Old 02-28-2012, 12:47 AM   #1
kmook
Member#: 146168
2015 Impreza
Hi, I jumped on the Cobb SD day one and wanted to share some info and pictures to help others.
Review: So far I am super impressed by it. I am running my STI in full SD mode and completely removed the MAF. (Note you can keep the MAF and use it as your IAT sensor, but I'd rather get rid of that thing!) I wired in a GM IAT sensor and GM 3bar MAP sensor removing the stock MAP sensor on the throttle body as well. It is awesome to not have a MAF anymore. I am now also able to run a shortram intake right off my rotated turbo (basically a short piece of pipe with a nipple for my AOS). Also since there is no MAF I can run a super light spring in my Tial BOV (I went from the pink spring to the black spring lol) and have no flutter/surge under low boost shifting now.
Parts: The parts I used are the following, I prefer to use the GM sensors as they are good products and a great price:
GM IAT w/ Pigtail = http://www.diyautotune.com/catalog/g...tail-p-62.html $22.25
Alum 3/8" NPT Bung for IAT = http://www.diyautotune.com/catalog/3...sor-p-107.html $9
or Steel 3/8" NPT Bung for IAT = http://www.diyautotune.com/catalog/3...sor-p-231.html $9
GM 3bar MAP Sensor = http://www.diyautotune.com/catalog/m...sor-p-161.html $64
GM MAP Sensor Pigtail = http://www.diyautotune.com/catalog/m...ail-p-163.html $11.50
Wiring: After clipping the stock MAP sensor off connect the stock harness wires to the GM pigtail as follows:
GM 3Bar Letter / 3Bar Wire Color / Type / Stock Wire Color
A / Black Wire / Ground / Black&Green
B / Green Wire / Signal / Orange
C / Gray Wire / 5v Src / Red
After clipping the stock MAF sensor off connect the stock harness wires to the GM pigtail as follows:
GM IAT Wire Color / Stock MAF Wire Color
Red / Brown
Black / Green&Red
Capped Off / Yellow&Blue
Capped Off / Green&Black
Capped Off / Pink&Blue
Pics:
Stock MAF & Stock MAP
GM 3bar MAP and GM IAT
GM IAT Installed
New Streamlined Engine Bay
kmook is offline   Reply With Quote
Old 02-28-2012, 04:44 AM   #2
TwinscrollGT35R
Member#: 256810
Nice write up.
Thanks. What turbo set up are you running?
TwinscrollGT35R is offline   Reply With Quote
Old 02-28-2012, 08:46 AM   #3
kmook
Member#: 146168
2015 Impreza
Originally Posted by TwinscrollGT35R View Post
Nice write up.
Thanks, I'm running a Perrin GT3582.
Old 02-28-2012, 09:35 AM   #4
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
Any gains in power?
Old 02-28-2012, 09:39 AM   #5
kmook
Member#: 146168
2015 Impreza
Not sure, still working on the tuning more, and then I'll get it on the dyno. Though when I went with the Cobb SD I also changed to the Cosworth Intake so I wont be able to tell just from changing to SD if there was any gain. I'm not sure if Cobb even advertises there are power gains. I just did it to go full SD on the stock ecu and get rid of the maf.
Old 03-24-2012, 02:02 AM   #6
Big-Sexy907
Member#: 59057
2004 Impreza, STi.
kmook, where did you tap in the MAP sensor?
Big-Sexy907 is offline   Reply With Quote
Old 03-24-2012, 02:09 AM   #7
kmook
Member#: 146168
2015 Impreza
The GM unit just uses a 1/4" line, so you can tap it anywhere really. Since I have the Cosworth intake all my vacuum connections are on the top on the vacuum bar.
I removed the stock MAP sensor and tapped the hole and screwed in a bolt with an o-ring under the head. That isn't needed as most people can leave their stock sensor in place and unused, but it sticks up and interfered with my vacuum lines a little on the Cosworth manifold.
Old 03-24-2012, 03:44 AM   #8
TwinscrollGT35R
Member#: 256810
I'm on a twinscroll gt35r with a 1.06 hotside.
Originally Posted by juanmedina View Post
Any gains in power?
I'll know in the next few days. As mine was converted. I'll have a base and a after SD conversion.
My car had bad surging at light throttle. 6th gear cruising was useless and 5th part throttle or tip in around 3100-3200 rpm then again a 3900-4100rpm
Even with the anti-surge housing.
I'll know more over the next week or so.
Old 03-31-2012, 10:54 PM   #9
YZ86
Member#: 188705
GD Widebody STI
Lexus Pearl White
Cant wait to see the result. looking to run cobb sd too!
YZ86 is offline   Reply With Quote
FS : NJ: 02 wrx stock ecu 5 speed nickc919 Engine/Power/Exhaust 3 03-01-2012 01:42 AM
Utec SD injector settings when stock ECU is already flashed benw UTEC 10 04-08-2009 11:46 PM
WTB / WTT 2.5NA (Forester) my Cobb for your stock Pursuit Texas Impreza Club Forum -- TXIC 7 06-15-2004 04:16 PM
Selling my Cobb stage 2 reflashed ECU stephan Private 'For Sale' Classifieds 3 09-18-2003 09:50 AM
Who has the most powerful, stock ECU, no electronics WRX? BADWRX Proven Power Bragging 25 07-17-2002 10:18 AM
