Old 02-28-2012, 09:22 AM   #1
AVANTI R5
Member#: 73805
2016 Cayman GT4
black
Default The mighty mite we want but can't have. 2012 A1 Quattro
There are some special small cars that enthusiasts would kill for, including the mid-engined Renault 5 Turbo, the rear-drive Talbot Sunbeam Lotus, and just about any Group B World Rally Championship homologation car, such as the Peugeot 205 Turbo 16. Here's a potential new classic: the Audi A1 Quattro, priced at the equivalent of more than $55,000 and powered by a 256-hp turbo four. Production is limited to just 333 units. It will be by far the most powerful car in its class, the 208-hp Mini John Cooper Works being a distant second.
One Serious A1
In late 2010, an eight-person team came together to transform the VW Polo–based, front-wheel-drive Audi A1 into an all-wheel-drive high-performance monster. Previously, the A1 lineup was topped by a front-wheel-drive, 185-hp, 1.4-liter version, with a seven-speed dual-clutch automatic as the only available transmission. For the new top-dog A1, the engineers dug deep into the corporate parts bin and came up with the Audi TTS’s EA113 2.0-liter TFSI, MQ350 six-speed manual transmission, Quattro all-wheel-drive system, and rear suspension setup. This A1 offers no dual-clutch option, and it’s perfectly fine that way.
This car, after all, is serious business. We estimate the sprint from 0 to 60 mph will take 5.0 seconds; top speed is a drag-limited 152 mph, the result of aerodynamics tuned for downforce. When you fire it up, the A1 Quattro emits a sonorous hum, which turns aggressive as soon as you hit the throttle. The not-too-light clutch bites aggressively, but the transmission is exceptionally smooth and easy to operate. Punch the throttle and the four tires grab hard.
Its Quattro all-wheel-drive system is front-biased, but the setup can briefly force up to 100 percent of the torque to the rear wheels. Nevertheless, it takes aggressive turn-in and determined throttle action to induce power oversteer. If you’re not interested in playing drift king, the XDS system—a function of the stability control—can apply the brakes at each of the four wheels to better maintain your intended line through a corner. The XDS function stays active even with stability control switched off; those more comfortable with a safety net in place can select the Sport mode, which allows significant leeway before intervening. The electrically assisted steering is precise. Beefed-up brakes effectively keep speed in check, and sit behind 18-inch wheels wearing 225/35 Bridgestone rubber. Thanks to its excellent chassis, the A1 Quattro feels a lot lighter than its not-insignificant 3000 pounds would suggest.
As you can see, the A1 Quattro marks a significant aesthetic departure from its lesser kin. There are large front air intakes, similar to those on the monstrous Wörthersee A1 Clubsport Quattro concept. (Before you ask, that car’s 503-hp inline-five won't really fit in the production A1's engine bay.) The lower portion of the hatch is painted black, and there’s a huge wing on the roof. Exhaust gases exit through two polished four-inch pipes. Only the one color is available—Glacier White Metallic—with a black roof. The xenon lights feature a red "wing" that runs along the LED element. And about the wheels: They’re unique turbine-look pieces, styled like those on the Clubsport concept, complete with center lugs.
The interior is fitted with leather sports seats, a 280-kph (174-mph) speedometer, a bright-red tach, and a steering-wheel inscription that references the 333-car production run. It’s not an extremely comfortable car, but its one, fully equipped trim level does bring a number of luxuries. Included are automatic climate control; a large-screen navigation system; and a 14-speaker, 465-watt Bose sound system.
Big Changes for a Little Car
It was no easy feat to integrate all of the 600 modifications required to create the A1 Quattro—specifically, the bigger powertrain. For instance, Audi had to develop an entirely new gas tank that wraps around the driveshaft. But don’t think the company went through all of this trouble for a mere 333 cars. By 2013, there will be an S1, with the same all-wheel-drive system and a version of the 2.0 TFSI that will produce "more [power] than a Mini John Cooper Works," an insider promises. Figure on around 220 hp. Hopefully, the S1 will retain the A1 Quattro's six-speed manual, although an Audi development engineer intimates that the drivetrain could accommodate a dual-clutch automatic. And what about an RS1? Such a car may appear in the distant future, but we suspect that the A1 Quattro will be Audi’s mightiest mite for quite some time.
Specifications >
VEHICLE TYPE: front-engine, 4-wheel-drive, 4-passenger, 3-door hatchback
BASE PRICE (Germany): $55,000
ENGINE TYPE: turbocharged and intercooled DOHC 16-valve inline-4, iron block and aluminum head, direct fuel injection
Displacement: 121 cu in, 1984 cc
Power: 256 hp @ 6000 rpm
Torque: 258 lb-ft @ 2500 rpm
TRANSMISSION: 6-speed manual
DIMENSIONS:
Wheelbase: 97.2 in
Length: 157.0 in
Width: 68.5 in Height: 55.7 in
Curb weight (C/D est): 3000 lb
PERFORMANCE (C/D EST):
Zero to 60 mph: 5.0 sec
Standing ¼-mile: 13.7
Top speed (drag limited): 152 mph
FUEL ECONOMY:
European combined cycle: 27 mpg
Old 02-28-2012, 01:22 PM   #2
Dex
Member#: 163775
2014 Ford Fiester ST
Murica Red
Unfortunately our ignorant populous would think it's a Fiat 500 and shrug it off.
Dex is offline   Reply With Quote
Old 02-28-2012, 02:06 PM   #3
RicardoPT
Member#: 244797
2006 wrx wagon limit
sgm
Ive been inside one its way bigger then a fiat 500.
RicardoPT is offline   Reply With Quote
Old 02-28-2012, 02:25 PM   #4
ChiWRX
Member#: 140955
Just trying to be
productive here.
That looks so damn fun. And relatively comfortable too.
ChiWRX is offline   Reply With Quote
Old 02-28-2012, 05:15 PM   #5
Dex
Member#: 163775
Murica Red
You're not getting what I'm saying. The American public is stupid when it comes to these small cars. Unlike enthusiasts such as ourselves, most Muricans don't and won't take the time to research this machine, and simply cast it off based on its looks and size.
Old 02-28-2012, 06:09 PM   #6
Stanley
Member#: 7374
2007 Grandpamobile
BlingBlingBlue
"Front biased" Quattro usually means a Haldex set up. I'd expect more for $55 grand. But then again, you can't draw direct comparisons in price by simply doing a currency conversion. Being a limited production vehicle means that it will probably be sold with mark ups, anyway.
I'm guessing that Audi execs decided the TT-RS was enough for USDM. You have to keep you halo cars in short supply or they lose their halo.
Stanley is offline   Reply With Quote
Old 02-28-2012, 08:07 PM   #7
boxerinside
Member#: 191994
damn! thats awesome!
talk about a sleeper.
Why can't they bring that car to compete against the MINI?
boxerinside is offline   Reply With Quote
Old 02-28-2012, 09:34 PM   #8
4wdwrx
Member#: 72042
2002 V7 Impreza
"Blue Mammoth" Returns
I want one.
3000 lbs ? kind of heavy for such a small car.
4wdwrx is offline   Reply With Quote
Old 02-28-2012, 11:07 PM   #9
XanRules
Member#: 157348
1996 JNCO Jorts
Stonewashed Denim
XanRules is offline   Reply With Quote
Old 02-29-2012, 12:08 AM   #10
Dex
Member#: 163775
Murica Red
Because this:
Old 02-29-2012, 12:15 AM   #11
coelement520
Member#: 271641
2008 impreza
grey
thats a sweet car but i can buy something much faster for $55k, like a used m5. however if they imported a slightly detuned version and sold it for $30k, i would be all over it.
coelement520 is offline   Reply With Quote
Old 02-29-2012, 01:28 AM   #12
HipToBeSquare
Member#: 119958
1992 SVX LS-L
I am still trying to grasp how Audi can sell A1, A3 3-door, and TT, simultaneously. In europe granted, but still.
And yet Quattro Sport Concept, or mid-engined R4 are still relegated to the drawing board or as a concept car only.
HipToBeSquare is offline   Reply With Quote
Old 02-29-2012, 06:55 AM   #13
OrbitalEllipses
Member#: 178811
2011 White Corolla
Over 400hp
I think your answer to that question is "in Europe granted". Small FWD cars are their bread and butter.
The poster who said Haldex is probably right, which makes this car that much less awesome. I'm sure all 333 will find homes though.
OrbitalEllipses is offline   Reply With Quote
Old 02-29-2012, 06:58 AM   #14
dave07
Member#: 291349
2013 Mustang GT
I thought this looked pretty sweet then I saw pictures of the rear end...blahhh. It's ugly!
dave07 is offline   Reply With Quote
Old 02-29-2012, 07:10 AM   #15
lark6
Member#: 2715
70 911T
You're not getting what I'm saying. The American public is stupid when it comes to these small cars. Unlike enthusiasts such as ourselves, most Muricans don't and won't take the time to research this machine, and simply cast it off based on its price and VAG origin.
There you go.
lark6 is offline   Reply With Quote
Old 02-29-2012, 07:14 AM   #16
KC
Member#: 442
13 Crosstrek XV
00 S2000
KC is offline   Reply With Quote
Old 02-29-2012, 11:25 AM   #17
Eyeflyistheeye
Member#: 69694
2014 EuroPinto 5MT
If it's $55,000 in Europe, I don't see how this is coming in under $42k in the United States.
Eyeflyistheeye is offline   Reply With Quote
Old 02-29-2012, 01:45 PM   #18
SCRAPPYDO
Member#: 873
2014 GLK/allroad
Datsun 71 240Z & 68 2000
They would not sell one of these darn things at 42K and up in the states. That is crazy. No, it is worse, that is just plain stupid.
Buy a Golf R and be done with it.
SCRAPPYDO is offline   Reply With Quote
Old 02-29-2012, 10:14 PM   #19
UKscooby
Member#: 33287
RIP Nik
I will always miss you
The A1's are quirky looking. Personally, I'm not a fan.
UKscooby is online now   Reply With Quote
you can hate obama all you want, but you have to love this moment SQ3.0dotJP Political Playground 36 05-29-2011 04:07 PM
Couple of parts we want you to have.....K&N Typhoon Short Ram Intake and WRX Muffler GTWORX.com MAIC Vendor Classifieds 7 05-27-2008 01:48 PM
Such is life....money to buy lunch but can't have it kaisersouse Off-Topic 16 02-06-2008 02:14 PM
The "I went to Japan but don't have as many cool car pics as Palmer" thread. Trailboss Member's Car Gallery 40 06-23-2006 04:52 PM
If we can't have the War forum...... imprezton Off-Topic 23 05-29-2003 03:57 AM
