Rocky Mountains Impreza Club
Go Back   NASIOC > NASIOC Chapters > Rocky Mountains Impreza Club Forum -- RMIC
Old 02-28-2012, 12:58 AM   #1
down2earthsubie
Member#: 171448
2003 wrx
psm
Default Brake problem on a 02 wrx
So my buddy has a 02 WRX with rs non ABS front brakes. We cannot get it to maintain brake pedal pressure. We replaced the master cylinder. Didn't fix it. Bench bled it too. No leaks anywhere. We cycled the ABS to try to work out bubbles in the ABS system. Nothing. It will build pressure for about 10 seconds then go straight to the floor. The whole system has new fluid we bled it so much. Gone through a 4 bottles. Anyone have any ideas? I think it has to do with the calipers. Anyone have any stock WRX calipers and rotors laying around? Or have an idea for us to test. Thanks.
down2earthsubie is offline   Reply With Quote
Old 02-28-2012, 01:13 AM   #2
MattTHEpainter
Member#: 284046
2000 Impreza w/ WRX
Did you make sure that the calipers are on the correct side. They should be marked "L" for drivers side and "R" for passenger.
MattTHEpainter is offline   Reply With Quote
Old 02-28-2012, 01:39 AM   #3
bhhamblin
n00b Moderator
Member#: 99397
15 WRX, 83 DR30,
93 R32 GTS-T, 93 R32 GTR
^^ Bleeders need to be facing upwards.
bhhamblin is offline   Reply With Quote
Old 02-28-2012, 01:53 AM   #4
08WhiteRex
Member#: 187453
2012 Mulletmobile
I've seen and heard of the proportioning valve messing up when a whole lot of air gets in the system.
08WhiteRex is offline   Reply With Quote
Old 02-28-2012, 02:44 AM   #5
azn2nr
Member#: 35276
maybe the abs is confused by the non abs brakes? though i dont imagine that would be the case as the abs sensors are on teh axles
azn2nr is offline   Reply With Quote
Hand brake problem on 02 wrx sedan millerlite1204 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 12-01-2011 07:19 PM
LGT Brakes on an 02 WRX problem Tut4u2 Brakes, Steering & Suspension 1 03-15-2010 07:51 PM
Oil problem on a 02 wrx 02vfWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 01-19-2008 05:42 PM
MAJOR problem on my 02 WRX - Power Stearing and Alt nick robinson Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 01-08-2007 08:52 PM
Turbo problem on a 02 wrx HotDrifter9 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 06-13-2006 09:55 PM
