Old 02-28-2012, 05:05 PM   #1
bugI-rx
Member#: 307546
02 Wrx
Psm
Default 02 wrx stage 2 knock?
I just did a few data logs and to me it looks like im getting knock at higher rpm. does anyone have any input? kinda new to this datalogging thing too. sorry for the crappy image. excell wont let me copy for some reason.
my mods are
cobb intake
invidia catless bellmouth downpipe
jna performance catback
cobb accessport v.2 stage 2 93oct. 3.0
bugI-rx is offline   Reply With Quote
Old 02-28-2012, 06:16 PM   #2
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
use the "adjust timing" feature in your AP to pull 3 degrees of timing. drive the car for a day or two, then re-log a WOT pull.
Black94Snake is offline   Reply With Quote
Old 02-28-2012, 07:33 PM   #3
bugI-rx
Member#: 307546
02 Wrx
Psm
looking much better, no more fine knock, however im still getting feedback knock? is this normal? i read up on it but still dont quite understand what could be causing this.
https://docs.google.com/spreadsheet/...KYTFrY0E#gid=0
https://docs.google.com/spreadsheet/...DhPbFVUSXY3ekE
Old 02-28-2012, 07:42 PM   #4
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
you should add "knock sum" to your datalog
You also might want to consider buying a wideband.
Old 02-28-2012, 07:52 PM   #5
bugI-rx
Member#: 307546
02 Wrx
Psm
thanks, I appreciate the help.
edit: just check and I dont think I have it. its the sub-001
Old 02-28-2012, 08:05 PM   #6
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
i'm not sure about the differences between the 001 and 002. I was just recalling what I use in my logs.
Old 02-29-2012, 11:20 AM   #7
Cobb Tuning
Member#: 4803
First, I would recommend downloading the newest v3.10 maps directly from our website. These are all new maps that work much better than the older ones. When you do the map change, make sure it is a Reflash map change, not just a Realtime. You will need to connect the green test mode connectors and the initialization connector. Also, on the older WRXs, it is very important to make sure maintenance is up to date (spark plugs, clean air filter, etc.) and that there are no boost/intake tract leaks. Once you change your Reflash map, post another log and we'll see how it is running!
Ian
Dyno'd 02 WRX Stage 2 247 WHP rexman2002 Proven Power Bragging 25 02-05-2014 04:23 AM
02 WRX Stage 2.5-3 on a AP v2..?? Aaron'z 2.5RS AccessPort 5 10-22-2009 08:59 PM
02 wrx stage 2 wagon aj777777monaco Private Vehicle 'For Sale' Classifieds 0 08-31-2007 06:47 PM
WTT: my 02 wrx STAGE 2 reflashed ecu for your stock ecu + 200 akcel SCIC Private Classifieds 3 05-19-2006 11:36 AM
FS: OH, PSM 02 WRX Stage 2 Vashed Private Vehicle 'For Sale' Classifieds 4 10-21-2005 05:47 PM
