
B 272801V009
I0200 .......
randysubie is offline   Reply With Quote
Old 11-19-2012, 11:24 AM   #90
wondras
Member#: 337076
2013 XV Crosstrek
Those are version numbers for various firmware/hardware components in the unit. I'm guessing EEP = EEPROM, HF = Handsfree, BT = Bluetooth, BDAD might be Bluetooth digital audio device or something like that.
AFAIK this display is read-only, so there's nothing you can change. I wonder if there are any Subaru service bulletins that shed any light on the version info, or how to update it.
M 272510v073,
E TEST VER
0,
E MAP TYPE
3,
EEP VER
014001V002,
S FROM VER
C310,
HF PARM
023501V002,
BT FW
BC310 AC310,
BDAD
000704AF64DE,
B 272801V009
I0200 .......
Old 11-20-2012, 05:32 PM   #91
wondras
Member#: 337076
2013 XV Crosstrek
Default frequency graphs for Bass/Mid/Treble controls
To help a bit more with system tuning, I measured the effects of the bass/midrange/treble controls. It uses the typical frequencies of 100 Hz / 1 KHz / 10 KHz, with a +-12 dB range, as shown here:
One interesting quirk is that the change is not constant throughout the 0-8 range:
Lower settings are closer together, which is actually pretty nice. A lot of decks go in 2 dB steps, and I often wish that I could make a smaller change.
Another thing to note is that boosted frequencies are limited above a volume setting of 34. For example, at a volume of 35, moving the bass from +7 to +8 makes no difference. At 40, there is no boosting at all. Cuts still apply, though.
Old 11-20-2012, 05:53 PM   #92
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
How do the numbers look below 25? I think my typical setting is around 12-14, max of probably around 20 since I have an amp
Old 11-20-2012, 06:07 PM   #93
randysubie
Member#: 301788
2012 wrx
lr
thanks, yes more information on the version info would be cool
Old 11-20-2012, 07:40 PM   #94
lymphomaniac
Member#: 334451
2013 Impreza2.0i CVT
DGM (sedan)
Here's a bit of a random question: anyone know if it's possible to do some sort of "firmware upgrade" to make the unit display non-English (such as Asian, Greek, or Cyrillic) characters?
lymphomaniac is offline   Reply With Quote
Old 11-20-2012, 07:55 PM   #95
wondras
Member#: 337076
2013 XV Crosstrek
With loudness off, the tone controls should be constant across all volumes up to 34. (Presumably it starts limiting the boost above this point to prevent clipping/distortion.)
You might want to try adjusting your amp gain down a bit, though, if you have audible noise/hiss. You may get a bit less noise if your max is more like 25-30.
Old 11-20-2012, 10:27 PM   #96
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
I have a bit of white noise, but not enough to bother me. My max listening level is 25, but usually around 8-10 for in town, and 16-20 for the highway(I actually paid attention today, my numbers earlier were guesses)
Gain is set to 45% on my amp, and I still have loudness enabled because the stock speakers don't sound good w/o it, will try again tomorrow I have been driving this car exclusively now for a week and have fully adjusted to the radio. The setup in my other car is much better
Old 11-21-2012, 11:01 PM   #97
DarkProphet
Member#: 299707
2011 Wrx 5-Door
Does anyone run an amp off their stock head unit? Just wondering how it sounds now that we can defeat the EQ and Loudness??
Thanks all!
Old 11-21-2012, 11:26 PM   #98
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Thanks all!
i have an Alpine KTP-445U i run of the stock HU, it sounds so much better especially now that the EQ is disabled
Old 11-22-2012, 04:16 PM   #99
Krazyjohnny
Member#: 330435
I have the stock HU (624U1) in my 2013 WRX Hatch. I am using an Alpine MRX V50 amp bridged to the front Rainbow CSX 265 Components (Thanks phenryiv) and the sub channel goes out to a Nakamichi SP 100 10" sub in an Audio Integrations Perfect fit enclosure. I am using the head unit in "through mode" and with the Loudness on to get what is most appealing to me. I have installed Dynamat Extreme in the the doors on both the outer skin and the inner most skin. I also used the same product in the hatch floor. That alone made a big difference with the stock speakers. Stepping up to the Rainbows kicked it up another notch. The choice of the Rainbows was made for their absolute perfect fit into the front tweeter pod.
Krazyjohnny is offline   Reply With Quote
Old 11-22-2012, 05:39 PM   #100
dsn112
Member#: 332561
2016 WRX LTD
It's the alpine, I switched to a JL under the seat and no longer have the white noise. Wonder if it has anything to do with how close the amp is to the headunit
2011+ Impreza head unit into 2009? codingparadox Car Audio, Video & Security 6 12-31-2011 12:48 AM
2011 Stock Head Unit Audio Playlist Options cheezmunky Car Audio, Video & Security 2 12-02-2011 10:09 AM
WTB : WTB - non-navi 2011+ OEM Head Unit with Bluetooth. ofspunk7 Private 'Wanted' Classifieds 2 10-25-2011 12:40 PM
2011 STi head unit w/o nav RCA PORTS? sk8dc10 Car Audio, Video & Security 5 11-06-2010 10:01 PM
2011 stock head unit wiring question subiebosch Car Audio, Video & Security 10 10-08-2010 09:21 AM
