Tri-State Area Club
Go Back   NASIOC > NASIOC Regional Areas > Tri-State Area Forum
Old 02-08-2013, 03:27 PM   #426
Donzo
Member#: 95337
2012 Jeep Overland
I asked the guys in OT their suggestions on an affordable laser for a Sig Pro 2022. I figured I'd copy/paste the responses here in case any of you are in the market for one or if you guys have a suggestion on another brand/model I should look into.
Originally Posted by Donzo View Post
Suggestions for an affordable laser to go on a Sig Pro 2022? Preferably not a $400 Crimson Trace. FYI the gun has a picatinny rail in front.
I found the LaserMax Uni-Max while reading reviews on the gun. Is it any good?
Amazon.com: Lasermax Uni-Max® Micro: Sports & Outdoors
Originally Posted by PGT View Post
I'll likely get one of these. I had the larger green LaserMax on my FiveSeven; it was fine but ate batteries. I sent it back to them and the did a warranty repair on it and it was fine afterwards.
Originally Posted by iguanamafia View Post
I use a light laser combo that works pretty well. Obviously more bulky than just a laser, but for $70 more(i didn't shop around mine is a Sig labeled one that i was given). Has momentary, constant, strobe, and of course the laser and the laser adjustment wrench is integrated into the light.
http://www.cheaperthandirt.com/product/58446
Originally Posted by grannyshifter View Post
i have one, it's a piece of **** don't waste your money on it. doesn't retain it's zero and drains battery. get something else.
Originally Posted by ALTribeca View Post
*A LOT* of the pistol ones are sub-par at-best.
I've had a couple of LaserMax Unis - they each withstood about 600 to 1K rounds of 9x19 (with a good handful of +Ps thrown in), but somewhere around there, they'd start to either seriously drift from zero or suffer electronic problems.
If you're going to plink with them, zero them, and then put the gun away for that potential SD/HD scenario, I think they - or virtually *any* of the multitude of < $150-$200 items you'd find today on the marked would be just fine. After all, you're not going to be going into ninja-battle with these items: for an imagined HD scenario, you're looking at perhaps no more than two magazines' worth of ammo needing to be expended, and even today's "airsoft grade" electronics are more than durable enough for that.
But if you're thinking about serious practice or going to training classes with such devices, I'd really recommend that you go by the old saying of "buy once, cry once." The TLR-2 has been reported as being good by some, marginal (or even less so by others)...one member on another Subaru Forum decided after about a weeks' worth of research to just suck it up and go with a Surefire X400.
I've had pretty good luck with the old Insight M6. You should be able to get those second-hand for well less than $150. Their output is limited (it was quoted an honest ~100 lumens, and the reflector assembly does produce artifacts) and the unit has limited run-time (incandescent), but that said, the run-time and output should both be more than sufficient for average HD-duty, unless that scenario for you also extends to covering your property, and you happen to have a bigger yard.
In the end, you've gotta ask yourself why you want a laser, and how this particular aiming aid is going to be employed. Let that guide your purchase.
Originally Posted by speelnik View Post
I bought the Sig brand one for my P226 on their website. 149 shipped (free shipping on orders over 100).
https://www.sigsauer.com/SigStore/cp...laser-405.aspx
Originally Posted by RuskiWGN View Post
Thank you, gentlemen. Your input is much appreciated. I considered a light/laser originally combo but I think that may be too tacticool for me and previously thought "it's an answer to a problem that doesn't exist." However, I recently considered it because a few nights ago something fell in the kitchen around 1 AM so I grabbed the Sig. The light switch is on the other side of the room and right then is when I thought that a light/laser combo would have been handy. I do keep a flashlight nearby also but having a free hand would be much more preferable.
It ended up being something in the kitchen that fell, not some skell trying to steal pots and pans.
Donzo is offline   Reply With Quote
Old 02-16-2013, 01:43 PM   #427
Donzo
Member#: 95337
2012 Jeep Overland
I've never heard of this movie before but after watching this clip, I need to rent it.
The Veteran
Old 02-16-2013, 01:44 PM   #428
Donzo
Member#: 95337
2012 Jeep Overland
Hey guys, Putnam Armory is giving away a free t-shirt to their 100th Like. Go visit the page and give them a Like!
www.facebook.com/PutnamArmory
Old 02-18-2013, 01:25 AM   #429
PhotoREX
Member#: 180193
04 Forester XT
Oh man this thread is right up my alley! Can't believe I missed it haha. Ps I work for Dick's in the Lodge.
PhotoREX is offline   Reply With Quote
Old 02-18-2013, 01:55 AM   #430
yellowrxo2
Member#: 13454
02 wrx
yellow
Which Dick's?
Palisades mall Rockland county and Whiteplains NY.
yellowrxo2 is offline   Reply With Quote
Old 04-06-2013, 11:48 PM   #431
Donzo
Member#: 95337
2012 Jeep Overland
SIG Pro 2022, Glock 23, Spikes Tactical AR and Bushmaster Carbon (polymer) AR.
Old 04-07-2013, 02:52 PM   #432
blackmamba11
Member#: 266458
2011 WRX sedan
black
Using a laser is not as great as people want to think or have been trained to think by seeing them used in movies. They could give your position away while engaged in a home defense situation and the shooter will be more focused on the laser, rather than the more important front site picture. The laser is electronic and works off of a battery which could fail and murphy's law will tell you that it most likely will fail when you need it the most. This can be said with a weapon mounted light as well. Something to get around this and have a solid back up plan would be to get a set of night sights installed which work very well in total darkness to low light environments. I have a glock 21 SF gen 4 with trijicon night sights and a surefire x300. I have shot numerous times in low light to total darkness situations with just the night sights and they are very efficient in my experience.
blackmamba11 is offline   Reply With Quote
Old 04-08-2013, 12:43 AM   #433
Mike Costin
Member#: 131787
06 STI,OB,OME XJs
Merkur Junkyard
^^ great setup
glock 23 gen3 with green trijicons and a surefire g2x here
Mike Costin is offline   Reply With Quote
Old 04-08-2013, 02:05 AM   #434
FreNetiC STi
Member#: 164797
It gets me from
point A-B
Your reasoning seems very similar to that of a police officer, or someone of a similar capacity. I like it.
FreNetiC STi is offline   Reply With Quote
Old 04-09-2013, 07:11 PM   #435
blackmamba11
Member#: 266458
2011 WRX sedan
black
I do have some background. Its really about preference but practicality is important to consider.. KISS.. Keep it simple stupid. I aloe have a springfield armory XD 4" .40 cal with a TLR 3.. Just a light no laser and have not gotten around to putting night sights on it. I have a springfield XD S .45 on the way for my CCW.
Old 06-21-2013, 12:30 PM   #436
Xeno057
Member#: 347866
Hi guys,
Can you PM me with recommendations for ranges to rent/shoot? I live in NYC, and I am planning a little bachelor's party for my friend.
I will be heading around 3 hours north, or 2 hours northwest of NYC for some other activity, so something around those areas would work nicely. But I suppose anything close to the city would work too.
Thanks!
Xeno057 is offline   Reply With Quote
Old 06-21-2013, 12:40 PM   #437
Donzo
Member#: 95337
2012 Jeep Overland
You have Blue Mountain, Putnam Fish & Game, Whortlekill Rod & Gun and Wooster Mountain in CT. All are about an hour or so from NYC.
I'm sure there are others.
Old 06-21-2013, 01:14 PM   #438
Xeno057
Member#: 347866
Thanks for the suggestions, but I dont think any of those rent out firearms.
Old 06-21-2013, 01:17 PM   #439
Xeno057
Member#: 347866
I see this place: http://www.sunset-range.com/index.php/firearms
But seems a bit expensive. Is that the general going rate?
Then there's this place: http://www.thundermt.com/rates.html
It's only skeet/trap shooting, but much for affordable.
Old 06-21-2013, 01:23 PM   #440
Donzo
Member#: 95337
2012 Jeep Overland
Oh, ok. Didn't catch the part about renting also. Check out this old thread I started a while back. I never ended up going but I wanted to go to Sunset Hill.
http://forums.nasioc.com/forums/show....php?t=1384273
Old 06-22-2013, 09:42 PM   #441
Ernest
Member#: 45076
2004 Stg2 Wagon 4eat
Thunder mnt. Is alot of fun.
I shoot at the firing line in pearl river ny. They rent guns, but it's not cheap.
Ernest is offline   Reply With Quote
Old 07-22-2013, 12:11 PM   #442
Donzo
Member#: 95337
2012 Jeep Overland
Blue Trail in Wallingford, CT
Colt AR 15, Ruger Mini14, Remington 700 in .308.
Colt full length and Spike's Tactical carbine
Old 07-22-2013, 12:29 PM   #443
JiveMasterT
Member#: 116666
2011 STI Limited
Looks nice, plays dirty
Love that 700. It kicks like a mule but even with a slight breeze we had like 1/2" groupings at 75 yards.
JiveMasterT is offline   Reply With Quote
Old 07-22-2013, 12:29 PM   #444
Donzo
Member#: 95337
2012 Jeep Overland
Old 07-24-2013, 10:56 AM   #445
Donzo
Member#: 95337
2012 Jeep Overland
For any of you interested in hunting, here is a PDF of the 2013-2014 season dates.
http://www.dec.ny.gov/docs/wildlife_...gseasons13.pdf
This is a basic map of the counties:
Old 08-28-2013, 09:29 AM   #446
bonky
Member#: 220806
2004 Honda
S2k
Just picked up my first gun. I cant be any happier.
Kimber 1911 tle/rl
33 days later...... I picked up my second gun
HK p30 9mm
I got about 500 rounds with the Kimber and about 120ish with the HK. Any range suggestions in NJ? I been going to Heritage guild in Easton PA. Would be nice if there was one closer.
bonky is offline   Reply With Quote
Old 08-28-2013, 09:45 AM   #447
Donzo
Member#: 95337
2012 Jeep Overland
Congrats!! Both of those are awesome! I've wanted a P30 for a while now. How do you like it so far? I ended up getting a SIG instead since I couldn't find a P30 to look at locally.
Old 08-28-2013, 09:53 AM   #448
bonky
Member#: 220806
2004 Honda
S2k
I love it. The main reason why I went with the P30 is because it fits like a glove in my hand. Adjustable back straps ftw. The trigger pull is a bit long for my liking but that is probably because I'm spoiled by the trigger my kimber has.
Old 08-28-2013, 03:11 PM   #449
the mike
Member#: 30926
2003 MBP
Sedan
Just a bit of advice, if you're in Jersey, I would remove those rounds from the case if you're traveling. No need to give the law any reason to give you a hard time.
the mike is offline   Reply With Quote
Old 08-28-2013, 03:17 PM   #450
bonky
Member#: 220806
2004 Honda
S2k
yup, I only did it for the picture. I always put my ammo in the back and firearms in the trunk.
Tri-State Motorcycle thread 4or2wheels Tri-State Area Forum 1737 09-05-2013 08:37 PM
Post pictures of your guns....Another gun thread... FreeBMW Off-Topic 93 06-12-2006 03:21 AM
Tri-State Forum Threads of Note! munkis Tri-State Area Forum 0 06-24-2004 11:35 PM
Tri-state Saddam Thread (put your comments here) typhoon116 Tri-State Area Forum 44 12-16-2003 05:59 PM
Gun people - Kimber Pro Tac II, or HK USP compact??? Yes, ANOTHER gun thread..... Subasaurus Rex Off-Topic 9 11-11-2003 11:24 PM
